Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
Where can I get a new bulb? - GE D52GW12 52" Rear Projection HDTV-Ready Television
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 132 Answers
If that is the correct model number of your set above (D52GW12), then your set doesn't have a bulb. That model has 3 picture tubes. You probably won't find a picture tube for one unless you take it to a tv repair shop which may have a used one, but it would be fairly expensive.
If that isn't your model number and your tv does have a lamp, you can find just about any one of them on ebay for the best price. Just enter your model number off the back of your set and the word "lamp" in the search column and they should come up.
Posted on Jul 30, 2010
How do I replace the bulb in my stylus pro straight?
Hi Richard, I found this answer that some one else wrote.
First remove cover to access the bulb, pull bulb straight down being careful not to break it. to replace w/new bulb, remove bulb from package, be sure to use a cloth or some type of glove so as not to get oils from your fingers on the new bulb as this will create a hot spot on the new bulb and shorten the life of it. Insert the new bulb gently so as not to break it, and put the cover back on.
Hope this helps
David
Dec 04, 2017 | The Office Equipment & Supplies
Bertazzoni hood replace bulb
First remove cover to access the bulb, pull bulb straight down being careful not to break it. to replace w/new bulb, remove bulb from package, be sure to use a cloth or some type of glove so as not to get oils from your fingers on the new bulb as this will create a hot spot on the new bulb and shorten the life of the bulb. Install the new bulb by inserting into the fixture by gently pushing the bulb into socket.
Hope this helps
Apr 19, 2014 | Bertazzoni K30 PRO X 30" Kitchen Hood
Neff bottom oven light not working after replaced blown bulb
Hi, My Neff oven bulb was replace with a new one after the old stopped working. The new bulb lasted 4 days and stopped working, could you tell me what seem to be the problem please.
Dec 28, 2012 | Ovens
Put a new projection bulb in.. whats the green
it is very possible you did take out the bulb housing and make sure you installed the new bulb correctly inside the housing and double check the way you slide in the bulb housing slowly making sure you do not force it in then make sure you reinstall bulb cover properly also!
techman
May 09, 2010 | Televison & Video
How to change out the left head light
if the # on the bulb is like 9005 or 9006 .back behind the head lamp assembly ,there are wires leading to the bulb housing ,with your fingers turn the bulb counter clock -wise ,now with the new bulb 'do not touch 'the new bulb with any part of your fingers only on the plastic part ,unsnap the old bulb a re install the new bulb,when placing it back in to the housing line it up with the grooves and turn.remember "righty tighty - lefty loosey, be very careful ,and do not turn lites on until you are away from bulb housing .
May 03, 2010 | 2002 Dodge Neon
Need to change low beam headlamp bulb
The bulb comes out the back, turn th bulb holder a quarter turn CCW abd pull it right out
The low beam is usualy the same bulb as the high beam, about 6 bucks or so
CAUTION Never touch the new bulb with your fingers, it leaves tiny straks of natural oil that will crack a new bulb
Put your hand in a clean plastic sandwich baggie THEN grab the new bulb ahd it just plugh straight in the holder, replace, turn a quarter turn CW and you're dome
Sometimes they're a ***** to gt your habd behind the bulb, but other than that it's easy
Sep 13, 2009 | 2005 Saturn VUE
Need to replace primer bulb on a briggs & stratton lawn mower
pull the bulb and retaing ring any way you can. don't try ti save them. you get a new retaing ring with the bulb. put the new bulb in then work the retaing ring in with a screw driver,clean everything behind the bulb before you put the new on in.
Apr 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Bulb wont come out of fitting
Do you have a NEW bulb? The bulb assy 'twists' out (counterclockwise) and a new bulb 'twists' in (clockwise). Each bulb has a connector to it. Remove the connector, twist out the old bulb, twist in the new one, and reconnect the connector.25d2850.jpg
Apr 17, 2009 | 2003 Hyundai Tiburon
Low beam bulb on 2003 X-type
Hi Rod
Open the hood, remove the plastic dome cover, and then the bulb connections, un clip the bulb retainer, extract the bulb, and check with the new one that its same.
No fingers on new bulb or it will pop when you switch on.
Fit new bulb and retaining clip, refit wires, test it, then fit plastic cover.
Good Luck !
This is what it looks like under hood !
A FixYa rating would be appreciated Thank you !
e3ac4f3.jpg John
Feb 08, 2009 | 2003 Jaguar X-Type
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
