I have a Konica Minolta C450 copier with FS-603 booklet maker. The problem I'm having is that when making booklets the staples are not centered down the middle of the fold they are more like stapling on the far left side and visible on top of the booklets. Also, when the booklets are being folded they're not quite folding evenly down the middle. How do I fix these problems.
  • Gail Williams Aug 04, 2010
    Hi Daniel,
    After several replies to my question, I can't believe someone FINALLY gave me the right answer. I cannot thank you enough. I followed your instructions and now my booklets are stapling and folding in the correct position. You're the BEST! Gail
  • 4,323 Answers
Hi
You can only adjust the folding postion and stapling position by only +/- 7 mm. Please follow the procedure for adjusting staple location and folding location--
Adjustment of the stapling position
• The stapling position is adjusted by aligning the stapling position to the folding position.
• This adjustment is made in the Service Mode of the main unit. Since the adjustment is made in increments of 1 mm, this adjustment is useful for eliminating a displacement of 1mm or more.
• For the effective adjustment of a minimal displacement smaller than 1 mm, refer to “Board switch”.
Adjustable range: - 7 to + 7 mm (Increment: 1 mm)
Adjustment procedure
1. Set A3 or 11 x 17 to the Feed Tray.
2. Touch these keys in this order: “Fold & Staple” → “OK.”
3. Set five sheets of A3 or 11 x 17 original (blank paper acceptable) in the Original Tray.
• These five sheets are used for adjustment to minimize variation.
4. Press the “Start” Key.
5. Set the mode to the Service Mode.
For details of how to display the Service Mode screen, see the Adjustment/Setting of the main unit service manual.
6. Touch “Finisher”.
7. Touch “Center-Staple Position Adj.”
8. Renew the center folding of the finished copies.
Take the top surface of the finished copies as “A”, and the under surface as “B.”
9. Check the deviation of the stapling position from the newly folded position.
NOTE-- In checking the deviation, refer not to the folded position by the Finisher but to the newly folded position.
10. Press the “Clear” Key.
11. Adjust with the +/- Keys. When the stapling position is shifted to the direction A: Adjust the value to the - side. When the stapling position is shifted to the direction B: Adjust the value to the + side.
12. Touch “END.”
13. Make the copy and check again.
For activating the service mode---
Procedure
1. Press the Utility/Counter key.
2. Touch “Details” on “Meter Count” display.
3. Press the following keys in this order.
Stop → 0 → 0 → Stop → 0 → 1
NOTES
• When selecting “CE Authentication” under “Enhanced Securiy” available from
Service Mode, authentication by CE password is necessary.
Enter the 8 digits CE password, and touch “OK” key.
(The initial setting for CE password is “92729272.”)
• If a wrong CE password is entered, re-enter the right password. The machine will
not enter Service Mode unless the CE password is entered correctly. To return to
the Basic screen, turn Main Power Switch OFF, and ON again.
• The service code entered is displayed as “.”
4. The Service Mode menu will appear.
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Posted on Aug 03, 2010
  • Daniel Scott
    Daniel Scott Aug 03, 2010
    Adjustment of the folding position
    • The folding position is adjusted by aligning the folding position to the stapling position.
    • For the effective adjustment of a minimal displacement smaller than 1 mm, refer to “Board switch.
    6. Touch “Finisher.”
    7. Touch “Half-Fold Position Adj.”
    8. Check the finished copies for deviation of the stapling position of from the newly folded position. Take the top surface of the finished copies as “A”, and the under surface as “B.”
    9. Press the “Clear” Key.
    10. Adjust with the +/- Keys. When the stapling position is shifted to the direction A: Adjust the value to the + side. When the stapling position is shifted to the direction B: Adjust the value to the - side.
    11. Touch “END.”
    12. Make the copy and check again.
    Daniel
    Brigadier General:
  • 3,917 Answers
Hi
Please check the bellow link to follow the method of creating booklets…
http://www.akitainfo.net/knowledgebase/Manuals/Bizhub%20Color/C250/bizhub_C250_CopyandPrinting_Job_Shops.pdf
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 30, 2010
  • Gail Williams Jul 30, 2010
    Thanks for the link but I already know how to create the booklets on my KM c450 copier with FS-603 finisher. The problem I'm having is that it's not saddle stitches down the middle of the booklet. And, the booklets are not folding down the middle of the page. I realize that I may need a technician to make some readjustments on the equipment. What I really want to know is can the FS-603 saddle stitch evenly down the middle of a booklet and can a booklet be folded evenly down the middle. Thank you.
Konica monolta c650 wont fold
Saddel stich (Church program and staples in the middle)? or corner? Or booklet with two staple on the on left hand side? Saddel stick requires paper in landscape.. Check the staple cartridge. ensure both cartridge are securely installed.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 29, 2014 | Konica Minolta bizhub Office Equipment &...
Print a booklet with a cover
well would have to know the model the spec on the paper and do you have a finisher
Jan 30, 2014 | Konica Minolta bizhub Office Equipment &...
How do I replace staples in the Konica Minolta Bizhub 600?
The saddle stich or the booklet??? saddle stich is like church program with staples in the middle. Booklet is staples on the left side of the paper or the corner stapler to different staplers and depends on the finisher model?
Aug 08, 2011 | Minolta Office Equipment & Supplies
Folding and Stapling a Booklet on Bizhub C250
1)The print driver has two collate buttons and you only need to uncheck the first one (which is the windows driver not the Konica Driver) or
2) Install a new driver
Oct 02, 2009 | Konica Minolta bizhub C250 All-In-One...
Can't fold and staple multiple booklets
when you click on file then print in the window that pops up look at the lower right corner and you will see a box that says collate uncheck that box and it will staple correctly
Mar 05, 2009 | Konica Minolta Office Equipment & Supplies
Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Jan 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Printing my booklet
Layout/print type: booklet.
Finishing, centre fold and staple.
Jun 18, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
439 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
