Question about HP Pavilion dv2000t Notebook
Screen will not turn on unless I reboot it 2-5
Screen will not run on unless I reboot it 2-5 times. I purchased from a friend that was sick of it, in hopes that I could fix it or just deal with it, so i Formatted the hard drive when I got it on and reinstalled the Virus known as Windows Vista....The screen Problem still exists, but when i do get it to boot up, i get in the the OS and everything but a few minuets later it shuts down, Its connected to sufficient power and everything...whats wrong with this computer.
    President:
  • 2,600 Answers
This computer sounds like it has the same problem as every other DV series laptop and that is the fact that if they overheat in the slight bit, the solder on the Nvidia chip hits its de-solder point and the chip looses contact with the motherboard and causes all kinds of issues. I have "reflowed" dozens of these motherboards and have a 90% success rate and getting them to run again. If you have a heat gun, I can walk you through the steps to reflowing the board. You have to understand though that it may work and again it may not. In the times when I have not been successfull, I simply replaced the motherboard.
Take the laptop apart, I'll give you a link below for the service manual that explains the process.
The Nvidia chip sits next to the processor chip, wrap the motherboard in aluminum foil to ptotect all the areas except for the top and bottom of the affected chip.
Now, clamp the motherboard to a desk so it will not move and make sure that the underside of the chip is accessable from underneath.
Get a quarter and wad up a small amount of solder and place it on the quarter. Now put a small amount of thermal paste on the chip and place the quarter on the chip with the solder up. (The solder will be the indication to you that the chip has reached the proper temperature to melt the solder on the chip).
Now, take the heat gun and on the first heat setting start heating the top of the chip for 30 seconds, then switch the gun to the bottom of the chip for 30 seconds, then go back to the top for 30 seconds and then to the bottom for 30 seconds.....now, switch the gun to high and hold it to the top of the chip where it will blow down on the quarter, keep the gun at least 6 inches away from the board at all times. When you see the solder on the quarter melt into a drop, switch the gun to the low heat setting and put the gun about 12 inches away and sweep the gun from side to side or have a ceiling fan over the area and let it blow air softly down on the board to help gradually cool it. Do not bump, hit or disturb the board until the board has at least 30 minutes to cool down. Once the board cools down, remove the quarter and reassemble the laptop. Power the ****** up and see if it fires up. Below is the link to the service manual, copy and paste it to your web browser address bar. It is in a PDF format and is free to use, copy and print.
http://tim.id.au/laptops/hp/hp%20pavilion%20dv2000.pdf
Posted on Jul 30, 2010
I have a cocker spaniel that is sick with the runs with blood coming out is ****. so what do i do?
Take the poor dog to the vet. It ate bad food somewhere if that is hapening..
Oct 10, 2012 | wikipedia.org
I need someone to help me , I don't have write on post or message, you all must be getting sick of me but this all I have , can't walk much and need this , please help .
- In the top right corner of the screen, click the down arrow and then click "Privacy Settings".
- Click "Edit Settings" next to "How You Connect"
- Make sure "Who can send you messages" is on "Friends of friends"
Jun 26, 2012 | Facebook Social Network
I have 2 Asus 550ti top video cards that stop working after 8 hours
I would suspect that your power supply unit isn't up to reliably running a 2 card sli system...
May 24, 2012 | Computers & Internet
I have A30 8199 with initial 2 ram card of 256 for total of 512 meg. I purchased 2 new cards of 512 each for total or 1Gig. I am on Win XP home and have all updates to XP with Bios of 5/10/05. When I...
Looking over at crucial.com it says that your A30 can use PC2700 and PC3200 DDR. Maybe go other there and see if your new ram matches what they sell. I know it's not much but maybe a start.
Apr 26, 2011 | Lenovo IBM ThinkCentre A30 8199 (8199XX2)...
Requires many reboots
Sounds like a software related problem. Easiest approach would be to back up any valuable files and restore to original factory setup. You may need to purchase an external USB optical drive to reload the Operating System. If this does solve your issue then you may want to consult a local trusted pc repair shop so they can run hardware testing. Unless you have a warranty, with Acer you have a one year MFG. Warranty from the original purchase date.
Mar 12, 2009 | Acer Aspire One Netbook 8.9" Notebook
Booting repeatedly at compaq window itself,it is not takes up WINDOWS OS.
Solution 1:
When you start the system, press F8 and then select "Last known good configuration". If it does not work the first time, try at least three or four times.
Solution 2:
You can try installing the OS again but you will lose the data in your c drive.
Solution 3:
Check with the BIOS configuration, Take a note of the original configuration before you make any changes.
Jan 15, 2009 | HP Pavillion ZV6000 Notebook
WD-52525 screen is jumping all around with wavy horizontal lines etc.
Good Day;
Keep talking to the factory, it is their product. Best Buy won't replace unless it is deemed not repairable and/or terms of the contract. You purchased the extra warranty because you most have felt that the TV might break down. Well, it did, now use the contract to repair your TV.
Good Luck, big IRISH.
Sep 29, 2008 | Mitsubishi WD-52525 52" Rear Projection...
MY SANDISK e200 KEEPS FREEZING ON THE BEGGINING SCREEN!!!
Whatever you do....do not hit it, kick it, smash it....unless you bought it with the guarantee of anything is covered unless it's lost or stolen warranty when you bought it! I have had mine for maybe 3-4 months now & still having problems with mine. Mine wants to freeze up on me. The last time was last weekend, & at the time I'm writing this, it has again been frozen the the past hr 1/2 +. Maybe it has something to do with weekends, not sure. But last Saturday, on my way to work mine was still acting "sick". Wierd & not sure what I did or didn't do, but all of a sudden it started working....approx. 7:30 am WIERD! If you find out what may be causing your problem maybe you might be lucky to find the end of the rainbow to technology....good luck! But again, don't smash it unless you bought the extra warranty. Better yet....! Take it back to the store & get a refund! May you have a better & safe weekend, Leesa Last weekend it took maybe 12 hrs. or so to unfreeze & believe me I wanted to smash it with my foot & I did purchase the extra warranty! Not sure if you are having the same problem. Don't destroy it....instead since mine is covered for anything except lost or stolen....please DESTROY MINE!!
May 08, 2007 | SanDisk Sansa e200 MP3 Player
HP Pavilion dv2000t Notebook Logo
59 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
