Question about Maxtor Personal Storage 3100 (M01E100) 100 GB Hard Drive
My 3100 worked for about 2 years and the other day
My 3100 has worked for about 2 years and the other day it stopped being read by WinXP. It usually had a constant fan whir and a barely perceptible buzz when the discs where being accessed, but now it clicks about every half a second and the orange "accessing" light never comes on. I recently changed the compression settings on the C drive to compress data to save disk space, could this have caused the external drive not to be read? I switched out the cable and it still does not work, even on another computer. Any other suggestions?
other info - Dell Inspiron 5150 (yep, aging quickly)
  • Maxtor Master
  • 27,725 Answers
If the fan does not come on at start up try this replace all electrical leads that attach to your hard drive including IDE,SATA leads if still no work replace PSU
Posted on Jul 31, 2010
My dell dimension 3100 had a virus and has to be formatted but i lost the windows xp installer, what should i do?
Install another OS unless you can find the receipt for the old WinXP purchase and wave that at a Microsoft retailer. Mint Linux is a good choice, though Fedora 13, bsd, OpenSolaris distros are very very good replacements. If you upgraded it enough for Windows 7 to work, try buying a copy of that from a dealer you like (or say, Microsoft.com , natch).
Jun 11, 2010 | Dell Dimension 3100 PC Desktop
Cannot read DVD but can CD?
Could be just a dirty lens. Try :-
1) Blowing some compressed air through it. You can get cans, may already have one.
2) Running a CD lens cleaner. Its practically the same mechanics.
After that, its taking it out and cleaning it.
Jun 06, 2010 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Hi I have 2 inverters on my house each with 21 pannels. normally 1 puts out around 3500w and the other around 3100 during the peak of the day. lately however 1 is only putting out only 600w during the peak...
The inverter will only make AC at a rate per the current and voltage being supplied by the solar panels. The panel outputs need to be checked and compared to the panels that are working correctly.
It certainly sounds as if there is a power distribution problem from the panels supplying the 3100 W average output inverter. It can be anything from a corroded terminal to a damaged umbilical or anything in between.
A bad ground for the inverter will also limit output. It may read resistance / continuity but can not carry the amount of current needed to produce 3100 W output. Given it has only been 5 days the problem should not be hard to isolate and find.
I had a similar problem arise quite recently with an 18 panel system and the problem ended up being corrosion on a terminal block connection. Cleaned up the terminals and reconnected everything with a 2155W difference from the original output on a 3200W inverter system.
Thanks for using FixYa.
Kelly
Mar 19, 2010 | Solar Electronics - Others
Breitling Colt Kinetic Watch - not working
I read the instructions for a similar type of watch and while the battery will keep the watch "alive" for some months when not in use, eventually the battery dies.
Since it is a kinetic watch the instructions I read said that you should gently shake the watch about 500 times to recharge the battery!
If you give it a good shake and then wear it for a few days, it should recharge itself, although it may have forgotten the time and may need re-setting.
Mar 01, 2010 | Breitling Colt Oceane 504 Watch
I had my hard drive replaced about a year ago And my computer frooze up to a blue screen 2 days ago,It doesn't have the sytem restore to the day you bought it on the new hard drive So I reinstalled windows...
Yes, it would be an idea to upgrade the video drivers, just goto device manager right click on your graphics in display adapters and choose the internet option, it takes afew minutes so be patient. post back if it does not work. thanks.
Feb 11, 2010 | Dell Dimension 3100 PC Desktop
I have 36'' Heartland refrige Model #3100. Every year or so refrige section stops cooling. I unplug for about 1 day after transfering food plug it back in and its fine. Any help would be greatly...
your frezer unit need to be check what you actualy do is defrost the unit every year :) but the problem is in your freezer unit that might be the heater unit / your fan.
Dec 30, 2009 | Refrigerators
My pc told me to un-plug my printer from a standard usb port into a high speed usb port, but where are the ports? It gave me the USB hub & ports in a pop-up which is now gone.
Dear,
Have you installed winxp service pack 2. only after service pack 2, xp support usb 2. instllall the latest service pack and try the same
Oct 16, 2009 | Dell Dimension 3100 PC Desktop
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Luminox 3100 series stops working at night
Sounds like there could be a bit of foreign material floating about inside, or the new battery was not up to scratch. Take it back for checking.
May 29, 2008 | Luminox Navy Seal Dive 3001 Wrist Watch
Maxtor Personal Storage 3100 (M01E100) 100 GB Hard Drive Logo
132 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
