I would like to manually clean the black print head of MRC-845CW but do not know how to get it out. I tried cleaning more than 10 times but did not help. I also put new black ink cartridge.
I am afraid that the method proposed by bzet1820 only works in printers where the print head is part of the ink cartridge.
On the MFC-845CW, the print head can only be exposed by disassembling the printer and this is not for the faint of heart! It can be done but the disassembly requires:
1) Remove the ink cartridges. Then fully remove the scanner bed (gently disengage the plastic blue arm that would normally hold the printer cover up when installing USB or Network cable.
2) Disconnect all visible connectors (wire and ribbon cables) by first lifting the plastic channels covers to expose the cables.
After all cable are disconected, with the printer cover at 90 degrees open, you can pull it backward and remove it.
3) Remove all visible screws to disconnect the external case from the main body of the printer.
The printer holds together also because of several hard to find plastic notches that click into place. You have to patiently probe and push/pull around the various edges to disengage the parts from each other.
4) After removing three holding screws, gently tilt the control panel forward and remove it. (There are some additional cables connecting the control panel to the rest of the circuitry and of course you need to disconnect those).
Mark or take pictures of the assemblies at various stages to facilitate reassembly.
5) Gently pull up the external case in its entirety to expose the entire printer body and the printer head. This requires some gentle persuasion especially on the two sides and the front of the printer.
6) With the print head visible on its two metal tracks, you have to ease out the rearmost track by forcing two spring clips out of the holding slots.
7) Once the rearmost track is free, gently ease out the print head mechanism from the front track and disengage the driving belt from the two pullies at each end. By twisting a bit the assembly (sill connected with ink tubes and ribbon cable) you will be finally be able to see the actual print head nozzles.
If you are lucky (!) some cleaning agent might be able to unclog the nozzles simply by rubbing with clean soaked fabric or qtips. If (as is most likely) you need more effective cleaning you wll have to remove the printer head completerly by unclipping a clip that holds the ink pipes to the printer head and a ribbon cable. These are under a black plastic cover that you will have to unclip with patient effort.
8) At this point, the head is free and you could soak the head in warm water / alchohol in a tray for a more energetic cleanup.
With a siringe, for my totally clogged magenta head, I tried to push air and alcohol through the magenta channel of the printer head but after reassembly I I found out that I was able to unclog only about 15% of the magenta nozzles. Subsequent cleanings in the printer did not unclog any further nozzles.
9) In reassembling the printer make sure that a little plastic white arm protruding through the rearmost metal track on the right hand side facing the printer, is actually exposed through a slot on the track (this determines when the printer head has reached the end of the run).
There is also a transparent ribbon that has to fit in between a vertical sensor on the printer head plastic cover. I think it senses the position of the printer head on its run.
If the above is not correctly done, after the printer is reassembled you will get an error such as "Unable to Clean - 50" or "Unable to Clean - 30" or something else and you will have to dismantle the whole printer again. Quite a pain....
Unfortunately, in my experience, if the head is heavily clogged it is unlikely that you will be able to free every single nozzle and restore full print quality. Anyway, if you like this type of challenge and don't mind actually getting your hands literally stained with ink, (as well as running the risk to end up with a totally unusable printer) I wish you good luck!!
Posted on Aug 01, 2010
  • 700 Answers
I assume that this one is multifunction brother mFc-845cw? if so, then please follow this procedure:
1. remove cartridge from craddle
2. check what is ink solvent, water, isopropyl alcohol or methylated spirit, solvent will be that which did not cause precipitation or curdling of the ink
3. touch bottom of the ink cartridge with lint free absorbent paper, if it leave print, this meant there is no problem with ink cartridge.
4. put one drop of solvent on gold button in the craddle adn allow to sink for about minute, touch with absorbent paper
5put a drop of solvent again on the nozzle in craddle, re-insert cartride and print test page. beginnig of the page will be rather faint but it should improve as page go to the bottom.
if this did not solved your problem, some office supply stores sell absorbent pads, weight is about 120 to 160, do not go for haevier than that as brother do not handle very well papers above 160 weight, try to print test page on that, whis will work as sort of cleaning tissue over the heads, do bear in mind that this cannot be run to often as it will wear heads very fast.
on all inkjet printers you need to print at least one page per week to prevent all nozzle from cogging and ink from drying.
hope this solve your problem, if not, please return but with more details on your printer.
Posted on Jul 30, 2010
How do I clean the print heads of a MFG665CW
Hello there
Not being familiar with this particular model, I had a look at the users manual which can be downloaded in pdf (Acrobat Reader) format from the link below:
http://download.brother.com/welcome/doc002117/Mini3_MfcLcdW_UsaEngUsr_D.pdf
Here I found the instructions for cleaning the printhead using the control panel menus:-
DO NOT touch the print head. Touching the print head may cause permanent damage and may void the print head's warranty.
a Press Ink.
b Press up or down to choose "Cleaning".
