Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Remove front speaker and input jacks
I need to replace an RCA jack on the front of RCA D52W19. I also want to get access to Video Tubes
  • RCA Master
  • 8,617 Answers
You can get the info and parts the Front Input Board from www.tvrepairworld.com
Posted on Jul 31, 2010
How to hook up the subwoffer
There are several methods, depending on the the types of 1)inputs on the subwoofer and 2) outputs on the amplifier (aka receiver). You can only use the type that is on BOTH.
Most sub woofers have "line level" inputs (they are the RCA phono style jacks or other style jack) that are marked "In" or "Input" and may have speaker level input & output terminal that accept speaker wires.
Amplifiers or "amp" all have speaker level outputs and many also have jacks that are labeled "Subwoofer" or "LFE" (low frequency effects) Output. If both your sub and amp have the "line level" jacks, then all you need to do is get a cable that is long enough to connect the two together, and then enable the low frequencies to be sent to the sub instead of the normal speakers in the receiver's set up menu. Done!
If you have only a speaker level connections common to both the sub and amp, you'll most likely need to disconnect the Main front L and R speakers from the amp and connect to the sub's Speaker Output terminals - and connect a couple of new speaker cables between the sub's Speaker Input terminals and the amp's Main front L and R terminals.
If you don't understand completely, provide the make and model of the amp and the sub, and I'll be able to clear up anything that isn't clear.
Mar 05, 2015 | Audio Players & Recorders
No sound for earphone, there are no rca jacks, the earphone is used to attach speakers, but there is no sound from the earphone jack
if their is a sound from the internal speaker then the problem is with in only in the earphone jack or in the connection. to access the internal part of the tv you need to remove the rear cover. locate the earphone jack terminal re soldered and check the connection at the board ( PCB). you can check also the continuity, attached powered pc speaker then use an analog tester and check weather their is a connection coming from the stereo input jack going to the terminal of the earphone jack of the tv. if no connection replace with new earphone jack. good luck hope this can helped.
Aug 14, 2012 | Insignia Televison & Video
I do not know what color to use the RCA jack in
RCA Jacks are usually white & red for left and right speakers and yellow for video. If you don't have a three piece set - then they are probably just for speakers and its one for right speaker and the other for left speaker.
On the back of the tv, the RCA jacks plug into the incoming area - with the red & white going to the speakers right and left and the yellow to the video jack. Then you need to choose the input method on the tv menu set up that matches in the one you chose on the tv. Examples of input methods are AUX, Antenna One, Antenna two, ect. With the tv turned on - keep changing the choice of input until you find the one that gives you a picture.
Jul 17, 2011 | Samsung Televison & Video
Hello, I have a Sony STR-D85 surround sound system. I need to connect my phone to the system so that my phone's music plays through my surround sound speakers. The front of the console has a headphone...
Headphone jack is an output not input jack. Your going to need a cord to go from your headphone jack(output) of your phone to audio input on your receiver. The cord has a mini stereo plug to the phone and RCA plugs of left and right to your receiver auxiliary input. Good luck..
Jul 15, 2011 | Sony STR-DE485 Receiver
Where are the amps and how do i by pass them for the stereo
The amps are located inside the radio. Most in-dash receivers that provide for "pre-amp outputs" also called "low level outputs" do so by providing female RCA type jacks. These are often found at the end of a short (4 - 6 inch) cable and are usually color coded red & white or red & black (some receivers provide a yellow RCA jack for video in / out, too). To use these RCA audio jacks, you need to realize that one jack is for the left channel source and the other is for the right channel source for a stereo signal. You will have to connect a compatible plug and cable of enough length to extend to a remote amplifier's RCA input jacks. The vehicle's speakers would also need to be connected directly to the same amplifier's output terminals. Using the two audio (left and right) RCA jacks will only allow the radio to control balance of the left and right audio, no fader (front and rear) control is possible. To get fader control, you'd have to either have a radio with four RCA low level output jacks (front L & R *and* rear L & R), or use the radio's speaker (or high level output) wires and connect them to the amplifier's speaker (or high level) input terminals.
