Question about Whynter FX-6SB Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D
DO YOU HAVE AMSTAR water dispenser Model YLR 2.0
DO YOU HAVE
1- AMSTAR water dispenser Model YLR 2.0 -5 (BY 92 ) WITH FRIDGE
2- AMSTAR water dispenser Model YLR 2.0-5 (BYZ 93) WITH FRIDGE
IF YES PLEASE GIVE ME THE PRICE FOR 1 CONT 20FT AT C&F DUBAI
2 Suggested Answers
SOURCE: need a handle for the hot water on a YLR-5-87H3 WATER DISPENSER
My water cooler was made for Sunbeam by Prestige Home Comfort of Canada. 1-877-383-6399 Mon thru Fri 8:30 am - 5:30 PM ET to order parts or service@limagehomeproducts.com to contact
Posted on May 30, 2009
Fisher & Paykel fridge the water dispenser on the front of fridge is locked how do you unlock it.?
Hello Patti Emelson,
Let's say... (for example)
Your model number is E522BLXU...
on that model... (Fisher & Paykel)
Page 10 of those
instructions
says of manualslib.com (URL link below)
Dispense LOCK
This mode disables the water dispensing pad & prevents water
from being dispensed.
To activate this mode, press the MENU and MEASURED FILL
keys together for two (2) seconds...
Of course the precise buttons could vary... WHICH is why
putting in TOUR MODEL NUMBER is important for
such questions ...
Reference
Fisher Paykel E522BLXU Service Manual Dispenser Lock Key Presses measured...
Hope this helps
Carnac the Magnificent
Oct 21, 2017 | Fisher Refrigerators
Sunbeam hot/cold water dispenser is leaking from looks like copper tubing that goes to tank. Model # ylr-5-87h3 what could my problem be
Broken solder connection.
Continual expansion and contraction of metal due to hot and cold extremes will cause metal fatigue. The most vulnerable place is at the join. Other places can fail, but usually the solder join will fail first.
Buy another one and support economy.
Make sure next unit is connected to cold water line, and not hot water line. If hot water dispenser is connected to Hot line, then it will cause water heater to run each time water is drawn through dispenser because cold water immediately enters tank.
http://waterheatertimer.org/Water-heater-dip-tube.html
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html#h-c
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#pot
You might also consider installing small tank under counter. Tanks are less glamorous than hot water dispensers but tanks are more reliable long term than instantaneous water heaters.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 28, 2013 | Water Heaters
GE Profile PFSS5NJWA SS water dispenser not dispensing water. I tried changing the filter, but it still does not work. I also tried pressing the "reset filter" button. When I press the water...
We have the same model and just had exactly the same problem. The coil behind the fresh produce trays is frozen. There are 2 coils, one provides water for the water dispenser and the other to the ice maker. Looking into the fridge the water dispenser coil is on the right hand side. We unplugged the fridge for a couple of hours and the problem has been solved. Try increasing the temperature of your fridge by a degree or two.
Feb 17, 2011 | General Electric PFSS5NJXSS Stainless...
Water leaks from dispenser
Bad water filter or weak water inlet solenoid. Water line to back of fridge goes to inlet solenoid valve. Check it first. Would help to know the manufacture date. If it has a filter at bottom of fridge it will cause leaks and low pressure to dispenser if not changed each year.
Sep 11, 2009 | Refrigerators
Need a handle for the hot water on a YLR-5-87H3 WATER DISPENSER
Feb 19, 2009 | Whynter FX-6SB Free Standing Hot & Cold...
Ge fridge makes Ice, doesn't dispense
turn freezer side to zero for 1 minute. press water dispenser
Jan 26, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Sunbeam Model YLR2-5-90HZ3 hot/cold water dispenser w fridge
HOW CAN I REPLACE THE PART MINE IS DRIPPING WATER CONSTANTLY.
Oct 05, 2008 | Whynter FX-6SB Free Standing Hot & Cold...
Whynter FX-6SB Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D Logo
71 people viewed this question
Top Whynter Water Filters & Coolers Experts
Tom Chichester
Are you a Whynter Water Filter and Cooler Expert? Answer questions, earn points and help others
