Question about Royal Office Equipment & Supplies
I have a vf1700mx I think we ran it a little to long and now when you put the paper in the motor starts and makes a noise a little different from shredding but will not accept pape. The motor is running but the shredder is not turning. Suggestions please.
  • Anonymous Mar 23, 2014
    Overload light come on
    Genius:
  • 1,218 Answers
If the moter runs but the cutting shafts are not turning then you have likely stripped a gear.... unplug, open top to see which one the give Royal a call at 1-800-524-0799; they should be able to help with parts.
Posted on Aug 19, 2010
Will not shred no matter what I try to do. I have run it backwards and forward and it still will not shred. Please advise and thank you.
If you want to keep it , I think you should dismantle it make a mental note of how you do it, free any paper jam and spray the cutter blades with a thin layer of WD 40 or similar then you should be good to go unless the motor is burned out from you constant on off testing
May 25, 2015 | Royal VF1700MX Shredder
Frigidaire in wall air conditioner making noise fan/ motor?
Is it a clicking or banging sound? The fan is most likely not kicking up the moisture to cool the evap coil off enough in the unit so you might here more noise for a little while. Monitor it and let me know if anything changes.
Sep 05, 2012 | Frigidaire FAH106N1 Wall/Window Air...
Knives rotate backwards, but not forwards; when
SORRY, BUT YOU HAVE LIKELY GOT A BURNT WINDING IN THE MOTOR OR A DEFECTIVE PCB..
Jun 28, 2010 | Royal Office Equipment & Supplies
Will not cut paper or CDs, but motor turns
If you can hear th motor turning but nothing else is turning...you have probably stripped teeth off a gear inside.
Unplug machine, take cover off and determine which gear/gears.....
you can call Royal at 1-800-524-0799. for parts.
May 23, 2010 | Royal VF1700MX Shredder
Royal VF1700MX - motor does not turn
You've probably lost the pcb inside the machine. Give Royal a call at 1-800-524-0799 they'll be able to advise on part number and price.
May 21, 2010 | Royal VF1700MX Shredder
Maytag Dryer - funny buzz sound and then nothing
my dryer makes a buzzy sound bt it wnt start just make a buzzy sound
Jul 10, 2009 | Whirlpool LER4634J Electric Dryer
Problems printing 4x6 with MP600
You're most welcome. Remember to check all of your paper, I had it curl a bit from sitting too long and I had a very bad paper jam from that. Good luck!
Feb 25, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Fisher-Paykel washer pump noise & some water left in tub
Lube the brass bearings on the motor. For some reason the bearing on the bottom nearest to the cooling fan will start to whine. I would guess because it's kicking dust up around the unit. I used a lube that will hold in place. Lube between the bracket that holds the motor together and by the fan. The noise should stop. I also suggest you lube the top bearing as well. The lube I recommend is a Silicone paste type.
Jan 04, 2009 | Fisher Paykel EcoSmart GWL15
I bought a 96 dodge intrepid 3.5 v6 car that ran great except it was leaking oil from somewhere on the front bottom left hand side of the engine checked everything and put power steering fluid cause it was...
It sounds like the car was ran out of oil.The engine bearings and crankshaft journal are probably scarred.The noise you are hearing is more than likely a piston rod slapping around about to break loose from the crankshaft.So,yes the engine is toast...Sorry..Good Luck!!!
Aug 05, 2008 | Dodge Intrepid Cars & Trucks
70 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
