Question about Vector 995 Radar Detector
Power cord wiring diagram
Need power cord wiring diagram for plug end for beltronics vector 955
5 Suggested Answers
SOURCE: Beltronics Vector 985
If its still under warrenty Call Beltronics 800-341-2288 I had the same problem and they re-tuned the Detector and updated the firmware my Vector 985 was out of warrenty by 5 months and Bel repaired it for free. Hope this helps
Posted on Aug 06, 2007
SOURCE: Beltronics Vector 995
You may have a voltage issue.Try to reset your detector. Hold the city and bright buttons until it resets. This should solve the message problem.
Posted on Apr 18, 2008
  • 6 Answers
SOURCE: Beltronics Vector 995 does not start
They don't have batteries. :d.
Posted on Nov 08, 2008
  • 134 Answers
SOURCE: No sound on my vector 940
Beltronics is now using a special "high temperature" speaker which resolves issues with speakers blowing due to high ambient temperatures. Contact Beltronics and schedule service for your V940. Not only will Bel replace the speaker with the newer model, but they will also test and calibrate your V940 and install whatever the current firmware is for your V940.
Posted on Jun 26, 2009
Hi, My Bel RX55 PROFESSIONAL SERIES, Will not power up when plugged into power output in my car help please
Unscrew the end of the power plug (the thing that goes into the cigarette lighter/power port of your car). Usually there is a fuse inside. If it is blown, try RadioShack for a replacement fuse. If that does not work, contact Beltronics for a replacement power cord ($150-$20) or other troubleshooting. RadioShack or Crutchfield.com may have a power cord that fits as well.
BelTronics:
toll-free phone 866-468-0322
or www.beltronics.com
Jun 13, 2014 | Vehicle Parts & Accessories
Take apart 955 beltronics
There are 2 screws you need to remove. The first one is in the corner of the base (flip it over and you will see it). The second screw is under the Beltronics sticker on the base, right below the first hyphen in their USA phone number. If you rub your fingernail around that location, you should feel the depression. I didn't remove the sticker, I just stuck my screwdriver over the sticker and unscrewed it through the sticker. Hope this helps.
Mar 28, 2012 | Vector 995 Radar Detector
I lost my cord and would like to make a basic power cord can u send me a diagram that shows the color code on the end that looks like phone wire i have material but i dont know where which wire goes...
on a 4 wired RJ11 or Rj12 Phone plug, it's the middle 2 wires. green and red are your positive and neg. Do a quick touch test to confirm which is pos and neg. only works one way. after confirmed. solder the wires and wrap insulation tape around each and then a couple times over both for strength. the phone wire is prone to breakage.
Apr 23, 2011 | Vector 995 Radar Detector
I bought it at a pawn shop, whenturned on, it says calibrate. How do i do that?
Hold down the "Brt" and "City" buttons as you power the unit on. This will reset the unit to it's default settings. It worked to restore mine to operation.
Dec 01, 2010 | Vector 955 Radar Detector
V955 does not work
Turn the unit off and then, while holding down the City and Brt buttons, turn it back on. This restores the factory default settings. Worked for mine with the exact same problem. Be sure to use the power switch though. If you just unplug the cord and plug it back in, it won't work.
Jul 27, 2008 | Vector 955 Radar Detector
Faulty Buttons
Return to Beltronics for repair. 1-800-341-2288.
Jun 14, 2008 | Vector 955 Radar Detector
Jun 17, 2007 | Vector 985 Radar Detector
Vector 995 Radar Detector Logo
755 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
Steve
Jerry Greenberg
Jerry Greenberg
David Payne
David Payne
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
