Dear Sir/Madam I have installed Easy Capture USB 2.0. on both my notebook and computer. Both work well wth the capture but the only problem I have is that it is using too much space. On average it is using 32 GB per 25 minutes or 1 gig per 11/2 minutes with the result I run out of space. I am sure it is a software problem but cant seem to fix. Could you please advise what I must try. I have available space on my laptop of 32 gig and on my desktop 52 gig. Many thanks Peter Butlion
  • 127 Answers
Best advice would be to get a large external hardrive you can get 1 terrabyte for about £60.00
Posted on Jul 30, 2010
Tip
For better video quality with EasyCap USB video capture card:
1. Install FFDShow codecs to Your Windows: http://adf.ly/1310198/ffdshow-codecs
2. Use gold plated cables and adapters - s-video is normally a little bit better than composite
3. Check that all contacts between devices, cables and adapters are tight enough
4. Do not use any extension USB cable - put EasyCap/EzCAP straight to the computer's USB port
5. Switch off all other programs during capturing
6. Capture with max resolution 720x576px PAL, 720x480px NTSC.
7. You must have a powerful computer - check that CPU Usage is under 50% during
capturing and if it goes over, so buy more RAM and/or better processor and/or
better graphic card and/or faster hard drive.
on Mar 13, 2014 | DekCell EasyCap USB 20 Video Capture...
My svid2usb22 cable doesnt recognise anything i connect to it...Am i doing something wrong
1- Install the software that it came with the USB Video Capture
this usb capture does not need special drivers because is just receiving video and audio and is not converting any format.
2- you must have a software to record the image and video that it comes from the USB Video Capture and have to be open at the time you start transmitting.
you can use roxio video capture or more pro like adobe premiere you may find free online capture software for this device but for sure this device should have his own software. I hope this answer work for you if not please add more details to posted question.
Thanks Good luck!
Mar 26, 2011 | StarTech.com Startech USB VIDEO CAPTURE...
How can i use my web cam of oy lenovo g460. is there any software required?
Hi mbisht19,
Based on your concern, I suggest trying the following steps:
1. Make sure that the updated driver has been installed on your computer.
--> you can download it here:
--> go to camera section and make sure you download the driver that matches your operating system.
2. After downloading, install the driver then restart your computer.
3. Log back in then try pressing the FN+ESC to activate the camera.
4. Now try to use easy capture to check if the camera is working.
--> easy capture is a preloaded application in your system.
--> if you cant find easy capture, you can download it here:
--> go to software section.
--> again make sure that you download the application that matches your operating system.
5. repeat step 2 and 3 then open the easy capture.
Hope it helps,
Thank you for using FixYa.
Sep 29, 2010 | IBM LENOVO VIDEO ADAPTER-G450 32MB 22P6640...
VHS to Easy capture to computer
The plugs you speak of are called RCA plugs, (Male side has an outside ring with "slots" around the edge, and a pin in the center. Female side has a short round "riser" with a hole in it). You need just standard Audio/Video hookup cables, available at any electronics store.. Walmart/Target/Kmart has them in the TV section. They get plugged into the Audio (Red & White) OUT of the VCR, into the Audio IN (Red & White) of the Easy Capture. The Yellow lead is for Video In/Out between the VCR and Easy Capture. The black is probably the S-Video connector, (round, has very small square hole, surronded by 4, 5, or 7 tiny pin holes) that can be also used to connect video/audio between VCR(if so equipped) and Easy Capture. Get a set of audio/video dubbing cables (abt $10 usually), connect Red to Red, White to White, Yellow to Yellow. Plug the Easy Capture USB cable into your computer (most likely), start the capture program. Start your vcr, hit Play. You should see your vcr tape playing on the computer screen.
Aug 18, 2009 | Televison & Video
Easy capture
Syd...I'm not sure what exactly your looking for...so I found this site for a free download...as far as i can tell i did not install it ..obviously...but anyway
http://www.tucows.com/preview/502111
And if you want to pay for the software
http://www.filesland.com/download/easy-capture.html
interestingly they have the Easy Capture and Thumbnail software (that I gave you the link to up above) for $19.95.
Hope this helps...good luck...please rate me....The Fang
Mar 24, 2009 | Lenovo 3000 Y410 Notebook
USB webcam is not working...its very urgent
run device manager and uninstalled your usb driver... then restart your computer then install again
Nov 05, 2008 | HP Compaq 6510b Notebook
My webcam show no video capture hardare
sir,
when i install the amcap and run it so a popup window is occured ,that no video capture hardware and video capture will not function properly.plz tell me how i can solve it.thaks
Sep 04, 2008 | A D S HARDWARE, MINI DUAL TV TUNER PTV339...
Web Cam not working
check whether another instance of webcam program is running or not for example say easy capture program. if not then may be you try downlaoding lastest version of yahoo messenger and see whether it work.update your antivirus is must. if problem still persists then do self recovery by pressing recovery buttom but i think u need to back up your data that you store in drive c: after installation update your antivirus. and see whether it works or not.
Jun 20, 2008 | Lenovo IdeaPad Y510 Notebook
Not able to install webcam
Normal 0 Try disconnecting the Camera from the USB port and reinstallthe software program. When the program asks you to connect thecamera to the USB port, do so and it should work.
Hope this helps. Bud
Nov 01, 2007 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
Alun Cox
David Payne
David Payne