All unused receiver wires should be terminated in a wirenut or securely wrapped in electrical tape to prevent accidental contact with grounded metal or other wires behind the dash.
I hope this helps!
Nov 11, 2009 | Car Audio & Video
I HAVE A RCA TELEVISION, MODEL F20632. I CANNOT FIND THE MANUAL TO HELP ME SET UP MY VCR. I HAVE A 4-PLUG VIDEO CABLE (YELLOW, BLACK, GREEN AND RED). CAN YOU TELL ME WHICH CONNECTIONS ON THE TV I NEED TO...
the yellow rca input jack( not the output one ) is for video in (by itself ) and the red and white rca jack inputs are for the right and left audio that is also required when using the yellow video jack
the red and white audio jacks are also required when using the component video inputs ( BLUE , GREEN & RED ) rca jacks
but only one type of connection is required ( yellow video jack , red and white audio jacks ) or ( the blue , green and red component video jacks and the red and white audio jacks )
you will need the yellow video input and the red and white audio inputs
Jan 05, 2009 | RCA F20632SE 20" TV
Sylvania vcr/dvd installation
!st) The antenna INPUT::RF (black wire usually from "cable TV", "Dish TV", even ANTENNA air wave reception,etc.) into INPUT of VCR\DVD, OUTPUT of VCR\DVD to TV RF input.
2nd) If you have INPUT\OUTPUT to what are called " RCA " jacks on your TV, on the front or on the back, then any & all output jacks from VCR\DVD goes to INPUT\OUTPUT of the TV.
In other words:: output of audio on VHS\DVD to input of audio on TV( RCA jacks). Output of video on VHS\DVD to input of video (RCA jacks)
Hope this helps
Aug 14, 2008 | Televison & Video
I have a aiwa cx-na77, how do I connect it to a tv so that I hear the tv sound on the aiwa speakers
If it has an "AUX" input or any other type of RCA jacks for an input, you can connect the TV RCA audio jacks output to the input RCA jacks of the Aiwa.
That's what you would need.
RCA audio outputs on the TV
RCA audio input on the Aiwa
Just look at the back of each unit and see if it has them. RCA audio jacks are the small circular red and white jacks. They will be labed on each unit what they are for. You need output jacks on the TV and input jacks (but not for phono) on the Aiwa.
Aug 08, 2008 | Aiwa Audio Players & Recorders
I want to setup my logitech x540 surround sound through my tv (which is LG 37LC2D the jacks at the back are Inputs: AV In 1 RF In Y AV In 1 S-Video In 1 Scart Jacks 3 Component in Audio 1 Digital Audio...
Based on your query "...which jack...put the green cable ...", I would suggest that you replace that green cable with a 3.5mm Stereo Phone Male to Twin RCA Male as shown below.
19ba6b8.jpg. The stereo phone would match the green INput ((Front) of the Logitech X-540 while the twin RCA (white & red) would match the RCA AUDIO OUTput of the LG 37LC2D.
Of course hooking it up this way would not fully utilize the 5.1 features of the X-540 (Rear and Sub/Center) but the TV sound will come out of the front speakers.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 09, 2008 | Televison & Video
Sony KV- 32V35 Front Jacks
Yes, the front RCA jacks on the Sony sets always seem to crack loose. I have seen that many, many times. To get to those jacks, you will have to remove the back of the TV and carefully pull out the main chassis, taking care not to pull out any wires or jacks. When the main chassis slides back, there is a smaller board in front of the main board, and the pushbuttons and RCA jacks are on that smaller board. The connectors to that board usually come off when you slide the main chassis back, so you will need to put those jacks back in place when reassembling. Slide the smaller board back, flip it over and resolder the connections on the RCA jacks. Sometimes I find that the copper trace to the center pin of the video (yellow) RCA jack is broken, so test for continuity and solder a small jumper wire to take the place of the cracked copper trace if necessary. Reassembnle the set and your jacks should be working fine.
Aug 31, 2007 | Sony KV-32V35 TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
53 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
