Question about SanDisk Sansa e260 MP3 Player
What is part number u14 and where can i purchase a new one?
I am looking for a part number or a schematic for his device. There is an IC to the bottom right of the tuning dial that needs to be replaced. Part is to burnt to read the part number on it. The device had been plugged into a wrong charging cable.
Thanks,
Joshua
U14 is an octal buffer made by Texas Instruments, part # SN74LVC244A. You can buy them from Digikey.com
Posted on Apr 28, 2008
110v accidentally plug in to 220v and the ic cut into pieces, we replace it. But the diode and resistor get damaged. What is the problem, we dont knoe thw value of the resistor because it get burned. and...
Without that info it's a **** shoot. The best you can do is Google the make and model number with the word schematic at the end. With any luck, you will find several sites that you can go to to look up or purchase the circuit diagrams and parts with their values.
Sep 04, 2011 | Oritron DAV3101 PROGRESSIVE SCAN DVD
My Philips home theater model hts3105/98 is not working due to IC breakdown hence i need that ic number to replace it. hence please help me.
Every IC has their number printed on the top 1st line. If you have identified the IC, look for the number. If it is burnt & cannot get the number, you will have to refer the schematic diagram of the model. The service manual is available under following url. Just paste the following url in your browser , a download link is there.
http://new.eserviceinfo.com/downloadsm/54246/PHILIPS_HTS3105.html
sonsunny
Jun 17, 2011 | Televison & Video
Green blinking (bottom) light. No paper feed or test print can be performed
O'Neil MF8i Infrared Printer Green light blinking problem,
Solution: There are two types of green light blinking problem slow and fast blinking so in case of slow blinking you should change the IC-LT1776 part location number on the board U14 and if the light fast blinking then need to change the part number U20 on the board.
Note: U20 Can be replace with working one only if you buy new one that will not work because its programmed by the manufacturer and normally U20 become faulty and U14 & U20 location numbers are for the old version board. With the new version board the ICs will be the same but the location number will be different.
Sep 07, 2010 | O'Neil Printers O'NEIL MF8I PORTABLE DOT...
Lanier 6720 U14 error on screen
U14 is a user code for waste toner full.
Open front cover and you will see a clear plastic bottle at the bottom of the machine; lift this out and dispose carefully of waste toner (do not reuse). When fitting back into machine, make sure that inside of bottle is clean as the detection sensor looks through the bottle to see if it is empty and if toner is covering inside of bottle, the message will remain.
Apr 20, 2010 | Lanier 5235 Printer
Schematic Diagram
I don't have a schematic but I have photos of that amp. What part do you need to identify?
babin_perry@yahoo.com
Jul 21, 2009 | Kicker KX1200.1 Car Audio Amplifier
there isn't a ic where you are talking about on my same device on the same exact device and mine doesn't have it i'm sorry for the inconvenince.
Dec 19, 2007 | SanDisk Sansa e260 MP3 Player
Magnavox lcd tv 15mf050v/17
I put heat-sinks on U14 and the regulator above it and the TV has been running fine all day. Always shut off after 14-30 minutes before. Heatsinks were just 1/2" x 1" metal strips with silicon thermal compound that I taped up to hold in place to temporarily test, as it is obviously a heat related problem.
If you try it and it works for you, post it here.
mwl777us@verizon.net
Dec 11, 2007 | Philips Magnavox 42MF521D/37 Television
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
SanDisk Sansa e260 MP3 Player Logo
46 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
