Question about Penn Gt Levelwind Series Reels
How to replace dog spring on Penn Reels getting the spring and dog positioned correctly under the bridge plate.
4 Suggested Answers
  • 69 Answers
SOURCE: Penn Squidder Model 140 controls
ok one is for your drag the other is reeling 3rd one are the brakes 4th one is your clicker and the last one is your spreader .
Posted on Apr 02, 2009
  • 75 Answers
SOURCE: PENN ASSEMBLE ISSUE
http://www.tackleheadquarters.com/Penn%20Schematics/320gt2.pdf
here it is
Posted on Jul 06, 2009
  • 242 Answers
SOURCE: my penn 113h is slipping when hook on a big fish.
sound like a very warn clutch
Posted on Dec 23, 2009
The feed dog do not come out and I can't put the plate on and I use the button and the button don't work help me what should I do to fix it by my self in my house
The feed dog comes out to move the material by adjusting the length of the stitch.
1. The plate is replaced by placing the spring under one side while the plate is at an angle.
2. As you slide the plate forward carefully you will see the second moving up to the machine.
3. Place the spring under the holding groove on the machine.
4. Carefully turn the plate until it pops into the grooved area. This may be troublesome but you'll get it. Also, the throat spring is strong so use a small screwdriver to hold it open while positioning the throat plate.
Aug 29, 2016 | Sewing Machines
How do I remove the bottom plate off of A Kenmore 1941 sewing machine? I removed all the screws and it still want come off.
1. Slide the front plate towards you. (Don't remove)
2. Lower feed dogs by rotating the hand wheel.
3. Raise the pressure foot or totally remove.
4. Remove the plate under the feed dogs.
5. If you remove the front plate it can be replaced at an angle. (Flat like paper) There are springs under the plate that must catch under the main frame of the sewing machine. Twist the plate until straight and push into position.
Nov 10, 2015 | Kenmore Sewing Machines
My penn 4300 ss, the bail won't close on it's own when I rotate the handle, I can close it manually. I have 3 other 4300's that work fine
You need to either replace the bail spring or release any tension cause by the bail wire gap being too wide or to small. Take apart the bail wire and adjust the gap so that it doesn't bind when closing the bail.
Mar 19, 2011 | Penn Gt Series Levelwind Reels 330GTi
Require a diagram to assemble 330GTI reel. Reel disassembled as drag not functioning properly
Here you go!
330 GTi Schematic
Make sure the drag plates and drag washers go in correctly or the drag will not work very well.
If you are using braided superline, make sure there is monofilament backing under the line otherwise the braided line will slip on the spool arbor, tricking you into thinking the drag is shot.
Best of luck!
Mike
Sep 26, 2009 | Penn Gt Levelwind Series Reels
Penn Gt Levelwind Series Reels Logo
262 people viewed this question
Top Penn Fishing Experts
ray gallant
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Are you a Penn Fishing Expert? Answer questions, earn points and help others
