Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
The picture doesn't fit on the screen anymore. Someone accidentally pushed the "wega gate" button and I think an adjustment was done but now I can't get it back. The only time the picture fits the screen is when I go to a HD channel. The TV is a Sony Wega Gate 50 inch and about 7 years old.
  • 10,594 Answers
Check button on remote that says Zoom/ Aspect ratio, press it repeatedly to get proper setting of picture in screen.
Posted on Jul 30, 2010
Sony wega gate tv picture and sound going off and on.
Hello, it sounds like it's time to replace the lamp again, but you might check and see if the fan in back of the set is turning first. if the fan is running, replace the lamp....tks
Sep 18, 2014 | Televison & Video
Can someone please tell me how to fix my tv
It looks like its the screen fit, adjustments. You know how you can adjust a computer screen?, well it's the same on a flat screen. Find the menu button and move the picture so it fits the screen. Also try adjusting the resolution. It could also be the convergence. Go to settings, menu and find how to adjust the convergence. Ten make sure the little box on the adjustment screen is in the middle of the tv screen. If its not move it there. Hope these tips help.
Jan 21, 2013 | Televison & Video
How do i adjust picture width on sony KV-21cl10B
Check this link to download the user manual to your Sony TV. It has all details.
Nov 03, 2012 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Color is off,i have a blue tint to screen cy
mcdevito75 here, You should have an AUTO button on your monitor that when pressed or pushed it"ll automatically adjust your monitor picture. If this doesn"t help you can try the menu button to adjust manually.
Jul 07, 2010 | LG 22" FLATRON LCD Monitor
Gate (operated by push button) open by itself
could be picking up a signal that is telling it to open from somewhere else. seems the button just supplies power to it from the way you explained it
Jun 13, 2017 | Gardner Bender #GSW-22 Push Button Switch
Picture is dark
Adjust video settings:
  1. Press Wega Gate
  2. Select Settings
  3. Highlight Video
  4. Press + to select
  5. Adjust/increase the brightness.
  6. Press Wega gate to exit.
If picture is still dark, you need to replace the lamp again. Sony recommends that you replace the lamp:
  1. After approximately 8,000 hours of use.
  2. When the screen becomes dark or the color becomes unusual.
  3. When the lamp indicator on the front of the TV flashes.
Aug 22, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Blue and black vertical lines over the picture
This problem is most likely related to the Optical BLock of the TV. There is a board, called the C board, that does all of the thinking for the optics of the television, and there are tests that can be run to confirm this.
Try pressing the MENU button (or WEGA GATE, HOME) on the remote control. If the menu that pops up has the same lines running through it, then it is definitely the Optical Block. If not, that doesn't rule it out completely. You can try Sony customer support, and they should be able to run you through some tests to confirm the exact cause of the problem.
Hope this helps you...
Jan 05, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Image too big for screen
I have the same tv.
On your remote push menu, then go to settings, and then screen. Put the auto wide to on. And keep the picture mode on normal, not the zoom or wide zoom. If its in HD it will fit the screen. If its not in HD it will crop the sides. This worked for me, hope it works out.
Dec 03, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony FD Trinitron WEGA KV-36HS500 36" TV - Bowed Picture
it sounds like a convergence adjustment problem. If you hava book on the tv still read it, and it will tell you what to do, other wise, look for a convergence button on the front of your tv, and take the remote and push menu to bring up setup, and go convergence adjustment click it and hit the conv. button on the front of the screen. there should be to lines going vertical and horizontal, these are the limes you adjust with your remote, you have to adjust the red and blue, the tv should blink to let you know which color you are on. when you have them lined up right the line will be perfectly white. hope this helps
Jan 31, 2007 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
337 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
