Question about Drills
Spit 349 drill battrey no charge
Spit 349 drill battrey will not hold a charge
  • 90 Answers
Battery packs are made up of a number or c batteries that are rechargable. when one gets weak or bad it may still work but not as good. you can repair battery packs but you only save a few dollars for all the agrivation. the new ion batteries have a mini computer in them to talk to the charger. if that goes bad that's it.
Posted on Aug 29, 2010
The battery seems to be dead and the unit is not recharging. Even when plugged in to the wall, the unit does not charge.
this is because the battrey of your phone become dead thatswhy it is not charging in any way... so only you have to boost the batrey if ther is anything in the battrey then it will work otherwise you have to change the battrey and to avoid this type of problem don't try to work in low battrey...by this your bttrey life is long...enjoy it and pls vote
Jun 23, 2015 | Televison & Video
Battrey charger not working
change you battery charger
Jan 18, 2012 | Drills
My 7.2 v drill won't charge
If your drill is old and has had a lot of use, it may be that the battery has had a full life and just needs to be replaced. Batteries will only take so many charges and then will quit holding a charge.
Feb 27, 2011 | Black & Decker & Cordless Drill
I have a Ryobi 18v drill with battery 130429002 that will not hold a charge. Expensive battery with very little use. Can you help?
If both batteries won't hold a charge the problem may be the charger (not providing a full charge). If one battery is OK and one not holding a charge, the problem is probably a defect with the battery. I know there expensive, (I recently had to replace one for DeWalt).
Aug 18, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
The drill is on the base but the battery lights are not coming on and it won't charge. It has been on the charger all night and hasn't charged at all. It worked fine up until now. I've only had it for...
You should check first using multitester, the voltage that comes out of the drill charger. if the stress is normal in accordance Battery voltage required by the drill, the damage there is on these batteries, the batteries serve targeted cell is damaged or broken connections between cells in these battrey. so the charger can not charge battery, indicator lights would not light up.
Jul 27, 2010 | Drills
The drill has stopped charging up. No obvious
It may be the charger, but most likely the battery can no longer hold a charge. This may happen if the battery drops below its holding charge. Example, left discharge for a couple months. There is little that can go wrong with a charger unless you start smelling burnt plastic from it.
Jun 07, 2010 | Black & Decker 18 Volt Cordless Drill...
Craftsman cordless drill won't work even after charging battery.
Try working the switches Low/High, Forward/Reverse. Sometimes, the battrey can hang up a bit in the charger, resulting in a low, or no charge. Try a different battery, or recharge your existing battery, making sure that it is firmly seated in the charger.
Regards, --W/D--
Jul 18, 2009 | Craftsman Drills
Altinator dose not charge when battry is low
time for another battery. Have a load test done on battery. Then have someone fullfield the alternator to see if its operating correctly
Jul 13, 2009 | 1987 Toyota Land Cruiser
Battrey
it may be charging,,,,,so check wheather the HOLD button on top is unlocked
Jan 02, 2008 | SanDisk Sansa e250 MP3 Player
Drills Logo
Top Drills Experts
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Drill Expert? Answer questions, earn points and help others
