Question about Kitchen Ranges
I need the test sequence for this dishwasher to clear memory or test each component. Stuck on 1 minute and won't move.
  • 4,323 Answers
Hi
Please tell me the make and model number of your dishwasher. Also describe in brief about the issue. Please post back for further assistance.
Daniel
Posted on Jul 30, 2010
  • benderdome Jul 30, 2010
    Sorry - - Gaggeneau M#GM915-710 S#SHUGGEIUC/U12
  • Daniel Scott
    Daniel Scott Jul 30, 2010
    Hi
    To reset it press the intensive and crystal buttons @ the same time, the display will change to 0. Close the door the pump will run for a while when the pump stops the dishwasher is reset.
    Please post back for any further assistance. If you are satisfied please do accept the solution.
    Daniel
Our ken ore elite dishwasher 66513423k701 clean button flashes 6 times pauses and flashes once. We did have a problem with the dishwasher dumping water all the floor and discovered the discharge pump was...
It sounds like you just need to reset the controller. This is done by running (or partially running) a diagnostic cycle, which will clear the error. Here's how to do it: Depending on the model, and the keys you have, press the following sequence of keys quickly (with less that 1 second between key presses:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
You will know that you have entered the diagnostic cycle when all the lights light up. Let it run for a few minutes, and then press Cancel to stop the diagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jan 18, 2015 | Kenmore Dishwashers
My Maytag MDB6160AWW finished its last cycle with a blinking "clean" light. I didn't think much of it. And somehow cleared the lights. When I filled it up and wanted to start a wash it will light up,
Blinking clean light is an error code does it blink 7 time pause then repeat that would be a heat circuit problem fast blinking a stuck key behind the lower panel should be a tech sheet explaining how to determine what the code is
Dec 24, 2014 | Maytag Dishwashers
Need reset sequence for dishwasher
see this causes, use the common sense.God bless you
Dishwasher Stuck in a Cycle If your Dishwasher is stuck in a cycle check the following
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer / electronic control.
Sep 19, 2012 | Whirlpool DU1055XTS Built-in Dishwasher
How to clear code 118 and 224 on 1994 ranger
Ford Ranger/Explorer/Mountaineer 1991-1999
Clearing Codes
Print
CONTINUOUS MEMORY CODES
These codes are retained in memory for 40 warm-up cycles. To clear the codes for the purposes of testing or confirming repair, perform the code reading procedure. When the fault codes begin to be displayed, de-activate the test by either disconnecting the jumper wire (meter, MIL or message center) or releasing the test button on the hand scanner. Stopping the test during code transmission will erase the Continuous Memory. Do not disconnect the negative battery cable to clear these codes; the Keep Alive memory will be cleared and a new code, 19, will be stored for loss of PCM power.
KEEP ALIVE MEMORY
The Keep Alive Memory (KAM) contains the adaptive factors used by the processor to compensate for component tolerances and wear. It should not be routinely cleared during diagnosis. If an emissions related part is replaced during repair, the KAM must be cleared. Failure to clear the KAM may cause severe driveability problems since the correction factor for the old component will be applied to the new component.
To clear the Keep Alive Memory, disconnect the negative battery cable for at least 5 minutes. After the memory is cleared and the battery reconnected, the vehicle must be driven at least 10 miles so that the processor may relearn the needed correction factors. The distance to be driven depends on the engine and vehicle, but all drives should include steady-throttle cruise on open roads. Certain driveability problems may be noted during the drive because the adaptive factors are not yet functioning
Jun 03, 2012 | 1994 Ford Ranger Supercab
My ferguson f2620lvd2 tv DVD combi set will not stop playing DVD after approx 1 minute
I assume you've already done a power off, and then an unplug power off. This really does reset memory at the component level, clearing fragmentation or stuck memory bits.
Jan 15, 2012 | Televison & Video
My Kitchen Aid dishwasher, model KUDK03FTSS3, is stuck in a loop of some sort. It starts, but freezes after a few minutes. Does anyone know the reset key sequence to make this go away? Kitchen Aid customer...
