Question about Sony KDF-E55A20 55 in. LCD Television
I have vertical bars on screen
I have vertical bars on the left and right side of the tv screen they started out narrow but they are getting wider now. Is there an adjustment that can be done to get rid of them or is it something serious? The set is only a little over a year old.
    President:
  • 1,099 Answers
The T CON board of the television is bad, you need to replace this
The T-CON (Timing Control or LCD controller) board (on the LCD panel assembly). It transfer the universal image signal of TTL and LVDS signal to specific TFT (Thin Film Transistor) LCD.
This is the interface board that talks to the Logic board and the LCD panel to produce pictures on the screen. White/gray glowing screen when it fails or not getting the voltage from the logic board (the 5 or 12vdc is supplied by switched transistor on the logic board). Notes: T-CON board is mounted under the metal cover shield.
Common failures:
Scrambled pictures, Lines, multiple pictures, color smears/blotches, rolling pictures after warm up.
Blown surface mounted fuse.
No pictures, very dark screen almost like there is no backlights.
Hope this helps........
Posted on Jul 30, 2010
Sony kdl52xbr4 tv has double vision on right side of screen perfect picture on left side is this a timing control board issue?
Fault with its T'Con board itself. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 14, 2015 | Sony Televison & Video
Vertical white line in the middle of rca tv
Check and replace all the electrolytic capacitors at its vertical output section circuit.
Mar 17, 2013 | Televison & Video
I have a 42 lg lcd tv when i switch it on the right side of the screen is darker than the left also there is a vertical bar about 1" at the edge
Be careful using this TV. There is a fault somewhere. No TV should ever do that, cold or not. Replace or repair it
Nov 24, 2017 | LG 42LC2D 42 in. LCD HDTV
We can hear it but the picture is very narrow in the middle if the screen
If you are referring to a horizontal line or bar, you will have to resolder the vertical IC. You may also need to replace the electrolytic capacitors that are almost next to the same IC. Now if you have a black vertical bars on the left and to the right side of the screen, you have a horizontal problem. Bad electrolytic capacitors and bad resistors in the horizontal deflection area of the TV board! Thanks for asking and give me a few hands of support!
Sep 13, 2010 | Emerson EWF2004 20" TV
How to center a screen?
Horizontal centering is performed in the service menu. Beware! You can mess up a lot of stuff in this menu.
Aug 02, 2009 | Toshiba Televison & Video
Suddenly hor. lin. became "narrowed", smell of overheated element
try a good slap most times it works
u may have to try looking at options to change the monitor soon too, its a sign to say the monitors's getting old
hope this helped
pls rate
Jun 29, 2009 | Samsung SyncMaster 900 SL Plus (White) 19"...
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Sony KDF-E55A20 55 in. LCD Television Logo
442 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
