Question about Sharp AR-5316 Advanced Digital Imager Copier
The page comes blank, the toner and developer are in good condition
    President:
  • 2,072 Answers
On the right side door there is what is called the transfer corotron.
It is a metal assembly with about a half inch opening with a plastic guide at the bottom. Inside there, there is a hair thin wire and that most likely has broken not allowing the image to transfer from the drum to the paper. Since you are getting no fault codes, that is most likely your problem.
Posted on Jul 30, 2010
Empty Developer on MP1900
Should replace the TYPE 28 DEVELOPER every 60,000 pages.... this is needed to mix with the toner. if you cleaned the toner/ developer mix out of the developer already then it will definatly give you blank pages ..... hopefully this helps.
Mar 13, 2014 | Ricoh Office Equipment & Supplies
Prints black pages
Please check the following parts:
exposure lamp does turn ON?
The PC drum charge voltage terminal in good condition?
Is the grid voltage terminal in good condition?
Is the developing bias terminal in good condition?Are the mirrors and lens dirty?
The PC drum cleaning blade is OK?
Waste toner collector agitator gear is in good condition?
Feb 06, 2013 | Ricoh Aficio 450 Copier
Magicolor 2300DL Printer. Blank pages come out. No error message. Toner and Drum are OK
here is my thinking... toner... goes from toner container... via developer to drum... where it gets info and then to paper where it gets placed... and then to fuser where it gets cemented...
if pages are coming out blank... check if toner is full... then check if developer unit is turning... then check if there is an image on the drum... if no image on drum then the charge roller or charge wire is not working....
if you still think all is ok up to this point then check your fuser... if it is cold after your machine is on for five minutes then its blown...
thats how I would check it...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Mar 12, 2010 | Konica Minolta magicolor 2300DL Laser...
Pages come out blank, even after changing toner on Ricoh 450
try to check transfer belt and related contact point on the right hand side.
Mar 10, 2010 | Ricoh Aficio 450 Copier
-Laser Printer printing NEAR blank pages\
if this is an fs3900 tray rerunning the developer thru the machine.
Do this by going into the menus..up and down untill you see others..than right arrow..now up and down untill you see service...right arrow..than up and down untill you see developer..once you see developer hit enter twice...power off than back on machine..it will than recoat the mag roller with toner...good luck
Jan 30, 2010 | Kyocera Mita KYOCERA/MITA - FS-3900DN Mono...
White/blank vertical lines
Try cleaning the laser **** glass. If dust or toner is on the glass, you won't get proper or even charge due to this condition. You need to remove the photoconductive drum to check this.
Jun 05, 2009 | Toshiba e-STUDIO 6CP Laser Printer
Blank copies on an ar208s sharp copier
Inside this machine has 3 sections. Toner cartridge, developing unit and drum unit. First pull out the toner cartridge then you will see a blue anodized screw, loosen this screw then pull this section ( developing unit ), if there's already toner inside the chamber, clean it and pour the all the developer into the chamber then put back the developing section, tighten the blue screw and install the toner cartridge.
May 12, 2009 | Sharp AR208s copier AR208s All-In-One...
New cartridge
Yes, it should.. It releases the toner into the developing unit. You may want to try running some blank page through the copier to get the toner moving evenly in the developing unit... Or it could just be a Bad cartridge. If you put the old one back does it work???
Sep 10, 2008 | Canon PC-940 Black and White Copier
Blank Copies
The Unit where you've put the toner cartridge could be to far from the drum. Make sure your developer unit (unit where you've put the cartridge in) is locked in place.
Mar 14, 2008 | Canon NP 7130 Black and White Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
49 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