Hi. Pressing and holding the cancel button may reset the unit at this time,as well as, pulling the ac plug out of the wall outlet for five minutes. With that said, I will provide the proper reset sequence below. 1. Open the door of the unit slightly. 2. Within three seconds, press the following sequence in this order-high temp scrub,energy saver dry,high temp scrub,energy saver dry. 3. After the sequence, close the unit door and latch it. 4. After the door is closed, press the cancel button. This will reset the main control, unless there is major damage to the circuitry of the control board.
Oct 13, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Cant get dishwasher to run and it is stuck on heat dry
Hi, iIt sounds like it needs to be rebooted, like a computer. Shut off the breaker for a few seconds and reset it. If it has a digital panel there is normally a button pushing sequence you push to clear out it's memory and get it back to square one. If you can't find the sequence in your manual, call the CS number and ask them how to clear the digital panel memory.
Jun 11, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
K-more elite dishwasher stuck in sensing mode; won't move to wash
Where did you find the sequence to clear the flashing clean light?
Apr 14, 2009 | Kenmore Dishwashers
Kitchenaid dishwasher kudi24sewhi stops after filling
Hi canchild,
By your description this sounds as though the machine control board has failed. But you should test it first.
Go to Home Depot or Lowe's and pick up a non-contact voltage tester, like this one. It's a tool that you'll use more often than you think for this project and others around the home,
WARNING---> THESE TESTS REQUIRE YOU TO HAVE POWER ON! AVOID ANY EXPOSED WIRING OR ELECTRICAL TERMINALS THROUGHOUT THE TEST PHASE!!!
Now remove the 4 screws holding the kick panel to access the lower section of your dishwasher. Set the dishwasher to run a normal load and start it.
The sequence is the washer will send power to the water valve first, test this with your new tool... it should light up if the tub is empty. If it's already full, power will not be applied to the valve. When the tub is full, the board will send power to the main wash motor in about 1-2 minutes. Use your Voltstick on the main motor harness. If the board is good, your stick will light up.
Now hit "Cancel"... this should activate the drain pump (it's on the right, connected to the pump sump and has 2 wires feeding it). Again, test with the Voltstick.
NOTE---> Your Voltstick may give you false positives... avoid this by singling out individual wires to test. DON'T TEST "WIRE BUNDLES".
These tests will confirm whether or not the board is sending power to the components in question. If you have power? The components have failed OR the wiring to the components have become loose, broken or disconnected.
If you aren't getting power to the components, your board has failed and will need a replacement. The part number for it is 9743448 and lists for about $160.
Hope this helps!
SG
Apr 05, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool gold dishwasher gets stuck at 53 minutes left for an hour
Try "resetting" the control board by running the diagnostic cycle. The cycle completes in 15 minutes.
The details are in the service manual. The manual can be found hidden behind the tow plate (at the very bottom front of the washer).
The diagnostic cycle may tell you the problem. It also helps clear up some of the software gltiches.
It is easy to run the diagnostic cycle.
Just the buttons in the following sequence. The sequence should be complete within 6 sec.
heated dry -> Normal -> heated dry -> Normal
This will trigger diagnostic cycle of 19 intervals. Pay special attention to the intervals 18, 17, 9, 6, 4.
Interval 18 - displays your controller module number (should be letter 'd' followed by number 0 or 1 or 2 or something. Note that down for future reference.
Interval 17 displays 'software generation number' Note that down for future reference.
Then wait until you reach interval 9.  --- clean LED turns on - then an open or shorted thermister is detected.
-- Sanitized LED turns on - then the washer detected greater than 100 deg F temperature
Interval 7
-- Soaking/sensing LED should NOT come on (unless food soil is present).
Interval 4 -- Soaking/sensing LED should come on
Let the cycle complete and then try running the normal wash. Hopefully the possible glitches are cleared by now and you should have no problem.
If this doesn't work, time to call the expert tech.
Nov 08, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Kitchen Ranges Logo
20 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
