Question about RCA L37WD12 37 in. LCD HDTV
MY L37WD12 STARTED NOT ALLOWING CONTROLS TO WORK ON TV OR REMOTE. THEN NO VIDEO, NOW NO POWER UP. RED LIGHT IS ON.
    President:
  • 1,099 Answers
You have to open the back cover of the television to check for bulged capacitors, if found replace with the same rating of the capacitors, but otherwise.
Also note that
If the green light comes on and blinks when the remote is touched it was never a issue with the mainboard, if it was you wouldnt have any signs of power. In most lcd tvs you have the main board which is normally the power board, the signal board which recieves signal and hold settings of the tv which can be all in one, the other is the inverter board, which scrambles the signal to what you see on the screen, and next we have the back light which lights the screen so you can see the picture, sometimes in certain models as i have learned you can have power/inverter boards which means the inverter and power are all on the same board, in your case i pressume the inverter board is seperate board and probably the issue you need to address, you can try website Shopjimmy.com,Ebay.com to buy a refurbish board for the replacement.
Hope this helps
Posted on Jul 30, 2010
Is there any way to turn on my RCA flat screen TV without a remote?
There might be a power switch on the front panel.
if the remote does not work, the replacement batteries could be defective or installed incorrectly.
The "light" on the front of the remote emits infra-red signals so you are unlikely to be able to see anything.
Dec 24, 2015 | RCA L37WD12 37 in. LCD HDTV
L37WD12 tv won't turn on, for a while if you unplugged it and then plugged it back in it would turn on and work fine but if you turned it off again you would have to unplug it again, well now no matter how...
Tv was have a failing power supply before.Now toally have dead transfer voltage to the rest of the tv circuitries.The tv power suuply board.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 06, 2010 | RCA L37WD12 37 in. LCD HDTV
My Mitsubishi projection TV will not produce audio or video
Two things are involved to cause that problem, tv remote control and remote sensor in tv.
Upon verification of remote working, it would be confirm that remote sensor in tv is defective and need to be replaced.
Remote control sends infra red light signal to tv and we can not see that light with naked-eye, so need digital camera or cell phone camera to see it by watching remote front through camera, press any keys on remote, if you see infra red light is blinking in remote front that means remote is working and remote sensor in tv will be replaced.
If no light blinking on pressing remote buttons confirm that this remote is defective and buy new remote.
Let me know if you have additional question.
Thanks.
May 31, 2010 | Mitsubishi WS-65511 65" Rear Projection...
RCA L37WD12 out of control
Ur Tuner board have problems,just not dead yet.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.The Tuner board main IC have intermitten short,that why take out A/C power input work for awhile,and than back to the same problems.
Apr 22, 2010 | RCA L37WD12 37 in. LCD HDTV
TV doesn't turn on. The red light is but no controls on the panel or the remote work.
Check the voltage at BP610 pin 1.It should be 5 volts.If it is low check or replace CP616.It is a 470 MFD 16 V capacitor.On my set it measured only 125 MFD.
Jul 08, 2009 | RCA L37WD12 37 in. LCD HDTV
Turns on automatically
use your camera on your phone and point the remote at the camera lense, you will probably find the remote is lit up and the remote is the problem, button on the remote is stuck and sending signal to the tv all the time until the batteries go flat. if its not that then the tv main av controller board has a fault. there area on the board for remote signal control.
Jan 09, 2018 | RCA L37WD12 37 in. LCD HDTV
RCA L37WD12 37 in. LCD HDTV Logo
239 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
