Water leaking during wash cycle - Washing Machines
    Problem Solver:
  • 17 Answers
I've had this problem and immediately assumed it was the door gasket. However I actually sat & watched it for a whole cycle & discovered that water was running back out from the soap dispenser area and dripping from the bottom of the washer door. I removed the dispenser tray & discovered an inch of built-up soap had accumulated inside the washer, which was not allowing the water to drain through properly. Once I removed the soap & residue, problem solved.
Posted on Jul 30, 2010
Top loading washer leaking water during spin cycle
a few things could be causing this
(1) a hole has rusted thru your outer drum or maybe a dispenser line has come off inside
(2) some left over from a past wash cycle has gotten into the seal in the center agitator bearing and made it leak
(3) the dishcharge water pump has a leak in it
all these things can be routed out with just a strong flashlite and a little time to watch where water runs from during a cycle
Nov 14, 2015 | Washing Machines
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
Washing machine leaks during spin and drain cycle
If the leak is still present after you replace the hoses , you may need to get a new water pump ( cheap part ) it is probably leaking , it removes the dirty water from the washer during spin and rinse cycle . hope this helps
Jun 28, 2012 | Washing Machines
Whilst wash on, water leaks from the underneath of washing machine. but cant see where it is coming from
if the water is leaking during the fill cycle when the detergent is being added from the drawer
ensure the draw is clear, if too much deturget rests has blocked the vent then water maybe running out on the inside.
if the problem is happening during the wash cycle this indicates a leak on your drum, ensure your door seal is intact and not leaking.
if the problem is during pumping, ensure that the pump is not causing a problem
maybe open the bottom vent and ensure the cover is seated properly and pump is clear.
also check the outlet pipe is not blocked or leaking and water is running back on the outside of the outlet pipe and under the machine
I hope this was useful.
May 23, 2011 | AEG Washing Machines
Water coming out of the botton during spin cycle
Take the bottom panel off the waher, put water in the machine, and watch to see where it is leaking. If you don't see a leak during the regular cycle, put the machine in drain and spin mode, and watch for leaks there. You should find your leak during one of these cycles so you will know what part you need.
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WATER IS COMING OUT FROM THE BOTTOM OF THE WASHING MACHINE ONCE THE WASHING HAS STOPPED, IT DOES NOT LEAK DURING CYCLE AND IT SPINS AND DRAINS FINE..
i would inspect both the hoses on the pump
no leak during cycle is explained because water is moving through them to fast to leak when the machine settles it starts to leak
Oct 15, 2009 | Hotpoint Aquarius WD63 Front Load...
Water leaks during drain cycle and the machine
Hi
If the water leaks during drain and spin only: A washer that leaks only during the drain/spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Please do rate this solution as "FixYa" if found useful.
Thanks
Rylee
Mar 17, 2009 | Washing Machines
Whirlpool front loader WF665/1 spilling water during cycle. Water is leaking from where the powder is deposited into the machine during the filling stage of the washing cycle. The machine will continue its...
that means that the water is leaking from the hows at the back of the detergent drawer.
This is not a difficult fix, however the washing machine must be taken apart to access the detergent hose and find the leak.
Always better to call a technician.
Nov 16, 2008 | LG WM2487H Front Load Washer
Washing machine
If water is leaking only during the times when it is supposed to be coming in , then the first places to check are at the hose connections and the hoses themselves. If it continues to leak after the water stops coming in , then you have to look at the drain connection and finally at the drum seal.
Nov 22, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
152 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
