Question about Yamaha RX-V757 Receiver
Why does my system cut out at high audio levels?
  • 63 Answers
There is not enough power output coming out of the amplifier and the overload switch kicks off. Sometimes this can be caused by cooling. Check your venting in the back for dust build up. Hope that helps!
Posted on Jul 30, 2010
High level input question
High level input is used when no RCA output are present on the head unit. You would wire the head unit speaker wires to the high level input.
Mar 18, 2014 | Rockford Fosgate Punch 301S Car Audio...
COMPRESSOR ON & OFF FREON LEVEL OK
You need to hook up a gauge and read the pressures on the low and high side. It will cut out if the pressure drops too low or goes too high. If it was properly evacuated and charged I would assume it is probably high pressure cut out which would be indicative of a plugged orifice tube or restriction in the system (line, condenser, evaporator.
Jul 06, 2011 | Chevrolet Colorado Cars & Trucks
1997 jetta ac works for one minute then warm air blows
check the refrigerant level. The compressor is running until the low pressure or high pressure switch switch cuts it off.
Running the unit without enough refrigerant will damage the compressor because the lubricating oil is dissolved in the refrigerant. This is the reason for the low pressure switch cut off--to protect the compressor from damage.
If pressure gets too high, the compressor seals will blow. Thus the reason for the high pressure switch. Too much refrigerant or too much air in the system (due to a leak) will cause high pressures.
If refrigerant level appears to be correct, then suspect trapped air from a leak causing a high pressure cut-off. If refrigerant is low, suspect a leak causing a low pressure cut-off.
Mar 02, 2011 | Volkswagen Jetta Cars & Trucks
My music system go in stand by in high sound
When drive level is to high there is a safety shutdown built into the audio ic to protect it from shorting out. How high is the level of music before shutdown? " quarter, half, three quarter, or more " this will help me determine if the audio is running normally or not.
Feb 14, 2011 | Panasonic Audio Players & Recorders
HOW DO YOU TURN DOWN THE HISSING NOISE
You can cut the treble gain some BUT most importantly is to send adequate signal to this speaker so volume level does not have to be set high when sending LINE LEVEL signals to it. Hissing noise is a product of the statistical noise that occurs in electronics. Running any device at high gain invariably brings up the hiss level. Managing thee signal levels is the responsibility of the sound engineer.
ALSO feed ALL interconnected equipment from the same receptacle or power source, even if it means running a power cable to a mixer alongside the snake. ALWAYS USE BALANCED audio cables whenever possible.
Dec 24, 2010 | Samson Auro D415 - 2-Way Active Speaker...
How to connect Marantz PMD201 to computer to convert tapes
You have an analog tape recorder, so you need an interface which will allow you to plug it into your computer. This kind of interface is sometimes referred to as a USB Audio Interface. I use a Tapco Link.USB, and it works well, but there are many out there to choose from - you can use something pretty simple, nothing fancy needed.
The interface will plug into your computer via USB cable, and then you will use RCA cables to plug the PMD201 into the interface. When you play the audio on the tape machine, you should be able to select the "USB interface" on your computer as your "input device" and record on the computer. Watch on the computer recording software for input levels (meters that show sound is coming in), and set them to appropriate levels, not too low, not too high (if there is a red zone, you want to flirt with it only on the highest levels) ... don't hit "zero" if your computer shows zero as the peak level for input.
Final Cut Pro is far to complicated for what you are talking about doing. Many computers come with software already installed that will make simple audio recordings like this.
Please feel free to visit my website, rexark.com, for more information on audio and recording, as well as audio presentation and PA systems.
Good Luck!
Mar 04, 2010 | Marantz PMD201 Desktop Cassette Voice...
Schoche converter trouble
yes , if you do not make your connections right you could probably damage the high to low, verify that all the wires you tapped into where speaker wires
Jul 15, 2009 | Scosche Industries Scosche Slc4 Speaker...
"protect" display when volume is high and volume cuts in and out.
you should have it repaired.the audio circuit is malfunctioning because of the sudden burst/surge of current.
May 15, 2009 | Onkyo TX-SR502 Receiver
1991 Ford Taurus SHO high-level audio system troubleshooting
Look into your owners manual and find the fuse diagram-it may be that your sound system has 2 fuses for the audio system. I had the same problem in my explorer with the "premium" sound system -and it was a fuse-one said radio etc. and the other said audio system-so im guessing that one ran the deck and one ran the amp-anyhow i changed it out and it worked fine-hope that helps ya
May 11, 2009 | Car Audio & Video
Crate BT50 Bass amp cutting out with high input.
Sometimes an amplifier's preamp can't handle certain signals/frequencies at a high gain, so they cut out. Bass guitars are especially prone to giving such a strong signal.
I bought an older, nonworking bass amp recently and fixed it just to find it had the same problem. Best solution is to put a low ohm resistor at the amps input, but if you turn your guitar down to half volume it'll have the same effect: should prevent it from cutting out.
Nov 01, 2007 | Crate SPA1600 Power Amplifier - SPA Series...
Yamaha RX-V757 Receiver Logo
65 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
