Back to:
Tags:
Camcorders
Generic problem for all Camcorders
Camcorders
posted by cmcneight on Apr 24, 2008
I would like to purchase a video system for golf instruction that can play back slow motion and frame by frame advance. I would like this system to be operated with a small remote controller.
thanks
chuck
email:
proshop@turkeymtngc.com
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 28, 2008
Not Rated (0)
VideoMaster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Almost any new digital camcorder will work great, but you want to make sure it has a high speed shutter setting.  Set the shutter speed as high as possible (which means you'll need a lot of light... day light is perfect).  You're still only shooting 30 frames per second, but each shot will be sharper (less motion blur) as the shutter speed increase.  High-end cameras can go up to as much as 1/10000th of a second, but even 1/500 would be great.  Standard, default shutter speed is 1/60th.
For playback, you can use the same camera with a remote control.  Just press play, then just before the swing press pause.  Then use the frame advance button to move 1 frame at a time.  Multiple presses of the frame button will increase the speed... to slow motion.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on camcorders:
I don't want to Accept this solution
Can you Help with these Camcorders problems?
Panasonic NV-EX3EN Mini DV Digital...
Downloaded stills with windows 95 now require to work with...
Panasonic AG-DVX100A Mini DV Digital...
I am seeing audio levels on the screen and I've done a...
JVC GR-DX25 Mini DV Digital Camcorder
colour bars coming down,no image and lens cover prints on...
Hitachi DZ-MV380A DVD Camcorder
it does not suport vista can we get the software for vista
JVC Everio GZ-HD7 Camcorder
Hello, the disc that came with camcorder everio GZ HD7 is...
Loading problems.
Repair Service
Find Camcorder Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
