Question about Invacare Supply Group Invacare Pronto M91 Electric Wheelchair
One of my residents has a Pronto M91 Sure Step and it turns on, the horn button works, the speed buttons work, but it WILL NOT turn off. Please help me. Would that mean I need to change the joystick controller keypad or the complete joystick controller?
  • 692 Answers
Just replace the keypad or if you are mechanically inclined remove joystick take the top off and glue a small piece of foil to the bottom of the on/off button reassemble and try that if that doesn't fix it order a new pad from a provider in your area
Posted on Aug 17, 2010
Testimonial: "thank you so very much for your help. It is much appreciated. Have a great day."
How do i turn on chair
The ON button is at the top front of the joystick. If this button does not turn on the red, yellow and green lights there are many possibilities as to why it is not turning on. Batteries have to be checked first for proper voltage. Then wiring needs to be checked for proper connections and fuses checked.
Jul 12, 2014 | Invacare Supply Group Invacare Pronto M91...
Put joystick into lock mode
press and hold on button til beep then push and hold joystick til beep then pull and hold joystick til beep turn off then on should be unlocked now
Oct 04, 2012 | Invacare Supply Group Invacare Pronto M91...
Is there fuses in the M91 Pronto Onboard charger
I had this exact same problem after having my M91 in the shop. The repair man said that the onboard charger was bad, so he sold me an offboard charger to charge through the arm. That didn't change anything. I finally took it apart myself and discovered that there was a cord leading from the onboard charger to the batteries that the repair person had left unplugged when he installed my new batteries.
What I'd thought was "fast draining" of the batteries was actually the batteries self-charging overnight (which they will do a little bit if you let them sit). Of course, this might not be your problem, but I'd say at least look at it as a possibility.
Aug 23, 2012 | Invacare Supply Group Invacare Pronto M91...
Batterys charged. I turn switch on. all the lights come on. Joy stick doesn't do anything. Pronto m91 (trulffes@asisna.com)
truffles e-mail me at lennieg2000@yahoo.com. I need to know if you are getting any flashing lights on your joystick and are you hearing the brakes click when you move the joystick. Thanks
Oct 18, 2010 | Invacare Supply Group Invacare Pronto M91...
One red light three green flash when turned on
Your chair has a motor problem. The code does not tell which side it is. Make sure both motors have the brakes in the drive position before turning on the chair. Also check that both motors are plugged into the main control module in the base of the chair.
May 15, 2010 | Invacare Supply Group Invacare Pronto M91...
Can't charge Pronto M91.
Hi Bob. Unfortunately in most cases this means that the batteries have gone so flat that they cannot be “revived”. The best thing to do is take the batteries to a local battery dealer and have them checked. You may need to replace them. Another possibility is that because the batteries are so flat, the charging circuit hit a wobbly trying to resuscitate them and popped a fuse button. A simple reset may help. Happy scooting. Regards Chris… info@mymobility.co.nz
Jun 21, 2009 | Invacare Supply Group Invacare Pronto M91...
Invacare Supply Group Invacare Pronto M91 Electric Wheelchair Logo
270 people viewed this question
Top Invacare Supply Group Health & Beauty Experts
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Marvin
Marvin
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
