Question about Plumb Pak Waste & Overflow Pipe Kit, 1 1/2"
I need to adjust my cable drain stopper. It
I need to adjust my cable drain stopper. It doesn't allow the water to drain as it is to low can I adjust it up?
  • rchigginsbsw Jul 31, 2010
    Thank you so much for this advice its works great. Also you may consider putting this information within your installation instructions.
  • 15,935 Answers
Is this on a tub?
Posted on Jul 30, 2010
  • blueextc3221
    blueextc3221 Jul 30, 2010
    All the cable operated tub drains that I work with are not dependent on
    the length of the cable to determine how far the pop up pops up, but
    instead it is the adjustment at the pop up part of the drain itself that
    is adjustable...see image below.
    Here, pull the stopper/pop up and out of the drain and see if you can
    adjust the overall height as presented below. You may need a pair of
    pliers to hold at the post or hex nut.
    Thanks!!
Moen drain adjustment
there is a rod under your sink which controls the travel of the stopper it needs to be adjusted for shorter travel.
Aug 26, 2017 | Moen Plumbing
Grohe drain stopper installation
They adjust by twisting them.
Jan 20, 2014 | Plumbing
Delta faucet will not hold water
The linkage to the drain stopper has to be adjusted so that the stopper seats when the rod is raised. If the stopper lifts out of the drain, it may be necessary to remove the lifter rod and insert it through the holes in the bottom of the stopper then reinstall. After this, pulling up on the faucet rod will force the stopper to seat rather than drop by gravity. The tradeoff is that you will not be able to remove the stopper without disassembly of the connection
Feb 18, 2013 | Plumbing
Whirlpool stopper
If there is a small loop on the bottom of the stopper, the popup lever is supposed to poke through that. All you need to do is look at the drain tailpiece for the lever sticking out the back, undo the retaining nut to allow the lever to be removed from the drain, drop the stopper down so the loop can be engaged by the actuator rod you just pulled out, retighten the nut, then make the final adjustments for open height with the small metal tab holds the lever to the piece of metal with holes in it that is attached to the drain poppet in the middle of the faucet assembly above It should close completely and then open to drain.
Jan 15, 2012 | Kohler Plumbing
Pop up sink basin wont stay down to allow water to stay in basin
I'm assuming this is a mechanical pop up drain. If so then one of three things are happening. Either the pop up mechanism needs to be adjusted, there is build up inside the drain where the stopper is or the mechanical parts are worn and need to be replaced.
Remove the items from underneath your vanity so that you have room to work. Under the vanity the pop up will have an adjustment rod. It is possible that the adjustment has slipped resulting in the drain not closing off properly. Try adjusting the connecting rod and see if that helps. If not move on to the next step.
You will need a small pail to catch any water when you disassemble the pop up. Inside the sink put something under the stopper to hold it in an open position because when you disassemble the pop up it will drop to the closed position and may be difficult to get out of the drain. Under the sink there will be rod coming out of the drain held on with a threaded nut. Unscrew the nut and the rod will come out of the drain and deattach from the pop up inside the drain. From the top of the sink remove the stopper. Clear any of the build up which is usually a distasteful combination of hair and soap scum. A pair of latex gloves come in handy at this point. Check the pop up for wear at the point where the rod attaches. It is possible that this could be worn to the point of not working correctly when the mechanics of the pop up are moved to the closed position. Your local hardware store will have any replacement parts required.
Be sure to reassemble every component before using the sink and test for leaks. Good luck with your project.
Jul 24, 2010 | Home
Tub drain wont stay open
If this is a trip lever waste type of drain it can be adjusted, Remove the 2 screws that hold the adjusting lever, this will allow you to remove the stopper. Clean the stopper of hair and sludge and replace. This will usually fix the problem. If not then adjust the linkage for the stopper.
Nov 23, 2009 | American Standard Scala Bathtub Only ...
Drain stopper in the bathtub has come off how do you reinstall when the stopper turns with a knob on the tub
the stopper just sits in the hole. When you turn the knob the cable operates the piece that raises and lowers the drain plug. The weight of it and the suction of the water is what seals it....provided the o-ring is good on the plug.
Oct 12, 2009 | Home
My bathtub drain is American Standard circa 1927. The tub stopper is actuated by turning a knob connected to a linkage connected to a rod, connected to a yoke which threads onto a sleeved pipe which...
your close to figuring it out,
I would guess you have a hair clog in the trap. they have inexpensive plastic rods (like a long zip tie) with serrated edges on it to capture the hair. Home Depot or Lowe's or Menards will have these
Jun 28, 2009 | Plumbing
Plumb Pak Waste & Overflow Pipe Kit, 1 1/2" Logo
50 people viewed this question
Top Plumb Pak Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumb Pak Plumbing Expert? Answer questions, earn points and help others
