Question about Kenmore Elite 45986 Front Load Washer
The digital readout is showing f 11 - Kenmore Elite 45986 Front Load Washer
    President:
  • 1,382 Answers
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08.
Thank you !!
Posted on Jul 30, 2010
I have a Lincoln 305g with digital readout and the amperage readout is fluctuating wildly but is not effecting amperage to the stinger,is it possibly just the digital readout that needs replacing?
Most likely the coil that is sensing output at the lead terminals. Check it with a hand held Amprobe (digital) to see if out put is stable at the leads.
May 15, 2017 | Lincoln Cars & Trucks
On model PLEF398DCH Frigidaire Professional Series electric range, my digital readout for the right side burners works fine. My left side digital readout is inoperative, but the burners work fine. Is there...
Good Afternoon Lee,
I understand that the left hand side digital readout is not working on your Frigidaire range, model# PLEF398DCH. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Once you restore power, you will need to set the clock and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 27, 2014 | Frigidaire Kitchen Ranges
5PK shows up in digital readout
check safety circuit ans gas pressure and ignitor if ok pressure switch
Aug 29, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Digital readout not readable
Try a new one. If it works, the scale is broken.
Jun 30, 2010 | Taylor Precision Products Taylor Precision...
No mileage showing digital readout thanks
It is registering, but the light is burned out. You can probably use a flashlight on it and see a faint glow of numbers, but you just need a new bulb. Your radio is probably only half lit on the readout, too. Common problem with Pontiac sunfires. Dashbulbs. Cheap fix, but time consuming.
Nov 17, 2009 | 2001 Pontiac Sunfire
The numbers on the digital readout are partly
If the display is showing "partial digits" on the display, it means a scale is excessively shaken (sometimes during shipping) it's possible for the LCD to become partially separated from the PCB (Printed Circuit Board). On many models you can gently press on the LCD and it will reconnect. However on many scales it's difficult to reach the LCD (without removing the cover) and thus the scale will often have to be returned to the manufacturer for repair. Contact them at 1-800-326-6247 for the Conair appliance customer service center.
Sep 09, 2009 | Salter 9007 Glass Lithium Digital Scale
Watts
The MRD-M300 has speaker-level inputs so you can easily use it with any car stereo. Hook it up and hear what good bass can sound like!
Details:
  • 150 watts RMS x 1 at 4 ohms
  • 300 watts RMS x 1 at 2 ohms
  • MOSFET power supply and output stage
  • STAR Topology for cleaner sound
  • Bass Engine® features:
    • low-pass digital crossover, 30-200 Hz, 24 dB/octave
    • variable subsonic filter (15-50 Hz in 5 Hz steps)
    • parametric EQ variable from 30-160 Hz
    • Bass Compensator enhances low-end definition
  • top-mounted digital control center with cover
  • time correction 0-10 milliseconds in 0.5ms steps
  • phase correction 0-180° selectable
  • digital readout
  • detachable front cover
  • blue power LED
  • delayed turn-on
  • requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
  • speaker- and preamp-level inputs
  • gold-plated terminals
  • 8-5/16"W x 2-11/16"H x 11-1/2"D (10"D without front cover)
  • 1-year warranty
May 29, 2009 | Alpine MRD-M300 Car Audio Amplifier
Sharp SPC344
You might need new batteries in the indoor readout unit, even though it appears to work normally. I just had the same problem and this fixed it. I know this is 2 year old problem but this might help someone else. Len 8-7-11
Mar 10, 2009 | HTC Touch P3452 Smartphone
My ge humidifer AHH140LK61 is showing a "P1" readout
Unit is defrosting – Allow the unit time
to automatically defrost. The error will
clear after the unit self defrosts.
Dec 02, 2008 | General Electric AHK30LK Humidifier
Kenmore Elite 45986 Front Load Washer Logo
138 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
