Question about HP LaserJet P3005n Printer
Printer Prints documents for a certain period of time
Hi all,
I'm having a problem with my HP 3005n Printer. On the control Panel it shows it's ready however when I print a document nothing prints. I recieve a error on my computer. I can't even Ping to the printer I get timed out. I cycle the power and sometimes it resolves the problem and prints fine for about an 1hr or so then it goes back. I'm thinking it's some kind of connectivity issue maybe a new NIC Card or something. Any thoughts would be greatly appreciated - Thanks
  • 1 more comment
  • Spencen8er Mar 06, 2009
    Yeah, my P3005N does just about the same thing. it's like it goes to sleep and won't wake back up again. It displays 'Ready' on the LCD, but pressing any of the buttons does nothing, and the driver says the printer is offline. I can't ping it or print to it. Cycling the power will work for a little while, but once you leave it alone for too long, it freezes again.
  • ajsingh Apr 01, 2009
    I've had the same problem and have been told it is an issue with the formatter board which HP have replaced along with the memory, on several occassions. Still hasn't been fixed. There is definitely a design fault with duplexing units..
  • sakkas Apr 06, 2009
    I also have the same problem. My only question is if this problematic behaviour is covered by the guarantee...
    Problem Solver:
  • 5 Answers
Printout a configuration page from the printer display, look wath it says according to the intern jetdirect.
Does the green led blinks on the back of the printer if not try another line or you NIC on the formatter board is defective.
Buy Q7848-60002 formatterboard P3005N/DN/X (incl NIC)
Posted on May 22, 2008
I am printing documents to my HP LaserJet 5000n Printer and the printer's not responding. I've tried restarting it and it displays that it's processing a job before displays that it's ready.
Either a corrupted driver or possibly a bad network card or parallel port, depending on how you have it connected. Does the printer print test pages from the on printer control panel ok? If yes, try printing a different document from a different program or try the windows test print from the driver. If it prints the windows test print then likely you have either a corrupted program or file. If it will not print the windows test print then I would delete the driver, download the current HP UPD driver and install that.
Sep 24, 2015 | HP LaserJet 5000n Printer
Cancel print job with a linux operating system
You've sent a print job to your printer and the green light is blinking, but the printer is not printing. The light blinks for a very long time.
The blinking light indicates that the printer is recieving your print request and will print shortly. If the document you are attempting to print is very large or contains many graphics or images, the printer must spool this data into its memory before printing. This can take quite a bit longer than usual. PDF files are notorious for taking longer than other document types.
In this case, it is best to wait a period of time before taking action. Give the printer 10 minutes and see if it prints.
If it does not print within this window of time, do the following.
1. In the bottom right corner of your screen, you will see a small printer icon. Double click on this icon to open the printer job menu.
2. You will see your print job located there, with other information, including its status.
3. Select the job by right clicking on it and select Cancel.
4. The job should cancel itself.
5. Unplug the printer, removing all power and leave it sit for a couple of minutes.
6. Plug the printer back in and allow it to go through its start up phase until the "Ready" indicator light is solid. This indicates that the printer is ready to recieve jobs.
7. You may now attempt to print again.
HP Printer Support
Jul 16, 2014 | HP Office Equipment & Supplies
Hp 2600 no longer prints from my laptop
Hi Friend,
I think One time uninstall printer software and restart laptop and installation before clean the virus in laptop then install printer driver. If any error show in installations time then antivirus sort time disable. And software full install then proper check it printer driver show in control panel. If problem same then change printer cable connector.
If then not solved then finally you check other OS laptop may be find error.
Jan 14, 2014 | HP Photosmart 2610 All-In-One InkJet...
Yellow not printing properly.
Go to the maintenance section of your printer on your desktop and clean the cartridges
Start - printers or Start - control panel - printers
Also check the level of your ink while you're there
May 08, 2010 | HP Deskjet D2360 InkJet Printer
Downloaded driver from HP. connected printer via
HP Support says “If the Ready light is blinking, and the Go light is on, it indicates Data in the printer memory is waiting to be printed. Pressing the GO button prints from Tray 1 or from another tray if Tray 1 is empty and the paper size is supported in the other Tray. Pressing the JOB CANCEL button cancels the current job and the printer returns to ready.
Make sure the paper size is correctly defined.
Dec 05, 2009 | HP LaserJet 2100tn Printer
HP PSC 2410 All-In-One InkJet Printer
You could go online to and see if the drivers need to be updated.
Jun 14, 2008 | HP PSC 2410 All-In-One InkJet Printer
HP Laserjet 1020 reprints on logon
Turn off printer, Goto Control panel then printers and faxs, double click on your printers icon, a box opens with your pending prints, select file and cancel all documents, close all windows, restart printer
Dec 16, 2007 | HP LaserJet 1020 Printer
HP LaserJet P3005n Printer Logo
292 people viewed this question
Ben Johnson
