Pellet insert won't start
I have a Lopi Foxfire self ignitor insert. When I push the start button it just sits there and does nothing but have the red light on. If you listen closely you can hear a slight buz or hum, not a fan, then it will start with all the normal sounds and functions after a minute or two or three. Last night it would not start at all, it just makes the slight buz but does not ever do anything. The ignitor is not even getting hot, not auger, not exhaust fan not intake fan. ??
I had the same problem...I'm being told I need to replace the whole circuit board?
Posted on Oct 29, 2008
  • 36 Answers
When was the last time this unit was clean? and has it been clean through the exhausted pipe?
What type of chimney is on this unit?
Are you using a Preminum Pellet?
Fireplacegirl
Posted on Apr 26, 2008
Need a lopi 1998 pellet stove manual. no air comimg out of the fire basket.
hi patty.
this is all i could find.go to this link and see if you can see the manual you are after.
lopi 1998 pellet stove manual Google Search
Nov 03, 2017 | Heating & Cooling
Hopper auger will not stop
How to Repair a Pellet Stove Auger That Won't Turn ' Home ...
homeguides.sfgate.com > Outdoors > General Repair
Cleaning the hopper, removing and replacing the auger and installing a new motor and ... Most pellet stoves do not have a removable auger cover, but you can see a ... youcan hear the motor attempting to spin the auger, turn off the auger and ...
Why wont my Auger feed pellets? ' Hearth.com Forums Home
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves
Jan 6, 2008 - Two #1 reason auger motor will not operate is: PRESSURE ..... Hopperlid trip switches now used on some stove will stop the auger and on the ... Harman Auger will not stop.
Oct 11, 2015
auger won't turn on Lopi Leyden
Oct 14, 2013
harman accentra will not turn off
Dec 31, 2011
Harmon Accentra feeding continually but no ignite
Jan 14, 2008
More results from www.hearth.com
Whitfield pellet stove repair, pellet stove repair, auger re
Jan 10, 2016 | Pool & Spa
Oven won't start
Try pushing the "convection oven" or "bake" button first, then enter the temperature you want. Then "Start".
Sep 24, 2012 | Thermador SC272T Electric Double Oven
Coffee maker turns on but will not brew
why question to all of this is with a "self clean" button, why doesn't it every tell you to clean it..... ??
Sep 07, 2012 | Cuisinart DCC-1200 Coffee Maker
My 1998 hitachi projector tv just randomly turns its self off and no matter how many times I push the power button it won't come on it does nothing no flash no noise no lights but after 15 to 20 mins...
The first thing possible is bad solder connections in the power supply or elsewhere.
Most of these sets with the back off have several green LED lights on the board and a red one.
The red one should be on all the time. What can be done is sit with back off and watch the Green ones--at the moment it shuts off does one go out first or last----each is tied to a voltage source in the set--it will point to where the problem is coming from---ancient self check feature that usually works well.
Another tactic you can use is if when it happens unplug it for a few minutes--I used to hook these to a wall switch so could kill power for a few minutes and try to turn back on--this would indicate a problem in the start up circuit in the power supply.
Tricks of the trade from working on lots of these sets---it would be easy to find if it just did not turn on at all.........
May 29, 2012 | Hitachi Televison & Video
Quadra Fire Pellet stove-will not ignite
I own a Quadrafire pellet stove. I have had this thing for 10 yrs. It seems every year at the start of the season I have some kind of problem. I clean it at the end of the season completely. First couple of burns are fine then get a good cold day and it doesn't work. All the gaskets, the exhaust blower, ignitor, glass front, and exhaust piping have had to be replaced. Now I have a blinking red light in the control box and cannot find anything on line to help. Does anyone know why this red light blinks 3 times every 10 seconds inside the control box? It's not the call for heat light. Think I may change to a wood burning stove to many headaches.
Oct 20, 2011 | Napoleon Auburn Pellet Stove Heater
Oven will not work - Hi/Lo broiler works fine
you have a bad bake ignitor. it is mounted to the long tube in the very back wall of the tube. usually held on by 2 1/4 inch bolts. usually if you replace the ignitor you have to cut the old one off and hard wire the new one in depending on what the new connection on you ignitor look like.
Jan 26, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Pellet stove
The buzzing is possibly your exhaust/combustion blower. This blower is the fan sound you hear as the stove starts up. If you ARE hearing a NORMAL fan sound, then the buzzing could be the auger motor. Do you have a Foxfire with an igniter? This tells me the series of model you have and what control system it uses.
Feb 24, 2008 | Heating & Cooling
Heating & Cooling Logo
183 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
