Question about Vacuums
I have a sanyo ems9515w and need a 180c thermal coupler. any suggestions where I can get this?
  • burtoncurtis Jul 30, 2010
    I am looking for a thermal coupler, or thermal protector for a sanyo ems9515w microwave. I can't seem to locate one. Any suggestions?
  • 532 Answers
Thermocouples can be purchased at most hardware stores, home depot, etc.
The only difference for a thermocouple is the length. There are heavy duty types and regular. I would suggest using a heavy duty thermocouple.
Also, it is recommended that thermocouples should be changed every 2-3 years to prevent unnecessary failures, which usually occur when you need the unit the most.
Thanks for contacting Fixya.
Posted on Jul 30, 2010
  • 4,323 Answers
Hi
You can get parts for your microwave oven from this link---
Sanyo EMS9515w Parts Link 1
Sanyo EMS9515w Parts Link 2
I am sure you are talking about thermal fuse or a thermostat. Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
    Daniel
    What I am looking for is the Thermal coupler that senses an overheating condition. It bolts against the inside of the unit and is flat, about the size of a dime, and is rated at 180 centigrade.
I am trying to change the bag on my sanyo transformax 3in1 vac, cannot open it how do i open it?
This video may help you. Also you might find the manual at this site: http://homeappliance.manualsonline.com/manuals/mfg/sanyo/sc15m.html
Nov 16, 2016 | Sanyo Vacuums
Hoover 5163 Fold Away
Cutting out the thermal protector is a way assuring a sale of a replacement motor in the near future.
Apr 04, 2014 | Hoover Vacuums
How do you remove the coupling on model kichenaid ksb560mco. it doesnt spin off like some online instructions say.
It should spin off when you stop the motor from turning. Use a long flat bladed screwdriver positioned against one of the teeth of the coupler on the angled side of the tooth. Then hit the screwdriver with a hammer to drive it into the plastic tooth without breaking off the tooth. (Note: it's a left-handed thread, not the more common right-handed thread. So you need to turn it clockwise to loosen.)
The hard part is getting that motor connection to stop turning with the coupling.
If you want to save the coupler and some damage to the blender when the screwdriver slips, get the blender coupler removal tool. See http://www.kitchenaidblog.com/blender/kitchenaid-blender-rubber-coupler-9704230-with-removal-tool/ for a link to buy both. Slide the removal tool under the old coupler to hold the knob from turning. Then turn the coupler to remove it. For some a pair of pliers helps you start the coupler moving. (It can get stiff over time.)
I hope this helps.
Jun 26, 2011 | Vacuums
I just got a used sc-a102 vacuum and I need to
Greetings from GoVacuum.com,
The Sanyo Performax model SC-A102 use the Sanyo Upright Bags Part Number PU-1 Bag. We stock most of the parts for this Sanyo if you ever need anything.
Here's some links to the products on our site that will fit your vacuum cleaner:
- Sanyo PU-1 Upright Vacuum Cleaner Bag, Generic 9pk.
- Sanyo SC-A102 Performax Vacuum Cleaner Belts, 2pk. Part SC-BL3
- Sanyo SC-A102 Performax Vacuum Cleaner Exhaust Filters Part SC-FU1
- Sanyo SC-A102 Perfoxmax Roller Brush Part 6490002487:
http://www.govacuum.com/sanyo-bagless-upright-12-inch-replacement-roller-brush-beater-bar-sanyo-part-6490002487.html
GoVacuum.com can also special order any part that you require. I hope that this helps you. The Sanyo uprights are pretty good quality, inexpensive vacuum cleaners. They use metal in all the right places, and last longer, unlike models that use just plastic.
If you found this helpful, please rate it as helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of the page.
Thank you!
Chris Jones
GoVacuum.com
Mar 20, 2010 | Sanyo Permax SC-A102 Bagged Upright Vacuum
Steam Vaccum won't switch on
it sounds like your thermal fuse went out and u have to open it up ant test the fuse with a multimeter...I had the same problem and had to replace the thermal fuse...I ordered a fuse(sf188e) from ebay...cut the old one out and soldered in the new one...hope this helps.
Dec 30, 2008 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Pulse Bagless dust press system vacuum cleaner I need to download the instruction manual
Dear Customer
please check the following link for
Sanyo Instruction Manual Upright Bagless Vacuum Cleaner SC-150, SC-180
http://homeappliance.manualsonline.com/manuals/mfg/sanyo/sanyo_upright_bagless_vacuum_cleaner_product_list.html
please rate this,Thank u
Dec 16, 2008 | Sanyo Vacuums
Fantom Cyclone XT Vacuum Cleaner
Here is the owners manual which goes over some troubleshooting problems.
http://www.fantom.com/fantom/manuals/Cyclone.pdf
At first I would think it was the thermal overload, which is covered in the manual. But I would guess that you have let it sit for 30 minutes to cool down and tried again and the vacuum still didn't work.
I would think you may have one of four problems.
1. Your thermal overload was tripped and is stuck and will need replaced.
2. You have a clog in your vacuum lines or the brush roller is froze, which keeps causing the thermal overload to trip.
3. Your power cord has a short, which would need replaced.
4. Your power switch is bad, which would need replaced.
Out of these 4 possible problems I would say the only one you could fix on your own would be problem #2. Make sure the vacuum is unplugged and take the brush roller off and clean it, make sure it moves free. Check your vacuum lines to make sure you do not have a clog, other wise the motor does not get air flow to cool it down causing the thermal overload to trip. As for problem 1, 3, and 4 I would suggest taking it to a repair shop.
Hope this helps, post back.
Jul 11, 2008 | Fantom Vacums XT450K Upright Vacuum
Eureka sanitaire SC412 thermal reset
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=658043 Generic problem for all Vacuums
Posted by 5star on Jun 09, 200
I need to reset the thermal reset button. I have never opened by back pack vacuum before. Does it have a particular color and does it have to be reset to a particular point or do I just press a button?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka / Sanitaire SC412 Thermal Reset. I would contact the manufacturer to see if your particular model # has one, just give them the model # and the serial #. So I suggest that you get an owner’s manual from the manufacturer on you particular model so that if happens again, you will be prepared. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
5855 Terry Fox Way
Mississauga, Ontario L5V 3E4
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 09, 2008 | Vacuums
Electrolux Canister - Stops working after 1-2 minutes.
Electrolux Canister - Stops working after 1-2...
Our vac works for a short time, then shuts off and makes clicking noise as if trying to restart again. Works after cooling for a while but for another very short time. Your suggestion on fix would be greatly appreciated.
Thanks
I would advise that it could be a thermal switch or a regular switch that the thermal switch is over heating and needs replacement – there are small hoses in the door section that could have been pinched or kinked and it stopping the air flow from the vacuum – also check for a clogged or plugged vacuum hose, a full vacuum bag or a dirty vacuum filter. Check the thermal switch or reg switch or the hoses in the door. Or feel free to contact your local vacuum dealer in your area or in the yellow pages, or call the factory @ the phone number listed below:
http://electrolux.com Customer Service
Electrolux Home Care Products – North America
PO Box 3900 Peoria, IL 61612
1-800-896-9756
Don – The Vac Man
Apr 21, 2008 | Electrolux Guardian Bagged Canister Vacuum
Vacuums Logo
55 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
