Question about Everex Computers & Internet
Need repair manual for four year old everex laptop_ power button won't work
  • larsonm639 Jul 30, 2010
    I won't go here again!
    Sergeant:
  • 206 Answers
Http://www.retrevo.com/samples/Everex-manuals.html
Try this link...
Hope you find what you are looking for
Posted on Jul 30, 2010
My LAPTOP EVEREX SA 2052T batery does not charge. The power went off as soon as I take the Power cable. Please advice
Normal 0 If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Oct 09, 2010 | Everex StepNote SA2052T Notebook
Have a Everex stepnote notebook and need to
I have inserted an image of the bottom of your laptop where it says HERE that is the part you have to remove, and I shaded anarea in black that is to indicate the location of a screw that needs to be removed inside. You may have to pull down and push out to remove the drive. It is an easy repair you shouldn't have any trouble.
Jan 13, 2010 | Everex StepNote SA2053T Notebook
Need the power jack for the Everex Everex StepNote
you may want to make sure it is not the power cord first, i thought mine was the power cord, I plugged it up to a different laptop and it worked. so it is something in the laptop..
Nov 03, 2009 | Everex StepNote NC1502 Notebook
Will not power up, no lights or sound
tried to remove battery and ac for a little while?
if that doesnt work, remove battery and ac-power.
remove the ram
put ac-power back and try to boot without ram
(do you get a beep/error?)
remove the ac again
insert the ram
insert battery
insert ac
try to boot up again.
if that doesnt work its probably a mainboard error and you need to take the computer to repair.
May 29, 2009 | Intel Everex LM7WE Notebook
Dark screen, no power ligts at all
try taking out the battery and plug in power, if it works, i suspected it's a battery faulty that needs a replacement.
May 28, 2009 | Everex StepNote NC1500 Notebook
New battery needed!
The Everex SA2052T uses the same battery as a Averatec 2260 (2200 series) laptop. I purchase one from provantage.com this week. The battery is made by BTI and the model number is AV2200. It works perfectly.
Nov 17, 2008 | Everex StepNote SA2050T Notebook
Help me
Witch password???
Bios password???
Everex has a known problem with this model of laptop. It has been known to set its bios password by itself. It is a simple fix, but should be done by a proffesional. There is no charge for this repair at a Everex repair center.
If you want, this is what needs to be done. Remove the piece of plastic above the keyboard. Unscrew the 2 screws in the keyboard and lift the keyboard up( No reason to disconnect it ) Unscrew and remove the modem card in the center. There is 2 solder points c88 on the system board. You need to short those 2 points out while you press the power button on. This will reset the bios password. This should take someone about 5 minutes to do.
If this solved your problem please rate this solution as "Solved" or ask here again in order to find another possible cause
Oct 25, 2007 | Everex StepNote NC1500 Notebook
Computers & Internet Logo
139 people viewed this question
Top Everex Computers & Internet Experts
k24674
Alun Cox
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
