On my lg washer that powers off sometimes, localwonder said there was a defect in the pwb[logic sector issues]. Is he talking about the pwb behind the control panel or the green circut board with all the conponets on it?
  • bdeem_45 Jul 30, 2010
    thank you and also localwonder. this was really helpful.
    President:
  • 1,554 Answers
He is talking about the latter, the one located on the left rear side of the cabinet and when the protective cover is removed, it looks something like this:
Posted on Jul 30, 2010
My LG Fuzzy Logic WF-T1022TP let in more water than the level according to the weight of the bundle, sometimes even until the drum overflows. Is there something wrong with the computer?
Try shutting off power to the washer while the machine is filling with water. If the washer continues to fill with water even when it is not getting power, this indicates that the water inlet valve is defective. If the water inlet valve is defective, replace it.
Jul 18, 2017 | LG Washing Machines
I have an LG washer that will not unload water
Washer Won't Drain
1) Check your drain hose to make sure it's not kinked, plugged, or frozen
2) Check that the impeller for the drain pump isn't plugged. It's behind the service door at the bottom left front of the washer. If it's plugged remove the obstruction.
If these solutions don't help you may wish to get an authorized tech in. The other possible causes include a disconnected or damaged connector (the front of the washer must be removed to access its location), a defective Drain Pump Assembly, or a defective Main PWB (system Board) Assembly.
Additionally, diagnosing the last two causes involve significant dis-assembly, multimeter testing while the washer has power, and purchasing expensive parts ( Pump $60US, Board $190US).
Finally, if you live in Canada there's a problem getting replacement parts; LG Canada's policy is to only supply parts to service providers. Additionally, while LG US will sell individuals parts, you would have to get any parts you need shipped to someone in the US who can then forward the parts to your Canadian address.
Jun 29, 2014 | LG WM1814CW Front Load Washer
My lg washer just stopped working last nite and has no power. anyone experirnec the same issue?
When this occurs it is a sign that you have a defective washer main control circuit board, this circuit board is the brains of the washer and it located behind the main control panel of the washer.
Feb 07, 2012 | LG Washing Machines
My 50 inch hitachi has volume no picture
No Picture:
1. The Power Supply may not be producing the correct voltages.
2. The Digital Module (Digi-Main) may not be producing correct
turn on commands (Power 1 and 2).
3. The Logic PWB may not be supplying the correct Vs/Va turn on
commands (Vsago and Vcego).
The Panel can have a defect of two natures.
1. The panel is shorted.
2. The panel is defective, but not presenting a short.
3. Y-SUS and/or X-SUS may be defective (Shorted and or nonworking).
First monitor the front Power LED.
• Does it turn on, then go completely off? (Indicates Shutdown), Power Supply not running.
(Shutdown usually indicates a Short.)
• Does it turn on and stay Green, but no picture. (No Shutdown),
• Power Supply running basic power supplies, but Vs/Va voltages not being produced.
PRELIMINARY OBSERVATION:
Next open the unit by removing the back cover. Check the following carefully by visual observation.
Power Supply PWB: Look very carefully around all mounting screws for cracks or PWB damage.
DW-3 NO PICTURE TROUBLESHOOTING
BUFFERS (Drivers) ON SDR Upper and/or Lower PWBs (50"~60")
Take a moment to carefully observe the Buffer "Snot" Chips
(Left Side black chips mounted on the SDR Upper and Lower PWBs).
Look very closely for burns and/or small holes in these chips.
If any defect is seen, the PWB is defective. Replace this PWB and
the Y-SUS if PWB not upgraded. Replace only SDR if PWB is upgraded
Dec 23, 2010 | Hitachi P50H401 50 in. Plasma HDTV
LG WASHER WON'T Power on
Hello. If the lid switch is defective, your washer may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
May 24, 2010 | LG WM1814CW Front Load Washer
My LG washer keeps displaying LE error and shuts down. What is wrong with it?
HI, this error code is referring to a locked motor issue. This will occur if the The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of stator assembly. Other issues with the motor harness may pertain to The electrical contact between the connectors, (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main PWB assembly is bad or unstable. Or the motor harness between the sator assembly and main PWB assembly is cut (open circuit). If all the motor harness connection are in good condition, This will lead to an out of order or, defective hall sensor. in this case, the motor will need to be replaced.
Nov 20, 2009 | LG WM-2277HW Front Load Washer
Getting Le error code and washer stops
HI, this error code is referring to a locked motor issue. This will occur if the The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of stator assembly. Other issues with the motor harness may pertain to The electrical contact between the connectors, (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main PWB assembly is bad or unstable. Or the motor harness between the sator assembly and main PWB assembly is cut (open circuit). If all the motor harness connection are in good condition, This will lead to an out of order or, defective hall sensor. in thsi case, the motor will need to be replaced.
Nov 18, 2009 | LG WM-2277HW Front Load Washer
LG Washer won't power up
LE Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Aug 26, 2009 | LG WM2277H Front Load Washer
I own a lg washer le has poped up on dig. screen tub will not spin ...
HI, this error code is referring to a locked motor issue. This will occur if the The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of stator assembly. Other issues with the motor harness may pertain to The electrical contact between the connectors, (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main PWB assembly is bad or unstable. Or the motor harness between the sator assembly and main PWB assembly is cut (open circuit). If all the motor harness connection are in good condition, This will lead to an out of order or, defective hall sensor. in this case, the motor will need to be replaced, as well as the sensor
Aug 18, 2009 | LG Washing Machines
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