Press OK.
c Press up or down to choose "Black, Color" or "All".
Press OK.
The machine cleans the print head. When cleaning is finished, the machine will go back to standby mode automatically.
This is done from the control panel but I also managed to find the Service Manual (not on the Brother site!) here
BROTHER MFC 845CW 665CW 660CN Service Manual free download schematics...
If you go towards the bottom of the page, there is a small link which says "Get download". Clicking on this downloads a pdf document to your browser which can then be saved to disk for future reference.
I found this manual interesting for its descriptions of the various operations.
Cheers
Nov 14, 2014 | Office Equipment & Supplies
Unable to clean 50 (brother MFC-845CW
Hi, to clean up brother MFC-845CW
Open the printer
Remove the ink cartridges from the print head.
Use cotton swabs dipped in hot water to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab.
Once finished, allow to dry and replace the cartridges
Try to print something now
You can also use the manual for help.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002117/Mini3_MfcLcdW_UsaEngUsr_D.pdf
Jun 14, 2011 | Brother MFC-845CW InkJet Printer
Hi my printer won't print black, test colour work but no black, therefore all text to print is blank. I have replaced the ink with a new one and cleaned it 5 times, still no black ink. Thanks
Hi
Clean it manually by removing the black ink cartridge and rub the print head into a paper with rubbing alcohol until ink flows more. Then run the print nozzle to clean the print head thoroughly. After, try to print again.
If not, dip the print head only into hot water for 5 minutes and then run the print nozzle.
Let me know if you need more help
Mar 08, 2011 | Brother MFC 420CN All-In-One InkJet...
Brother Mfc-845cw and Mfc-465cn both stopped printing Black about the same time. Using Non brother Ink. Tried cleaning, replacing carts, unpluging maching. how can I fix this.
the black ink that was used in the refilled cartridges was probably to thick for the nozzels on the head, you can try buying the original cartridges and then cleaning again, or check with the store you got these cartridges from as some of them offer a warranty
Nov 20, 2009 | Brother MFC-465CN InkJet Printer
Black print won't work on Brother MFC-845CW
Open the case,i don't sure were the cartridge is located but i think is easy to you to find it.When you found it, wipe the botton part of your cartridge use soft clothe for cleaning.Look at mannual to locate the cartridge.
May 19, 2009 | Brother Multi-Function Center MFC-240C...
Printer will not print black ink.
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head..slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out.
5. Have severasl paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. May color and black and white print is back!
Hope this helps.
cw
Feb 16, 2009 | Canon PIXMA iP90v InkJet Printer
IP90 WONT PRINT BLACK
1. open the top lid to have the cartridges that are inserted in the print head move to the middle of the printer.
3. What is left there is the print head holder. Slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out of the tank.
5. Have several paper towels hand and know that you will have color and bw ink on your fingers
10. My color and black and white print came right back!
Hope this helps.
Jan 30, 2009 | Canon PIXMA iP90 InkJet Printer
Print head for brother mfc420cn
Cleaning the print head
To ensure good print quality, the MFC will regularly clean the print
head. You can start the cleaning process manually if needed.
Clean the print head and ink cartridges if you get a horizontal line in
the text or graphics on your printed pages. You can clean Black only
or three colors at a time (Cyan/Yellow/Magenta), or all four colors at
once.
Cleaning the print head consumes ink. Cleaning too often uses ink
unnecessarily.
Caution
Do NOT touch the print head. Touching the print head may cause
permanent damage and may void the print head’s warranty.
1 Press Ink.
2 Press ▲ or ▼ to select Cleaning.
Press Menu/Set.
3 Press ▲ or ▼ to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished,
the MFC will go back to standby mode automatically.
If you clean the print head at least five times and the print has
not improved, call Brother Customer Service
Hope that helps,
Take Care,
Michael
Nov 13, 2008 | Brother MFC 420CN All-In-One InkJet...
Not printing black
First of all the print head is clogged just because you have tried to print repeatedly while some of the cartridges are empty. This results ink burn in the nozzle and clog. My recipe: Heat some drinking water in the kettle (70-80 C). Put the head in it and shake gently several times until ink is completely clean (10 minutes). Change the water do the same again. Change the water again (70-80 C) this time put a spoon full of apple vinegar (becomes a natural acidic solution very dilute) shake again, clean with cotton stick. I did it and started to love my mp800 again as much as I just bought it, all colours come back and started to print superior photos again...... Do not touch heads' copper poles and cartridges poles because of the static electric they may mulfunction and colours may becaome totally mixed for a short while...
Aug 22, 2007 | Brother MFC 210C All-In-One InkJet Printer
387 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
