Question about Canon PIXMA MP130 All-In-One InkJet Printer
INK ABSORBER FULL - Canon PIXMA MP130 All-In-One InkJet Printer
    President:
  • 1,335 Answers
If you absorber is full, you will have to replace it. You can either buy an absorber kit or have it replaced at a service center. A kit should be around $40 and to have it replaced including the kit should be around $100. It's up to you on how your want to handle it.
Sometimes it's cheaper to buy a newer printer.
Posted on Jul 30, 2010
Testimonial: "MB"
  • Canon Master
  • 525 Answers
To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
OR
turn on the printer press menu
press scan, copy, scan to enter service mode
use> to get to nvram
set ABS-M level to 0
Set ABS-P level to 0
Press stop to exit......Done
I hope this help!
Posted on Jan 15, 2015
INK ABSORBER FULL
Your waste ink absorber is FULL. So you need to replace your waste ink absorber to the new one.
This problem can not be solved by the user. You must take or send it to a service centre, where a technician will remove the old ink absorber, clean up any internal ink mess and enter a reset code to clear the "ink absorber full" condition.
May 27, 2011 | Computers & Internet
"ink absorber is full contact
while the ink on the ink absorber is submitted and must be cleaned. disassemble the printer until the ink absorber is reached, remove the ink absorber, with an alcohol solution to clean the ink dissolve deposits. It is better to make this a specialist
Mar 31, 2011 | Computers & Internet
Ink absober is full
Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during Print Head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible
Jan 11, 2011 | Casio Office Equipment & Supplies
Ink waste absorber is nearly full. What do I do?
You need to reset it.
Use this method with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full
You need Mptool to reset your mp170
download mptool here
Manual guide to use mptool
download manual guide here
Jul 09, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Ink absorber full
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Nov 28, 2009 | Canon PIXMA iP1600 Printer
Absorber is full
Hi ....
Please vote if this helps .... Cheers :)
Jul 15, 2009 | Canon Pixma iP4500 InkJet Printer
Canon ip1800 ink absorber is full, cannot remove Cartridge
Hi ...
Please vote if this helps ... Cheers :)
Jun 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Waste ink absorber almost full. What do I do?
Hi ...
May 04, 2009 | Canon I960 InkJet Photo Printer
My canon ip4500 says that the ink absorber is full contact the service centre
Hi ....
Do vote if this helps ... Cheers :)
Apr 29, 2009 | Canon Pixma iP4500 InkJet Printer
What does ink absorber full mean on Canon Pixma 1700?
my Canon pixma keeps coming up ink absorber full cannot print
Oct 30, 2008 | Canon PIXMA iP1600 Printer
Canon PIXMA MP130 All-In-One InkJet Printer Logo
227 people viewed this question
old marine
old marine
