My set is just over 4 years old and when it started turning itself off every few minutes in April this year the approved service agent did a house call and changed the bulb. He also cleaned the two filters but they were not very dirty. I have put the airconditioning on in the TV room and it still goes off after about 90 minutes of running. Could it be another bulb replacement? Local service agent no longer makes house calls - will come and pick it up and take back to workshop - $110 for this service and to quote to fix it. I am on the Gold Coast Queensland. How do you remove the soft air filter from its housing?My set is just over 4 years old and when it started turning itself off every few minutes in April this year the approved service agent did a house call and changed the bulb. He also cleaned the two filters but they were not very dirty. I have put the airconditioning on in the TV room and it still goes off after about 90 minutes of running. Could it be another bulb replacement? Local service agent no longer makes house calls - will come and pick it up and take back to workshop - $110 for this service and to quote to fix it. I am on the Gold Coast Queensland. How do you remove the soft air filter from its housing?
There is a software patch that increases the cut off temperature you may get this at Loewe Website. Quick fix is reverse one of the fans on the back of the set this gives a through flow of air rather than all fans blowing into the set.
You have to replace Lamp before resetting Lamp Timer and most of all the ones I have replace TV does it Automatically.But if you do have a problem on Menu go to Lamp Timer and reset.
If Fan stops running Lamp will not Light and TV will not come on!On your Menu you should have in there a listing for Lamp Timer it should tell you how many hrs you have on Lamp and Ballast Board is what turns Lamp on if you need Parts Call Encompass 1-800-638-3328 or UED 1-800-648-6657
Its Bad if it does not Light! Call Encompass Parts or look up their website for listings of Parts to your TV.
1-800-638-3328 also I have found some good deals on Lamps on E-Bay got one for mine for 85.00 and got my Ballast Board for 65.00
sorry cant solve it ,i called all the loewe service agents and they all said the same thing, put up with it. a new engine/colour wheel cost around $2500,
There is a software patch availabe to increase the thermal cut off temperature. Can only be programmed using the Loewe Cablemax kit. Another solution is that the fans at the back all blow into the tv, reverse one of these fans, this gives a flow through the cavity. Remember to remove the filter from the one you reverse.
TV light goes on and off without appearance of any picture
