Question about Frigidaire FAC124 wall/Window Air Conditioner
220? is this a 220 volt model
  • Frigidaire Master
  • 43,501 Answers
Can I change a model 6224, 220 volt motor to 110 volts so I can move it around with a cord.
No, it is setup for 220 and will burn out the energy if you try.. A 220 v is actually two hot 110 leads and 1 ground built into the plug
Apr 24, 2018 | Cars & Trucks
Is the Hunter portable AC High Effiency Model 31125 to be plugged into a 220 outlet only?
if the plate on the side says 220 volts then it will only work on 220 -250 volts outlet
at a 110 volts outlet it will fail and at anything more than 250 volts it will burn up
Apr 20, 2016 | Hunter Heating & Cooling
What spect of voltage conventer transfer to convent the Voltage 110 to the 220-240 V printer??
110 volt to 220 power converter 220 volt to 110 voltage ...
www.dvdoverseas.com/voltage_converters.htm
110-220 volt voltage converter power transformer 220 volt voltage converters 240 ...run on 120 volt 60 cycles (60hz) and most of the worlds run on 220/240 volt ...
Oct 07, 2015 | Canon F151300 LBP 3100 Mono Laser Printer...
I plugged my 110v KG25H3XWH mixer into a 220v outlet via a voltage transformer and turned it on. It immediately sparked, popped, emitting a burnt smell and tripped the circuit breaker. Is it possible for...
First here is the link to a good suuplier with OEM parts for 110 and 220 volt http://www.appliancezone.com/SearchProducts.aspx?ID=9707627&x=12&y=7
you can change any KA mixer from 110 to 220 and 220 to 110, you need the armature stato phase control board and speed swith for eith conversion, the 220 madel number or 220 model has a letter in front of the ka which is the indicator for 220 volt go to http://www.kitchenaid.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10552&langId=-1&storeId=10202 for a exploded parts list and part numbers look any where for a KA 220 volt model and you can find the same thing
Oct 04, 2013 | KitchenAid Food Mixers
I have a electric dryer Model WED5810SW0 THAT I WAS TOLD I COULD CONVERT TO 120V from 240v is this true and if so how do i do this?
If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU. Before an explanation of how to do it you should keep in mind that this is for a single receptacle only. If any other receptacles are on the same circuit they will also be changed to 240 volt receptacles and if you plug any 120 volt device into them, the 120 volt device will be destroyed. That said OK, any 120 volt outlet can be changed to 240 volt by removing the 120 volt circuits neutral, re identifying the white wire with red or black phase tape and connecting it to a new 2 pole 15 amp breaker. The maximum that this circuit will now load up to is, on #14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be changed to a 15A - 240V receptacle so that 120 volt devices can not be plugged into it. Never use 2 single pole breakers together because code requires that on a fault trip both legs of the 240V circuit must be disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply
Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that convert foreign electricity to power devices from different parts of the world. A step down voltage converter is a 220 to 110 volts converter. A step up converter is a 110 volts to 220 volts converter. Our 2-way converters are voltage transformers that convert power from both 220 to 110 volts and 110 to 220 volts. They also work with 100 volts, 110 volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage converter / voltage transformer available in many different sizes including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000 watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
Sep 07, 2011 | Whirlpool Dryers
GE side by side refrigerator 220 volts. Model #
Hi again,
Yes, 2HP compressor is what suitable for this model of refrigerator sir.
Thank you for visiting FixYa!
May 12, 2011 | GE Refrigerators
Is this a 110 or 220 v dryer
It is EXTREMELY difficult to extract this answer for you without a make, model, and year.
BUT a 220 volt plug is seriously larger than a 110 volt plug, the 220 volt has 4 prongs, the 110 has three.
May 01, 2011 | Dryers
How do I know if my Hotpoint oven 920 years old0 is on a 220 0r 120 line? The serial plate says 120/220.
An oven uses both 120 & 220 -- actually it would be 120 volts and 240 volts or nominally, 110 volt and 220 volt.
The 120 is used for the lights. The 240 is used for the heating elements.
A 240 volt breaker (nominally 220 volt) -- supplies both 120 and 240 volts depending on how the supply is connected to the appliance.
There will be a 240 volt (nominally 220 volt) breaker in the main panel for the oven. This is two 120 volt breakers side-by-side with their toggle switches connected together with a strap across the top of the toggles.
Charlie
Jan 11, 2011 | Hotpoint Ovens
I have a radial arm saw model 113.19790 I have no manual, I can't tell if it is 220 or 110 volts. It runs slow, can you tell me if this model is 220 or 110 volts. Thank You,,,, Denny
Craftsman Radial Arm Saw, model # 113.19790 requires 220 Vac. I purchased my saw brand new and I have yet to have a problem with it beyond typical alignments. My only complaint is with the 5/8" arbor.
Aug 16, 2010 | Craftsman Saws
PS2 110 volts charged to 220 volts
Hello. I think is it is repairable. Please give me the model SCPH..... and I will try to help you. Best regards, Arpi
Apr 08, 2007 | Sony PlayStation 2 (PS2) Console
Frigidaire FAC124 wall/Window Air Conditioner Logo
324 people viewed this question
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
