Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
I dropped my Portable WD and I can not read it on my Laptop any more, I get parameter incorrect error, although my Laptop can see the hard drive after a long wait but wont read it. Any idea how to resolve this or any application that I can use to recover my data? please help
  • 11,800 Answers
The hard disk inside it was damaged. The only thing you can do is to take the disk out and put it directly in a working pc. In there you must use a recovery software but if the damage is too great only professional, expensive programs will have a chance of recovering something.
Try this program first
http://www.softpedia.com/get/PORTABLE-SOFTWARE/System/Backup-and-Recovery/Windows-Portable-Applications-Portable-PC-Inspector-File-Recovery.shtml
If it fails that means the damage is severe and pro tools are needed. If you really need that data the best way is to send the disk to a recovery firm, but it will be expensive - over $1k and even they can't guarantee success.
Posted on Jul 30, 2010
  • 2 more comments
  • owa444 Jul 30, 2010
    This is a Portable small WD Hard Drive what do you mean by putting in a working Laptop.
  • Azrael SRL Jul 30, 2010
    That case has in it a laptop hard disk (2.5") . If you take this disk out you can connect it either directly in a laptop and in there run a special recovery system (i think this is beyond your expertise) or, using an adaptor, you can connect it in a desktop. In there it will appear in My Computer just as another disk. Download the recommended program and run it on the disk - if the damage isn't too great the program will recover and save to the other disk almost all your data.
    Is it okay to connect the WD external drive using the USB cable to my laptop as usual before running this program that you suggested?
    Not quite, if the case is also damaged (even in the slightest way) you will not have a single chance of recovering something. You can do something else: you can buy another case, put the disk in it, connect that case to the laptop  and run the program.
    A cheap case  http://www.newegg.com/Product/Product.as...
Cannot read from disk, ask for installation drive
Just to clarify it is asking for the install driver? If so it should be in the portable unless you have reformatted or upgraded your laptop/computer. I went to the WD site and found this page for you. I would recommend that you check the knowledge data base and dicussion board before using any of the downloads. I hope this helps
Sep 02, 2013 | Western Digital Wd Elements Se 1tb...
Dropped my WD portable hard drive and cannot read my files.
You can send it in to WD or a company that specializes in data retrieval from dead hard drives and have them copy off the files for you, but it will cost a furtune to do it.
Sep 02, 2012 | Western Digital Passport Computers &...
External WD 1TB. I cannot retrieve my files it says Parameter is incorrect when that is gone It shows there are no files on my HD and there are plenty of files all psd files as well
I'm sorry to say that this may be due to a corrupt HDD. WD Hard drives tend to die far too fast (I know too well unfortunately).
If this is under warranty, I would call up WD support service for a free replacement.
If you want to take more invasive steps, I will be happy to help you try and recover your files.
Feb 23, 2011 | Western Digital My Book Essential 1TB...
Hi there, I just bought my WD My passport 500gb usb 2.0 last november, it was fine until yesterday when I mistakenly pulled out the cable while it was installing the WD smartware on the laptop, since then...
1 If the warranty is valid> get another drive and install it according to the instruction set. the hassle is better than trying to fix what is broken or defective without the tools to do so.
Feb 12, 2011 | Western Digital My Passport Essential...
My wd hdd fell from my desk, and a few minutes after it dropped i tried it on my compaq laptop and it worked after restarting the laptop, i tried accessing my wd hdd and it gave an error message saying...
WD offers a recovery service, unfortunately that is going to be your cheapest option and that is a long shot and expensive. What happened is the Disk Read/Write arms are no longer in alignment from the impact or have broken free. Because of the need for a clean room environment to work on a HD it is very costly to get these repaired and well out of range for most everyday users.
Nov 26, 2010 | Western Digital WD Passport 250GB Portable...
Wd connected with a usb to laptop, not responding, pls help ,steady white light on
Try it in all the USB sockets available in your laptop. Try it in a desktop computer. Try a different cable.
Sometimes the USB connectors in a laptop are unable to deliver the full current rated in the USB specifications, and the drive can't start.
Also cables sometimes add to the problem, as they have too thin wires causing too much voltage drop.
Jul 08, 2010 | Western Digital WD Passport 250GB Portable...
Turbotax 2008
Hello There, I found this in their FAQ Guide. Hope this resolves your problems, I know it is a bit of a read. Good Luck!!
What is happening?
Double-clicking on a backup, portable company file, or a file with an extension other than .qbw, the following error occurs:
An error occurred when QuickBooks tried to create, open, or use the company file. Please try again. If the problem persists, contact Intuit Technical Support and provide them with the following error codes: (-6150,-1006).
Or, if you attempt to double-click the data file without QuickBooks open, the following error occurs:
There was an unexpected error reported while trying to run QuickBooks with company file "path location". Error code 80070057.
Note: More than one error message that includes the error code 80070057 exists. If this is not the exact wording of your error message please refer to one of these other documents:
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, QBW, NT, or TLG file from a Google Search Timeline
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, NT, or TLG file from a Google Search Timeline
Error: 80070057, the parameter is incorrect. There was an unexpected error reported while trying to run QuickBooks with company file [path and name]
Error: 80070057 the parameter is incorrect" and "You do not have sufficient permissions to delete files...
If your Error 80070057 is different than the ones displayed, perform a new Search.
Why is this happening:
QuickBooks cannot read the company file because the QuickBooks file extension was changed or is the wrong type (.qbm, .qbb, .qbx).
This error can also occur during conversion or creation of a backup or portable company file if QuickBooks detects data damage in the company file.
This error may possibly occur if the QuickBooks installation is damaged.
This error can also be caused by attempting to open the portable company file (.qbm) without having QuickBooks open.
How to fix the problem:
Verify that the file extension displays company name.qbw and not a shortcut.
Copy the company file, change the extension to .qbm, .qbb, or .qbx, and follow the appropriate steps to open a portable file, backup, or accountant's review.
If the error occurs during the conversion or creation of a backup or portable company file, run the Verify utility to check the file for data damage. If it finds damage, run the Rebuild utility.
Repair the QuickBooks installation.
Uninstall, and then reinstall QuickBooks.
Sep 25, 2009 | Microsoft Windows XP Home Edition
Dropped my wd portable hard disk now computer is not reading it
brother
your hard drive has either a crashed head,ir amisalligned head due to dropping it several times. also head stuck to platter is the result of dropping it.and may be the motor of the hard drive has lost its central axis and has got jammed.
if your drive is still spinning i am sure it has head crash problem only.
please try to either get it replaced if its under warrenty.
if you wish to recover data , please pm me.
datarecoveryfactory
Sep 04, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
190 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
