Question about Zebra Printer 140-751-00000
I have a zebra 105SL printer for labels. When trying to use 4 1/2 x 2 inche labels with a wide gap (1/2 inch) between the labels, I get an out of paper message and cannot print. Any ideas as to how to override the out of label message (printing from Loftware)
    Champion:
  • Zebra Expert
  • 285 Answers
Can you run sensor profile, and run manual calibration.
Posted on Nov 13, 2010
Zebra 105sl - printer does not print correct size
This sounds like a mismatch between the printer settings in the print driver and the label settings in your label design software.
In the printer driver - printer preferences- set the physical label dimentions.
Also set the printing defaults to the same settings.
In you design program ensure your label size is the same as the printer driver and also you can set the print preferences in the same program, ensure they all match and hey presto it works. But if nt then contact www,lancerlabels.co.uk, they will talk you through the problem on the phone. They will not charge for the advice.
Mar 17, 2013 | Zebra 105SL Thermal Label Printer
I CANT PRINT THE CORRECT SIZE
Hi!
fixed the 203 dpi new head in zebra 105sl printer then 1 week print is correct size to 4x6 inches label but after 15 days its not comming full page print.
pls help to get soultion
thanks / Khokan
Jul 15, 2012 | Office Equipment & Supplies
Zebra 105sl felt paper error
check if the sensors behind the printhead (small metal open case)is on the same position that the uper sensor(black plastic bit with the screw behind the printhead) Run the sensor profile, check if he check the gap.
run manual calibration from the settings.
worst case senario, Reset the printer to Factory defult (Press PAUSE and CANCEL buttons and tun printer on, then relese the butons after 5 secounds.
Jul 06, 2010 | Zebra 105SL Thermal Label Printer
Zebra 105SL print only half of label
This can happen if your page size in your driver is not set to the actual label size. It can happen if you have old .dll driver files mixed with your mew driver installation.
This is what I would do:
Uninstall the driver completely - delete the icon in Printers and Faxes. Drop down the file menu there and choose server properties and remove the driver for all Zebra printers from the Drivers tab. Go into the LCD menu of the printer and load defaults. Go back into the LCD meny and look at the page width setting. Your printer has 300 dots per inch, so a 4 inch label would be 1200 dots wide.
Another thing to consider is that you may be trying to printer to a 300 dpi printer from a 203 dpi driver. Make sure that you choose 300dpi when you reinstall. This should work.... If not, repost with more details about your application and driver. I can assure you that this is not a printer problem unless half of your printhead has failed.... unlikely, but possible....
Jan 16, 2010 | Zebra 105Se Thermal Printer
My Zebra Zm 400 keeps saying Pause Error Condition paper out however it is set to Direct Thermal. How do I get it back to the ready state?
make sure that the maximum lenght for the label is set to something greater than the physical length of the label. I was having this issue with a 4x3 label. As soon as I increased the maximum lenght to 5 inches it worked.
Dec 29, 2009 | Zebra 105SL Thermal Label Printer
We are in need of thermal printers and Zebra LP
The LP2844 can only print on Direct Thermal labels.
DT labels have the ink within the label and the labels react to heat. If these labels are to be exposed to direct sunlight they will eventually turn black.
Hint:
If you scrape the label with fingernail you can usually see the black ink on label
The physical size of the labels is this max width 1 inch (MInimum) to 4 inches (Max). Maximum length of label depends on the amount of memory in printer but maximum size for standard LP2844 is 11 inches. With full memory can be 22 inches long.
The labels must be on a 1 inch core.
These printer can handle all label types.
1: die cut Labels - Use gap sensing.*
2: Labels with Black mark on back - Use Black mark*
3: Continuous roll - select continuous *
* Select in printer driver media setting
Use the latest ZDesigner Driver V1.5.10
Download from Zebra Website.
Printer Preferences - Advanced Setup - Media Type.
Dec 02, 2009 | Zebra Eltron TLP 2844 Thermal Label...
Zebra s4m printer can't set up the height to be .375 it goes to .37 are these labels just not compatible?
As long as your printer front panel setup is set to AT LEAST your label height, you should be fine. You set up your EXACT height in your label software page layout.
Set up the printer for 1 inch height, and the gap sensor will work fine. Just make sure your printer driver is also set up for 1 inch, and make your label creator software page layout exact.
Nov 12, 2009 | Zebra S4M Thermal Label Printer
How to stop calibrating soo much?
There is no way to get around the recalibration for different sizes of label, you must do it at every different label height, The callibration only sets the label height/length, so try doing the same length labels in sequence.
Oct 22, 2009 | Zebra 105SL Thermal Label Printer
This can happen if you have the wrong dpi setup. For instance the 105sl can be either 203dpi or 300dpi. If your printhead is 300dpi and the label you create is expecting 203dpi, then you will see shrunken label. Your situation doesn't exactly sound like this is the case but it may be worth checking.
Mar 21, 2008 | Zebra 105SL Thermal Label Printer
Zebra Printer 140-751-00000 Logo
116 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
