Question about HP W2338h 23 in. LCD TV
I have a HP monitor, HPw2338h. On the right side of the screen are vertical stripes, blue, green and red. I've tried factory reset - no luck. -jeannie
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. As you have already tried to reset the monitor to factory default I will suggest you to use different type of connection like VGA, DVI or HDMI. Also try to connect the monitor to another computer and if still the stripes are visible then the monitor has been damaged or defective and needs to be replaced. Otherwise check the video card and drivers and uninstall and reinstall the drivers if required. Also see the link for detailed step-by-step procedure to resolve the issue---
Vertical Stripes on HP Monitor W 2338H
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 30, 2010
  • honeypot60 Jul 30, 2010
    It will take me until next week to try a different cord, when I can get to a store with this kind of cord. so until then - thanks.
  • Rylee Smith
    Rylee Smith Jul 30, 2010
    OK, Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Screen is green blue and red vertical stripes, audio is ok
Sounds like a panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 06, 2014 | HP Televison & Video
Vertical green line screen try
Have you tried to do a reset via the monitors menu options?
Jan 21, 2014 | HP w1907 LCD Monitor
My hp vs 15 displays vertical color stripes that alternate different colors wether its hooked up tp computer or not what is wrong, is it junk
It may sound strange but be absolutely sure the cable is plugged into the monitor. Adapter on the computer. The serial adapter on the back looks just like video. Video actually has a faintly noticeable monitor icon rigtht next to it. Plugging into a serial can eventually blow out your monitor. Also, a.badcable can do the same thing. And if you have messed up the monitor's settings you will see the same
Apr 13, 2012 | HP vs15 15"LCD Flat Panel Monitor
Replace factory stereo with after market for 98 Dodge Ram 2500
Right Rear Spkr (-) Blue w/ Orange Stripe
Right Front Spkr (-) Blue w/ Red Stripe
Right Rear Spkr (+) Blue w/ White Stripe
Right Front Spkr (+) Purple
+12 Volt Ignition Wire Lite Purple w/ White Stripe
+12 Volt Battery Wire Pink
Left Front Spkr (-) Brown w/ Red Stripe
Left Rear Spkr (-) Brown w/ Blue Stripe
Left Front Spkr (+) Green
Left Rear Spkr (+) Brown w/ Yellow Stripe
ground would have to be connected directly to vehicle's frame
Jun 05, 2010 | Car Audio & Video
I have a 1996 dodge grand caravan with 8 speakers. Im hooking up a kenwood stereo but I can only get 4 speakers to turn on. How do I get the other 4 to turn on?
here is the wire digram hope it helps
Factory in-dash wire harness (this vehicle has a 2 pc harness)
that snaps into the factory radio
Black Plug
Gray Plug
Radio Wire & Color Code Information Page 2 of 2
Typical Dodge/Chrysler Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (-) Blue w/ White Stripe Purple w/ Black Stripe
B Left Rear Spkr (-) Brown w/ Yellow Stripe Green w/ Black Stripe
C Right Front Spkr (+) Purple Gray
D Left Front Spkr (+) Dark Green White
E Right Rear Spkr (+) Blue w/ Orange Stripe Purple
F Left Rear Spkr (+) Brown w/ Blue Stripe Green
G Power Antenna/Amp White (use for Infinity Radio) Blue
H +12 Volt Battery Wire Pink or Pink w/ White Stripe Yellow
I +12 Volt Ignition Wire Red w/ White Strip Red
J Radio Dimmer Wire Do Not Use
K Headlight Dimmer Wire Do Not Use
L Right Front Spkr (-) Blue w/ Red Stripe Gray w/ Black Stripe
M Left Front Spkr (-) Brown w/ Red Stripe White w/ Black Stripe
N No Wire
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
Feb 22, 2010 | Kenwood KDC-MP242
LG Flatron L1930B lcd monitor - 3 vert. stripes, center one dead
sounds like the pixel controllers have gone bad or one or more of the color (RGB, RED, GREEN, BLUE) controllers have gone out. this is quite common in lcd monitors/tvs and is usually caused by pressure on the edges of the screen (you grabbed it too tightly when moving the monitor) or just faulty controllers. they are expected to eventually go bad, ask LG for yourself, they will tell you the same thing. If you just bought it, that can be considered a mfr defect that they will replace, IF IT IS IN WARRANTY!!!!! Unfort. there is no fix due to seal that placed on the actual lcd panel inside the plastic casing. Youd spend more money trying to find the part and install it than just buying a new monitor. hate to say it but im an avid gamer and have gone through about 4 lcd monitors in tha past 3 years due to everyday use
Sep 18, 2009 | LG L1930B 19" LCD Monitor
Westinghouse LCD TV - broad vertical green and blue lines
try to go to the factory reset and see if that helps. If not, you can then check your connection. if you use component (red, green and blue for video and red and white for audio), make sure all the color matches when you plug it in. if everything have been checked then you need to replace the main board and it should correct the problem.
Jun 22, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I came home to find loads of red squiggles all over my monitor. Then 4 big red vertical stripes that look like bar codes. I tried to restart the computer by turning it off, then as it was starting, loads...
Wow llks like the controller died in the monitor the controlles the pixalation and stablilization in this case it looks like if its not under warrenty a new one is in order sorry no quick fix I would appricate nice feedback tho
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 23, 2009 | HP Pavilion F1703 17" LCD Monitor
Black Out
Hi Detrix, Check with www.lcdrepair.net if you want a repair. Something is wrong with your LCD controller and or GUI interface circuit or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. These circuits take the Signal from the computer and controls the 2.5 million pixels on the LCD screen. Dsut can cause major problems with handling all that data. Give it a shot, what do you have to loose, its not dangerous if the monitor is unplugged.
Oct 09, 2007 | Samsung SyncMaster 193P 19" LCD Monitor
HP W2338h 23 in. LCD TV Logo
97 people viewed this question
Top HP Televison & Video Experts
Computer Links
vbalag
Level 1 Expert
Alun Cox
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
