There are shadows going to the right & lines on my computer screen monitor.
  • vanstroud2 Jul 30, 2010
    Worked great. Appreciate it!
    President:
  • 567 Answers
Hi there, check the cable that goes from the computer to the monitor it may not be properly connected,have bent or broken pin or it is going bad.You should try another cable to if it will work.
Posted on Jul 30, 2010
Asus VH196 text bleed
Go into settings a restore to defaults.
Then right click on desktop and then display go to display driver and restore to default or uninstall reboot computer and it will reinstall the drivers.
Sep 09, 2017 | ASUS VH192D 19 inch LCD Monitor
Monitor ghosts & shadows
The LCD driver board may need to be replaced.
Have it checked by a qualified technician.
Mar 14, 2010 | ASUS MW221U LCD Monitor
Dark shadow to the immediate right of my texts
Problaly you had a magnet near by that caused that Dark Shadow.
Feb 10, 2010 | HP Pavilion F50 17" Flat Panel LCD Monitor
My monitor has a line down the middle with a shadow on one side of theline and I have osd locked on the screen and cannot get the program to show on screen to fix it
Vertical line down a monitor with a shadow genearlly is an indication of a video cable problem. Try removing the video cable from the computer and if it is still there and OSD is still locked it is an internal logic circuits problem
Dec 17, 2009 | LG Flatron L1515S 15" LCD Monitor
Monitor display is blurry, with shadows and waves next to text
Jnanda,
Could be one of two related situations both have to do with built up magnetic flux:
!. If you have used the monitor for a significant amount of time and have never degaussed it that might be it.
To fix: Go to where your monitor's controls are (eg screen size/position, Brightness, Contrast, etc.). Providing that we are referring to an older style monitor (like a TV) and not a flat screen, you should find a degaussing button located there. This button is marked with a depiction of a horseshoe magnet. Press it.
If you have on screen settings control, hit the menu button and select the icon that looks like a horseshoe magnet.
You'll hear a buzz and the screen will go kooky for a moment.
You're then degaussed. Your problem should go away.
2. You may have moved the monitor close to a source of electromagnetic interference (or vice-versa) this will also cause that sort of thing you describe (remember that there are electrical lines in the walls (another source of EMI)
In that case move the monitor away from the EMI source or move the EMI source away from the monitor.
Remember that it could be both 1 and 2. So if the problem lessens but does not go away fully try both steps.
Feb 06, 2009 | Dell E173FP 17" LCD Monitor
Shadow Lines Across Screen on Dell P1130 CRT Monitor
What sort of shadow lines? I assume you haven't just noticed the two horizontal lines 1/3rd up the screen from the bottom and 1/3rd down from the top from the internal stabilizing wires that all Trinitron CRTs have?
Jan 29, 2009 | Dell P1130 21" CRT Monitor
Shadowing
Has a shadowing problem where everything on the screen was shadowing to the right. Did basic troubleshooting techniques and found that it was due to a loose connection to the computer. You may want to check this if resetting to factory settings doesn't help.
Apr 18, 2008 | Samsung SyncMaster 940N Flat panel Monitor
Monitor has shadows from left to right
Try changing the cable that connects the monitor to the computer, that might improve things slightly, but because you said that it works for the first 15 minutes I'm skeptical that the cable has anything to do with it.
The monitor is near the end of it's life. There's not much that can be done.
Jan 24, 2008 | HP Pavilion F50 17" Flat Panel LCD Monitor
Problem with shadows showing on monitor
LCD Monitor Shadow Effect
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this is very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
Solution: Keep the two cables - (power cable and monitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Nov 02, 2007 | Dell Computers & Internet
Ghosting
I know exactly what your talking about. I've seen in many times. It' happens too in CRT monitors as well as LCD. It could ALTHOUGH be as simple as a bad cable catching interference. Most likely though, it sounds like a bad LCD driver board or video board. If you have warranty, call it in. Otherwise see if it lessens with adjustments of contrast and brightness up and down. This directly affect the driver board power and can improve it enough to be tolerable again.
Aug 04, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Open Questions:
How to Remove a Virus from Windows PC or Laptop - DataAlign As the number of cybercrimes and harmful online attacks are increasing these days, it is difficult to keep ourselves safe while surfing the websites of various sites online. If you are looking for a safe online risk reduction scenario, then trust the tech support of TechFree for Toshiba products. Toshiba laptops and other devices get best maintenance and recovery by the services of Toshiba support. Toshiba support provides best risk safety from online threats and also recovery for broken computers and other peripheral devices. Online threats in the form of viruses, Trojans and malwares that are prevalent everywhere pose serious safety threats to the customer's personal information. Various other regular issues like slow computers, snail speed processing, recurrent screen freezing, frequent and without reason computer shutting down and restarting etc. also prove to be a reason of headache for the customers. In case you want all your tech issues to get resolved while you can be busy doing your usual life stuffs then get in touch with the fabulously supporting Toshiba supprot team. You can get the benefit of 24/7 tech support service at your home or office by calling on their toll free helpline number Call Toshiba +1888784-9316 Technicians of Toshiba support got certified for involvement of advanced technology and still making it available for customers at affordable prices. Also, many profitable deals and offers are provided to the customers. Your search for that perfect tech support with features like reliability and consistency is over with Online Toshiba support Email service technique makes delivery of support easier and comfortable for the customer. Also, professional tech services become more trust-worthy with the 30 days money back guarantee it comes with. Toshiba technicians make efforts of delivering the best customer support along with proper knowledge sharing which helps the customers to get proper understanding about all issues and their resolutions. For tech related support contact tech service team of TechFree on their toll free helpline number Toshiba Customer +1888784-9316 anytime. Toshiba support providing professional and certified tech experts will use the most appropriate troubleshooting to resolve tech issues in least turnaround time.
Aug 17, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
15 people viewed this question
Alun Cox
David Payne
David Payne
