Question about Coffee Makers & Espresso Machines
Mr. Coffee Cafe Frappe will not brew coffee
I have a Mr. Coffee Cafe Frappe and it will no longer brew the coffee. It will blend the ice when I push the ''blend'' button but the coffee does not brew. The power light is blinking red but the ''frappe'' light never comes on. It worked great for a few months. I used it every day and loved it!
SOURCE: my bunn is too slow
Use the de-liming spring to clean the copper tube behind the spray head. Pour several pots of clear white vinegar through the unit to further remove lime and scale from the interior of your coffee maker. My Bunn is 24 years old, and the only replacement parts I've ever required are new carafes and the 4041 silicone washer repair kit.
Posted on Sep 19, 2007
freetek
  • 5568 Answers
SOURCE: mr coffee 072179228578 won't brew
There is a thermal fuse of poor quality in every one of these machines to protect against fire.
If you are unlucky, it fails early and at a safe temperature, if you aren't it may hold forever.
Two years ago, I had three coffeemakers fail in two days; I got a refund instead of a fourth.
Because the parts are spot-welded together, these machines are essentially unrepairable.
If you want to peer inside, look for a cylindrical part about 5/8 " long with one pointed end; this is the thermal fuse.
DON'T consider bypassing it, I know of one counter that caught fire after the thermal switch that controls the heater got stuck.
Posted on Jul 18, 2008
buffalonyman
  • 1865 Answers
SOURCE: Mr. Coffee FTX23 quit brewing
The heating element burned out, its a common problem. Mr. Coffee tend to leak, I've had several of them.
Posted on Jun 10, 2009
  • 186 Answers
SOURCE: my mr. coffee coffee pot won't brew. it will make
Try running a cupfull of vinegar through it followed by a pot of plain water.This will remove any hard water deposits which may be blocking the tubes.
Posted on Nov 05, 2009
rickead1
  • 1998 Answers
SOURCE: This is the first time
yes you should get some kind of power indicated that power is on the machine i would first check the circuit breaker and then assure that you have power coming out of the outlet after which you could then use a multimeter to folow where you do have power going to sometimes it could also be a bad switch on the unit itself but first assure where you do have power going to and any further questions message me back Thanks Rick
Posted on May 19, 2011
How can I turn of the delay system? I just want to be able to brew coffee as needed without the delay system.
When you have set the size mug or carafe you need to mix ahead, setting the Delay Brew is as simple as hitting the "Deferral Brew" button, tap the "H" button the hour and the "M" button to the moment, click which blend you'd like (Classic, Rick, Over-Ice, or Specialty) and afterward hit the "Delay Brew" button once more. Your Ninja will give a little beep to tell you it has you secured and voila! Your morning espresso is prepared!
The 5 Best Rated Coffee Makers in 2016 Appliance Authority
Feb 21, 2016 | Mr. Coffee 12-Cup Programmable Coffeemaker
My Mr Coffee beeps three times when I push the brew button and will not brew
If the carafe, the filter basket, or the water reservoir are not all properly seated, the unit will beep 3 times to let you know it cannot brew until everything is in place.
This happens to me sometimes when I push the button right as I'm putting the carafe in place. I just need to wait a few seconds.
Oct 03, 2013 | Mr. Coffee 072179228578 12 Cup Coffee...
MR COFFEE FTX49. Brewing starts, then stops
Mine just started to do the exact same thing. So I decided to clean it using the "Clean" program and just water. I put the brewer through the cleaning program 3 times - each time it would brew water from 12 cups to 8 cups, I'd tap the brewer on the countertop, it would brew from 8 cups to 4 cups, tap it again, and it would brew the remaining cups. So, I called the Mr. Coffee help line (800-672-6333). The most-likely problem is that the hose is no longer attached in the water reservoir. The help line suggested that I take it in to a service center. I live in Urbana, IL and the closest service center is in Oak Lawn, IL - 2 hours away from me!!
Here is my solution:
1) Buy another coffee brewer.
or
2) Smash your current Mr. Coffee brewer into a million pieces (this relieves stress) and go buy another coffee brewer (probably stay away from Mr. Coffee products).
Hope this helps.
Frustrated in Urbana
Oct 11, 2009 | Mr. Coffee 12-Cup Programmable Coffeemaker
Clean light won't go out, can't use delay brew feature.
Try unplugging it for several minuets & see if it clears it..
Jul 08, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Delay brew will no longer work.
electronics and steam do not mix mr coffee used to put the control boards under the front where it was warm and dry . now there right where the steam can ruin them ... you might try unpluging it and puting it in the sunlight for a day and see if it drys out another thing go to amazon find your model and make a review , this will help others not to make the same mistake you did BTW just so you know , you dont have a real mr coffee , sunbeam bought them a few years back and now its just china junk .... good luck ......please rate this answer if it helped, 3 or 4 stars .and keep me in the paid department . a 1 or 2 will knock me off the air . thanks
Mar 01, 2009 | Mr. Coffee FTX24 12-Cup Coffee Maker
Cleaning ice tea maker
Try to do that
  1. Pour 1 quart (32 oz.) of undiluted white household vinegar into the water reservoir.
  2. Place the pitcher lid on the pitcher. ...
  3. Push the "on" button to begin brewing cycle. ...
  4. Re-plug the cord. ...
  5. When your machine shuts off, unplug the cord, remove the pitcher.
Feb 24, 2009 | Sunbeam Mr. Coffee Iced Tea Maker, TM3PS...
Mr. Coffee won't brew - Mod. #ECX30118
IF YOUR HAVING ISSUES WITH THE ACTUAL BREW OR CLEANING CYCLE AND IT WILL NOT WORK, THERE IS NO TROUBLE SHOOTING THAT CAN BE DONE. MR COFFEE CARRIES A YEAR WARRANTY SO YOU SHOULD CALL THEM TO HAVE THEM REPLACE THE UNIT.
Jan 14, 2009 | Mr. Coffee FTX24 12-Cup Coffee Maker
How to
Fill the pitcher with water to the water level park on the pitcher and pour into water intake in the top of the tea brewer.
Fill pitcher to ice level mark (if there isn't one, put in about 2 - 3 trays).
Make sure that the brew basket lever is closed by pushing in then down.
Put 6 - 10 regular tea bags in brew basket and place brew basket on top of pitcher.
Slide the pitcher with the brew basket under the machine where the water comes out and make sure it is snug. Turn machine on.
When the machine is done brewing, the unit will shut off automatically.
Carefully slide the pitcher away from the machine and release the lever. This will let the tea pour into the pitcher.
That's it! Just don't put the pitcher, lid or brew basket in the dishwasher - that's how I ruined my first one.
Jan 24, 2008 | Mr. Coffee Iced Tea Maker TM1S
Coffee Makers & Espresso Machines Logo
309 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
