Question about Maxtor HARDDRIVES Hard Drive
Bios won't reconise 160 gig maxtor harddrive
I'm running an ATX BX mainboard MS-6163 pro with an amd 800 cpu. had for over two years. the BIOS will not reconise the new 160 gig harddrive. Any ideas anyone?
  • 30 Answers
You could try a BIOS update to increase the size of the Drive the BIOS is able to see.
The second last one indicates that drive sizes are supported over 65GB. It may still not be able to see the 160GB HDD, but this is your only option with this Board. You could always upgrade the Motherboard to support larger drives.
Good Luck.
Posted on Apr 25, 2008
How to adjust jumper settings of ecs mainboard mcp61m-m3
onbly jumpers on that board should be for bios cmos clear. the cpu setting snd such are to be adjusted inside the bios setup utility.
Mar 09, 2011 | EliteGroup ECS MCP61MM3 (V10) AM3 NVIDIA...
A770E3 MOTHERBOARD 4 GIG RAM SATA 1 TERABYTE HD SATA CD/DVD NETBIOS SEE EVERYTHING FINE. BOOT SEQUENCE FOR CD ROM 1ST PROBLEM. WONT BOOT ANY OS. XP PRO ORIGINAL DISK LINUX UBUNTU...
You can get a manual here:
http://www.biostar.com.tw/app/en/mb/content.php?S_ID=450
Did you set the boot sequense in your bios ??
First your CD or DVD drive
Second you harddrive.
Harddrive must be in sata 0.
CD or DVD must be in sata 1.
Or look in the manual how the settings should be.
Good luck.
Feb 27, 2011 | Biostar A770E3 AM3 AMD 770 ATX AMD...
Rebuilding my computer, won't load past ''press f11 for bbs popup''
Has the motherboard got a new BIOS battery?
Check the voltage of the battery, if it is a lithium battery CR2032 then the voltage should be 3 volts, if it is less than 2.98 volts then replace the battery.
Feb 17, 2010 | EliteGroup ECS Socket AM2+/ GeForce 8200/...
Trying to upgrade a Compaq SR1020NX computer. The HP website still has old info, likely based on the original bios. The motherboard is an Asus A8M2N-LA. What CPU upgrades will run on that board? Is there...
The ASUS A8M2N-LA is the motherboard used by HP for the new D4500e AMD AM2 PC.
Here are the details:
Motherboard manufacturer's name: ASUS A8M2N-LA
HP/Compaq name: Nodus-GL8E
CPU/Processor  Socket: AM2 Supports AMD Athlon 64, Athlon 64 X2, and Sempron processors
Front-side bus (FSB)  2000 MegaTransfers/second
Chipset  GeForce 6150 LE chipset
BIOS features  Award brand system BIOS Keyboard combination to used to enter BIOS: F1
Form factor  Micro-ATX: 9.6 in X 9.6 in
Memory  Four 240-pin DDR2 DIMM sockets, Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs, non-ECC memory only, unbuffered Maximum HP/Compaq approved memory is 4 GB*
PS - as you can see the rangeis 533 - 667 MHz. I would suggest you call HP support and ask if it will support 800 MHz,
Feb 15, 2010 | AMD Athlon 64 X2 5400+ Processor...
Cpu update
basing from MSI website cpu support for this mobo,
the best AMD processor you can fit on this mobo is
ATHLONXP 3200+.
Barton (0.13u) 200/400MHz FSB 512KB L2 Cache AthlonXP 3000+ 200 Auto OK AthlonXP 3200+ 200 Auto OK
http://global.msi.com.tw/index.php?func=prodcpusupport&prod_no=592&maincat_no=1#menu
Oct 13, 2008 | Intel Motherboard
New processor and memory - how to configure SETUP???
you need to update (flash) your bios to recognize the new cpu. check with your motherboard's manufacturer for a bios update.
May 13, 2008 | MSI KT4 Ultra-SR Socket...
Micro star mainboard ms-6163
Hi
MS-6163 Pro Systemboard IDE controller utilises Intel 82371EB PCI Chipset and supports up to Ultra DMA 33 operation mode.
MS-6163 Pro - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=340&maincat_no=1
**** Other MS-6163 ****
MS-6163FC Systemboard IDE controller utilises Intel 82371EB PCI Chipset and supports Ultra DMA DMA 33/66 operation modes.
MS-6163FC - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=341&maincat_no=1
MS-6163VA - Systemboard IDE controller utilises VIA VT82C596B Chipset and supports Ultra DMA DMA 33/66 operation modes.
MS-6163VA - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=342&maincat_no=1
MS-BX Master Systemboard IDE controller utilises Intel 82371EB PCI Chipset and supports Ultra DMA DMA 33/66 operation modes.
MS-BX Master - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=319&maincat_no=1
Regards
Mike
Mar 27, 2008 | MSI MS-6163 Pro Motherboard
I tried to overclock it
Doesnt sound good - When you said you reset the bios that meant you reset the CMOS jumper on the mainboard?
If that doesnt do it then i would try just one stick of ram at a time.
You may even have burned up the CPU trying to overclock it so far. If you could find another athlon xp then i would try that last.
If that isnt practical then it is likely the mainboard is shot.
It would probably be best at that point to use this as an excuse to upgrade to a newer platform - an athlon x2 5600 with mainboard and RAM is only about $200-$250 depending on the combo you get. Keep in mind most newer boards will use PCI Express instead of AGP video cards.
Dec 20, 2007 | MSI K7N2 (MS-6570) Motherboard
Computers & Internet Logo
114 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
