Question about Canon imageRUNNER 2000 Copier
Paper keeps getting jammed in left cover when i try to copy on both sides of the paper
  • 1,219 Answers
first: did you set correct paper size and type for bypass insertion?
Second: Clean roller!!
Remove drum cover, its a cover left sideway, with grey handle in middle. You can remove it by pulling it into left side.
Remove bypass tray, it is holded by two plastic hinges. You must remove them from its holders.
Now you are able to see the bypass roller.Its in the midlle and has plastic axis from both sides.
Clean it with alcohol, and dry it.
Try now, run few copies from bypass.
If that doesnt helps you you need to check bypass clutch, wich is located left of the bypass tray, covered with plastic cover, wich covers section from bypass to up to the fixing unit.
To remove bypass clutch you also must remove back cover.
But if you must do these write me on emma.servis@gmail.com, or call service, because the clutch must be putten into specific position.
Hope that helped!
Posted on Jul 31, 2010
Canon IR 2016j, paper jams on every copy.How do i fix it?
Dear Abdullah
pl. check the machine base where it stay, it should be plain and firm.
Next check the left side door(test it by pushing inside while making copy). check the fixing assembly and paper path, may be toner clogged on its surface.
If your machine covered more than 200000 A4 copies, check the paper path (guide) at registration sensor and delivery guide at fixing unit.
If the paper jam at paper pickup tray, replace the pickup roller set (2nos.)
Since you have not mentioned the page counter and where paper jam occurs, its difficult to assume more.
thanks.
Mar 15, 2015 | Canon Office Equipment & Supplies
My kyocera KM 1815 keeps saying "paper jam 00 open left cover and remove paper jam but there is no jam
Hi
Check all the paper movement from the tray, left or right cover, front cover, if so then remove jammed paper. Otherwise the paper sensor spring guide missing or fell off from its original position. Check carefully where the sensor locate. paper sensors detect all the paper movement in the machine during copying or printing, so locate the place in the machine which the paper usually jammed, see the screen of the machine, it will locate the place where the paper jammed mostly. Sensor not return to it original position that is why ( remove paper jam keeps blinking)
Aug 11, 2014 | Kyocera Mita Office Equipment & Supplies
Canon ir2016 jams papers under registration clutch. the clutch runs on power up but does not run when copig or printing help
This seems to be a common problem for the Canon ir 20 xx series machines. The problem is having machine indicating paper jams on the left hand side of the machine. When you open the left cover you do sometimes find paper stuck on entering the fuser unit. The main problem, and loads of these machines with these problems have been fixed, are the half moon pickup rollers! Clean the pickup rollers or even better, replace them and you will get the machine working 100%!! To confirm this try copying from the machine using the manual feed tray. You will never get a paper jam. This fault is due to incorrect pickup resulting in timing problem and thus getting paper jams! Good luck!
Mar 10, 2014 | Office Equipment & Supplies
Keeps showing follow instrctns in right cover to remove. Unable to copy
ther is a paper jam in the machine, open the side cover and remove the paper jam, if the paper is not visible then there is a small piece stuck somewhere.
Nov 17, 2010 | Ricoh Aficio 2015 Copier
I get a paper jam every time I try to manually make a copy on the second side of a copy. First side no jam. Help. Derek
hai,
Open the leftside lower cover (below the dlivery door).
i think duplex revesing area have old copied papers. if have remove it, then
Check the paper passing rollers dirt or demage, clean it, hold properly
then clean the sensor of paper reversed area.
best of luck
May 23, 2010 | Canon imageRUNNER 400S Copier
Brother 8820d MFC auto doc feeder does not work...
You need a new hinge so the cover will sit down properly, or paper will jam anyway, but it sounds like there is still a scrap of paper on one of the sensors inside the ADF, you need to look with a flashlight down thru where the paper goes and also look up thru the slot with the ADF lifted.
Sep 11, 2009 | Brother MFC 8820D All-In-One Laser Printer
Paper jam that I can get the small pieces of paper out
sounds like your jammed paper is in the fixing assembly. (the one on the right side, where the paper comes out printed very hot)
you are gonna have to remove it from the copier to easily remove the paper.
here's some instrutions.
remove the cartridge. then remove the platten glass. you will need to remove a small plastic cover on the left side of the glass. then just remove the glass. then remove a black piece of plastic that covers a cable. now remove the control panel. like if you were to remove the cartridge open the uper cover and there you should see a screw. unscrew it, then the panel must slide a little to your left and then just carefully unplug the flat cable. now you need to remove all the covers on the left side of the copier. (...ok they dont sell this particular model around here but if you do not happen to see screws on the left side then you may have to remove even the front cover). once done, unplug the fixing assembly, there must be at least two connectors that go directly to the power supply, then unscrew it, from two holes located at the top (where you previously remove the platten glass), on one side there should be only one screw and on the other two. once is unplugged and unscrew it should come out 'easily' Caution: It could be hot! now you gotta remove the top cover of the assembly just unscrewing the two screws one per side. it still it doesnt pop up it has some kind of metal locks you just need to push or pull depending on how they're located. once you get to this point (or even before) you should be really able to remove all the paper jammed in there. Good luck!
Jan 15, 2009 | Canon PC-1060 Black and White Copier
Check document message
It thinks there is a document stuck in the document handler. Check for a small piece of paper, or a stuck sensor.
May 27, 2008 | Canon imageCLASS D340 All-In-One Laser...
Canon imageRUNNER 2000 Copier Logo
174 people viewed this question
old marine
old marine
