Question about Acer AL1916W 19" LCD Monitor
I have a lcd acer AL1916W IT WENT BLACK COMPLETELY
  • 11,361 Answers
Http://s807.photobucket.com/albums/yy352/budm/Acer%20AL1916W/
http://s807.photobucket.com/albums/yy352/budm/ACER%20AL1916W%20Abd/
Look for bad DC filter caps and open winding on the inverter transformer.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Posted on Aug 01, 2010
I'm using the AL1916w 19" as a secondary monitor for my laptop. I went to turn it on the other morning whilst it was connected and it didn't turn on. I've tried it with other computers and it seems to...
Look for bad caps just like other failed monitors as shown in my album first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 03, 2010 | Acer AL1916W 19" LCD Monitor
How do you hook up sound to the computer. I have
The ACER AL1916W does not have built-in speakers, you need to get powered speaker system for your PC.
This is the spec of the AL1916W: http://reviews.cnet.com/lcd-monitors/acer-al1916w-lcd-display/4507-3174_7-31652355.html?tag=mncolBtm;rnav
Mar 30, 2010 | Acer AL1916W 19" LCD Monitor
Acer AL1916W about 2 years old. Turned on this
Bad caps in the power supply, common problems with 2-year old monitors, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 25, 2010 | Acer AL1916W 19" LCD Monitor
My acer al1916w displays the image for 3 seconds then goes black
Sounds like your video card. Check to make sure it's connected properly. If so, check to make sure it's properly seated to *********** board. The possible issue could be the card is connected enough to display the picture, but not enough to communicate with the monitor to stay on because it has an active feed. Best of luck fixing it
Oct 14, 2009 | Acer AL1916W 19" LCD Monitor
Acer monitor x193HQ when turned-on has black
you need to center the image using the control settings on the monitor panel, hope this helps
Jun 10, 2009 | Acer AL1916W 19" LCD Monitor
After loading windows Vista screen says no signal
steve, i dont think there is any problem with monitor. restart ur pc in safe mode, change resolution to 1440X900.
Mar 02, 2009 | Acer AL1916W 19" LCD Monitor
Black screen
Your backlight is starting to go bad! These backlights are little tiny florecent bulbs, these can be replaced and they do burn out. Sounds like your back light is bad! Could be costly to replace as there are not too many places out there that will replace the bulbs.
Oct 15, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Blacking out
This is not a setting or driver issue! The best way to determine this is to connect the monitor up to another device to see if the same thing occurs! If it does then your backlight is in bad shape and it is starting to go bad. It will generate enough power to display some images, but when it continues to be on for a certain peirod of time it goes black. This is common when the backlight is starting to go bad!
Oct 04, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W Beeping
Try setting to the native resolution of 1440 x 900.
Aug 06, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
210 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
