Question about Indesit Washing Machines
When the door is closed it still comes up with "door" on the display panel and wont start.
  • Indesit Master
  • 909 Answers
You will find the door latch is faulty and needs replacement.
Posted on Jul 30, 2010
My electrolux eiflw50l washing machine wont start
Hey friend, thanks for your post!
From the information you have provided your Electrolux washer is not starting. This could be a possible issue with your control panel or door latch. If your door is not communicating that it is closed then the washer will not start. Is your washer displaying any information or error codes? If you can provide any additional information I will be able to assist you further. -Matt
Mar 15, 2015 | Electrolux Washing Machines
Light panel fully lit stopping program selection and start does a electronic part need replacing
I would suspect the user interface panel.
Most dishwashers can be tested thusly:
Turn off power to the dishwasher at the circuit breaker box. Take apart the Dishwasher door and unhook the cable from the User Interface panel to the main control board. Then, turn the power back on and close the dishwasher door so it latches. The drain pump should go on. If it doesn't the main board is bad. If it does, it's the user interface panel.
Oct 15, 2014 | Beko DW602 600 mm Silver Built-In...
Wont start machine error come up
Door open error code can also be displayed as "dOE" On non-display panel models this fault code is denoted by the light for the door lock being lit or flashing.
  • Check door is closed correctly and latched
  • Check door handle for damage or wear
  • Check door safety lock if inoperative replace door lock
  • Check door lock wiring
  • If there is a clicking sound once or twice when the Start/Pause button is pressed the main control board may be faulty
Apr 08, 2014 | LG WD-1280FHD Front Load Washer
Lights will come on and timer will count down but the washer will not begin
Hello -
Try resetting the unit at the household circuit breaker and confirm that there is power to the unit. If there is power and unit will not start you could possibly have a defective control board, cord or wiring. Do you notice any error codes displayed on the control panel or lights blinking? If so, if panel displays "DR", either the door is not closing properly or it may have a defective door lock switch. However, if panel displays "DDO" the drawer is not closing, magnet may be missing or have a defective reed switch. Typically this is not a do it yourself job and it is something that you want a certified professional to install/repair for you due to safety and liability reasons.
Oct 23, 2012 | Frigidaire GLTF2940ES Front Load Washer
My new bosch axxis washer was20160uc does not start
Open the dishwasher door if the desired cycle does not perform as selected on the control panel. Press the main power switch "Off" and then "On" again. Select a cycle, press the appropriate button, press "Start" and close the door. Make sure the door is closed completely.
Check the circuit breaker and water supply if the dishwasher does not start after selecting the appropriate cycle on the control panel and shutting the door.
Turn "Off" the dishwasher and disconnect the dishwasher from the power supply if an error code between "E01" and "E30" appears on the digital display. Reconnect and turn the dishwasher "On." This should reset the control panel.
Terminate a program on the control panel by holding the "A" button and pressing "Start" at the same time. The display will read "0:01". Close the door to start the program sequence. The display will read "0:00" when finished.
Oct 15, 2010 | Dishwashers
Door wont open on bosch classixx 6 1400 express washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board. The wash program should halt when this comes up but you should be able to restart it when the door is closed. As the cost of a new door interlock isn't overly expensive. The best way to fix this problem is to purchase a new lock and fit it.
Thank you !
May 19, 2010 | Bosch Classixx WFL 2066 Front Load Washer
CL in display
take the screws out from around the top and take the control panel off to access the door latch assembly but first take the mylar ribbon off from the control panel and clean it with a pencil eraser gently and replace the ribbon see if that clears it and let me know now leave the two lower screws in the door panel so it wont come off
Mar 15, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Jan 24, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi Washing machine
when any of the buttons are pressed ERR is displayed.
Jan 24, 2008 | Washing Machines
Washing Machines Logo
150 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
