Question about Homelite Mighty Lite Lawn Trimmer
Gas mix for homelite trim n edge ut20779 - Homelite Mighty Lite Lawn Trimmer
4 Suggested Answers
panilling9
  • 284 Answers
SOURCE: Just plain gas or a mix in my Homelite 25cc zip start gas trimmer
you will have to mix oil and gas in a one gallon container
your ratio will be 40:1 that is 3.2oz of oil to one gallon of gas
you will need two cycle oil as some are pre bottled at this amount and some you have to measure as some dispensers have markings for you.
Do NOT USE MOTOR OIL OR OUTBOARD MOTOR OIL.
I would use 89 octane mid grade especially if fuel will be sitting.
Look for the 2 cycle oil that contains a fuel stabilizer in it if possible if not thats fine.
Dont want to throw you off but some will say you can use a 50:1 mix---2.6 oz to 1gallon
if you can find the SYNTHETIC type 2 cycle oil this would be your alternative and would be ok to use also.
Posted on Jun 15, 2009
SOURCE: homelite trim n'edge owners manual for ut20933
1 gal gas to 2.6 oz of Homelite Oil per OM.
Posted on May 31, 2010
  • 21 Answers
SOURCE: what is the fuel oil mixture for a homelite gas
FUELING AND REFUELING THE TRIMMER
FUEL MIXTURE
This product is powered by a 2-cycle engine and requires pre-mixing gasoline and 2-cycle oil. Pre-mix unleaded gasoline and 2-cycle engine oil in a clean 1 gallon container approved for gasoline.
Recommended fuel: This engine is certified to operate on unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mix oil with gasoline according to the instructions on the package. If Premium Exact Mix oil is not available, use a high quality 2-cycle engine oil, mixed at 2.6 oz. per gallon (US).
Do not use automotive oil or 2-cycle outboard oil.
NOTE: Premium Exact Mix fuel mix will stay fresh up to 30 days. DO NOT mix quantities larger than usable in a 30 day period.
PREMIUM EXACT MIX (50:1)
GASOLINE OIL
1 gallon (US) 2.6 oz.
1 Liter 20 cc (20 ml)
Posted on Jul 11, 2010
What is gas m ratio fr 25cc weer
Hello there
Download here friend.
http://manuals.homelite.com/system/files/4262/original/UT40502_UT40903_041_eng.pdf?2011
Page 8 of the Homelite user Manual gives you the EXACT ratio.
FUEL MIXTURE
'This product is powered by a 2-cycle engine and requires
pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded
gasoline and 2-cycle engine lubricant in a clean 1 gallon
Recommended fuel:
Mix Homelite Premium Exact Mixlubricant with gasolineaccording to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US)'
Sep 12, 2014 | Homelite Garden
I just purchase a homelite leafblower ut 09510 175mph, do i need to mix oil and gas for fuel?
Yes, you will need to mix up some fuel with two cycle oil. See your owners manual for the proper mix ratio. Keep this fuel in separate container from your lawn mower gas.
Sep 04, 2011 | Homelite Garden
I have a Homelite UT20702 trimmer, a 25 cc engine. What is the gas/oil mixture supposed to be. Lost manual.
Mix Homelite Premium Exact Mix oil with gasoline according to the instructions on the package. If Premium Exact Mix oil is not available, use a high quality 2-cycle engine oil, mixed at 2.6 oz. per gallon (US). Do not use automotive oil or 2-cycle outboard oil
Here is link to owners manual too
http://www.homelite.com/system/manuals/stringtrimmers/ut20763_20778_20779_eng.pdf
Hope this helps
Please rate FIXYA
Jun 25, 2011 | Homelite Garden
Need gas/oil mix for Homelite 330 10604A, HJ
To the best of my recollection the 330 is an older model saw and should be running about a 16:1 ratio. 8oz. of oil to 1 gallon of fuel. Hope this helps.
Note: You're always better being a bit richer (lower ratio) than you are leaner (higher ratio).
Feb 20, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
I have recently obtained a Homelite "zip start" trim n edge string trimmer. What fuel mixture is recommended for it?
Modern Homelite equipment uses a 50;1 fuel mixture. That is 2.6 ounces of 2 cycle mix to 1 gallon (U.S.) of gasoline. I highly recommend to use a quality 2 cycle oil that is designed for lawn equipment. I also recommend to use a mix that contains fuel stabilizer. This will usually be in a 3.2 ounce bottle.
Always use fresh fuel, it prevents problems in your equipment.
Nov 29, 2010 | Homelite Consumer Products MightyLite...
Need to know gas mixture
Yours is not a current model and I did not find a manual. The following is an excerpt from a 26cc MightyLite Blower/Vac UT08550/UT08951 "Operator's Manual":
This product is powered by a 2-cycle engine and requires pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded gasoline and 2-cycle engine lubricant in a clean 1 gallon container approved for gasoline.
Mix Homelite Premium Exact Mix lubricant with gasoline according to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US).
Do not use automotive lubricant or 2-cycle outboard lubricant.
GasolineLubricant
If properly adjusted your blower will operate fine on 50:1 regardles of what the manual reads. HTH
Lou
Jan 29, 2010 | Homelite Consumer Products Backpack...
What is the gas and oil spec for Homelite Edge/Treamer and were can I find the online manual - UT20930
50:1 mixture. Trimlite, Trim 'n Edge, and EasyReach models.
Unleaded gasoline. Mix Homelite Premium Exact Mix oil with gasoline according to the instructions on the package. If Premium Exact Mix oil is not available, use a high quality 2-cycle engine oil, mixed at 2.6 oz. per gallon (US). Do not use automotive oil or 2-cycle outboard oil.
Homelite manuals are quite hard to find. I'm sorry that I can't help you with that.
Oct 11, 2009 | Homelite Garden
What is the fuel oil mixture for a homelite gas trimmer model ut20779
Hi a safe fuel mix is 25:1 but most homelites run a mix of 32:1 either one should be ok
Jul 03, 2009 | Garden
Jun 15, 2009 | Homelite Garden
Homelite Mighty Lite Lawn Trimmer  Logo
542 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
