Question about Dryers
Can you please tell me where the pilot light is on a kenmore 600 series dryer
  • 171 Answers
Pilot lights haven't been used for a while.  now using and ignitor or 'glowbar'
Posted on Jul 30, 2010
Is there a pilot light on a Kenmore 600 gas dryer? If so how do you light it?
Check the owner manual. If you do not have it, search the internet for it. Most manuals are online now.
Jun 01, 2015 | Kenmore Dryers
How to light pilot for Kenmore 70 series Gas dryer
In order for us to provide you accurate information and supply you with the correct manufactures part numbers , we will need the complete model number, serial number and batch or series numbers (if applicable) found on a business card size metal/foil plate. If you are having difficulty locating this identification label, follow this link which will take you to our Website where we have pictures of common locations where your model number ID label can be found. Here is the link: http://www.affordableappliance.com/Tips/modelnumbers.htm Once you have the updated information, please reply to this email. Eric Campion
May 21, 2014 | Kenmore 73952 Gas Dryer
Kenmore 90 series gas dryer no heat
The gas ignitor most likley is not functioning. They do not have a pilot light like appliances in the oold days. They must ignite a new flame each use. if you don't smell gas when you try and use, then it is the ignitor and the computerized sensor tells the gas not to turn on because the initial flame has not been created.
Oct 08, 2012 | Kenmore 63942 Dryer
I have an kenmore 600 series clothes dryer. It's about 1.5 years old. The dryer tumbles. gas and electric are on but no heat.
It is most likely the element if it is an electric dryer. If it is a gas dryer be sure that the pilot light is on for the gas at the valve.Also this machine is most likely under warranty so check it out.
I am 90 % sure that is an electric dryer so I would check to see that one of your breakers for the dryer are not tripped as one can run the dryer but it needs two to get the heat running as it runs on 220 volt.
Oct 06, 2010 | Dryers
My Kenmore 60 series gas dryer will not heat up. I checked the lint trap and it is clean. How do I open the front panel to check the pilot light?
Some dryers have a small inspection hole covered by a small platic cap.
Remove cap and look inside unit for pilot. Newer dryers have an igniter that glows when the dryer is turned on. It ignites the gas then goes out.
Jul 30, 2009 | Kenmore 73952 Gas Dryer
Kenmore 90 series propane gas dryer
Hi, You should not have a pilot light, There are electronic ignitors on the dryers. Unless this dryer is 40 years old, just start the dryer and the heat should come on.
If the heat does not work, there must be another issue.
Please let me know if I can help you further.
Thanks
Vic
Jul 21, 2009 | Kenmore 63942 Dryer
Kenmore electric dryer, 600 series, runs but does not heat.
check you're thermostats for continuity, they are normally 3 thermostats, reset stats have a button on them please press, if not thermostat its your heating element
Jun 20, 2009 | Dryers
Kenmore 600 series gas dryer not warm
Make sure the vent is clear and air movement is good through the rear vent.
Ten,
Check and or replace the flame sensor and the gas valve coils.
Mar 11, 2009 | Kenmore 73952 Gas Dryer
How to light the pilot for gas dryer, 90 plus series
Dryers haven't used pilot lights in over 30 years. You have an electronic igniter
Jan 16, 2018 | Kenmore 74602 Gas Dryer
How to light the pilot?
If this is an electric dryer, it doesn't have a pilot either. If this is a gas dryer it will have an electric pilot. but then if it were a gas dryer, it would have a removable lower front panel for servicing the burner. So you must have an electric dryer. if the dryer runs but does not heat, the electric element is most likely at fault. If you really were looking for a pilot light on an electric dryer, I must recommend that you call a reputable appliance service regarding repairs so as to not jeopardize your safety.
Aug 31, 2008 | Kenmore 84052 Dryer
Dryers Logo
79 people viewed this question
Top Dryers Experts
Marvin
Marvin
