Question about Sony Playstation 3 (PS3) Console
When i turn on the ps3 it shuts back off imediatly flashes blue then yellow then the red light flashes
    Problem Solver:
  • 5 Answers
Power Supply going bad Or RSX chip separating from motherboard Dreaded YLOD yellow light of death Solutions You tube Fix it yourself or send it off to Sony for them to Fix
Posted on Jul 30, 2010
My ps3 turned off during game play and the light flashed blue green yellow and then kept flashing red and if I wait a long time and try again the fan turns on light god blue for one sec then turn a yellow...
I'm afraid you have gotten the Yellow Light of Death ( YLOD ) you will need to have your PS3 repaired by a technician or you can Google YLOD and you will find a repair guide.
May 03, 2012 | Sony Video Game Consoles & Games
PS3 turned off on its on, now won't turn back on
"When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked."
"If this happens:
• Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
• If the PS3 system is in an enclosed area like a bookshelf or entertainment center, move it to a more open area.
• Leave the PS3 system off for 30 minutes to let it cool down.
• If you continue to have issues, you will have to send the system in for service."
Hope this will help...
May 31, 2010 | Sony Playstation 3 (PS3) Console
Ps3 will not turn on properly
You are so lucky to be there. I share a guide for you - It make me like a pro to help my friends and many people. It is too expensive to send back to Sony repair if your machine is out of warranty!
I had solved the PS3 yellow / red lights flashing problems after bought this guide. It's Video and Guides are really catch your eyes and fixed many PS3 issues ! The author of the book is really kind and helpful to his customers. May be you can buy it and share what you have learned !
PS3 Yellow Lights Fixing Guide
May 30, 2010 | Sony Playstation 3 (PS3) Console
My playstation just shut off an the red light flashes
do you get a yellow light? i bet you do..
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work
Send your playstation back to Sony
May 09, 2010 | Sony Playstation 3 (PS3) Console
It wont turn on just flashed red light and wont give the disk back
watch the lights on the front when you try to turn it on. If the blue light flashes yellow for a second, you have ahardware failure, so-called Yellow Light of Death. You can get the disc out by turning off the switch at the back, then hold down the eject button and turn the back button on again.
May 01, 2010 | Sony Playstation 3 (PS3) Console
Playstation turns on for roughly 2 seconds then
Sounds like you have the Yellow Light of Death. This usually occurs when your system gets too hot, and the CPU connection breaks, and no longer connects with the motherboard. Try sending it to CPR in NYC. They do all kinds of repairs with playstations and xboxes and usually get it done within a week.
here is the website www.cpr-nyc.com
hope it helps!
Mar 29, 2010 | Sony Playstation 3 (PS3) Console
Flashing red light
yellow light of death, ring playstation
Mar 02, 2010 | Sony Playstation 3 (PS3) Console
PS3 light turns GREEN, w/ blinkin BLUE, to YELLOW, to flashin RED
it is fried and needs repairs if you break the seal by trying it yourself you void the warrany
Mar 15, 2009 | Sony Playstation 3 40GB System Console
The game system will not turn on.it flashes a yellow light
What model is your PS3? 40 / 60 / 80 etc.
I can help you with this problem or at least give you low down on what's going on.
Mar 03, 2009 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
153 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
