Question about Canon PowerShot SD600 Digital Camera
Delay timer I am trying to delay the timer and it is not working. Do you have the manual that explains it Thanks
  • 2,016 Answers
You can download the manuals for the PowerShot SD600 here.
To use the self timer feature, you need to set it up in the menu first.
1. Press the Menu button. If not in the shooting menu (silhouette of a camera), use the left or right arrow to get there.
2. Use the down arrow to select Self Timer.
3. Use the right arrow to select the clockface with a 2 or a 10 (2 second or 10 second delay).
4. Press the Func./Set button.
5. Press the Menu button to exit.
Once set up, you can activate it by pressing on the down arrow. You should see an icon change from a rectangle to a clockface at the top center of the LCD when the self timer mode is selected. Press the down button again to cancel the self timer mode.
Posted on Apr 24, 2008
  • Ken Holland Oct 09, 2013
    Thank you, thank you; I have my self-timer back!! Yea!!
Hb51r manual
Plug in
make sure bulbs work
rotate dial to set choice of delay times
timer turns on at dusk,,, and delays off for amount of time you choose
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#outdoor
Gene
Dec 13, 2013 | Intermatic Outdoor Timer/Photo Control...
No 'ON' indicator in the self timer menu
The first clock sets the self-timer for a ten-second delay, the second for a two-second delay. Select the one you want to set the self-timer. Start the self-timer by pressing the shutter release button as usual.
Full details are in the "Self-Timer Photography" section of the manual (page 60 in my copy). If you need a manual you may download a copy here.
Nov 03, 2012 | Fuji FinePix S5200 / S5600 Digital Camera
I've installed a intermatic t101p201 which has a heater delay circuit - but can't get power to the heater through the delay switch when i turn the switch manually on - i haven't checked yet to...
Check that your pool heater supports optional fireman's switch
Black wires on firemans switch connect to pool heater. Power to fireman switch comes from pool equipment and not the timer.
If pool equipment does not support fireman, then cap off the wires.
Fireman switch turns off heater 15-20 minutes before turning off pump.
The purpose is so pool equipment lasts longer.
You can buy the fireman's switch separately, but if this is new timer, then switch is probably good.
Open following link to identify fireman's switch and related parts for the timer:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#fireman
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 30, 2011 | Intermatic HEATER DELAY SHUT OFF SWITCH...
I am in need of some advise. I have a pellet stove and need to replace an obselete part, I am wondering what would be the best delay relay timer to use, it will operate an 6rpm/150lb torque auger that goes...
1) Pex supply sell the E502 OFF delay Paragon product: Timing cycle begins when switch is activated, and shuts down at end of timing cycle. 5 seconds to 3 hours
http://www.pexsupply.com/Paragon-E502-Electronic-Off-Delay-Timer-5-sec-to-3-Hrs
http://www.grainger.com/Grainger/cycle-timers/timers/electrical/ecatalog/N-8hb
See manuals for Paragon product:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#percentage
2) Tork ACT120 cycle timer (minimum ON is 30 seconds)
http://www.grainger.com/Grainger/TORK-Adjustable-Cycle-Timer-4JNH8?Pid=search
http://www.nsi-sales.com/act_series.htm
See ACT manuals:
http://waterheatertimer.org/Tork-timers-and-manuals.html#cycle
3) Intermatic CT1000 cycle timer: cycle durations of 30 seconds to 30 minutes, with on-off durations from 1 minute to 29 minutes.
Click model number to access manual
http://www.intermatic.com/products/timers/mechanical%20time%20switches/percentage%20cycle%20timers.aspx
Drillspot sells indoor/outdoor 120V or 240V CT1000
http://www.drillspot.com/products/1325934/Cycle_Timer_CT1000_Cycle_Timer?s=1
4) Do a google search for 'electronic cycle timer' or 'percentage timer'
5) Timers listed above can be wired to a contactor (or relay) that turns on auger, if that's what project calls for.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Dayton off-delay timers require push-button operation
Feb 03, 2011 | Amperite Dayton Solid State Timer On Delay...
I have a fan timer that delay for 30mins for every set time but the problem is when the power is out it loses its memory and start with 30mins delay all over again
Power outages are not that common.
If I understand correctly, you have or need some kind of automatic delay timer, like the Paragon ET series.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#ET
Or maybe the Dayton off delay timer.
Or you have an occupancy sensor with time delay like the Tork SSA.
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#SSA
Is this timer hard-wired into a box, where it gets steady power?
Is the timer supposed to have a back-up rechargeable battery?
If this is a digital Tork box-type timer, most of those timers have a power-loss carryover.
If you can identify your timer, or say more details about how your timer operates and where timer is located, and what fan Load is, I might be able to suggest an alternative that works for your purpose.
Add a comment.
Dec 14, 2010 | ICP Vortex Fan Timer Control Board For Air...
Electric dryer - drum turns but no heat
If it has a conventional electro/mechaniacal timer, then the timer is faulty, as it should advance, unless of course it has a time delay function, if it has, make sure it is off.
This probably explains why it is not heating.
Plz rate this solution.Thanks.
Dec 26, 2008 | Dryers
Kitchenaid KAWS750JQ3 Top Load Washer
hi there,
make sure that the program is not on the "Intermittent Agitate Program". that would be the cause of the delay.
the other issue would be the timer itself. the timer is mechanical, so once the contact on it is corroded, it will only function intermitently or not at all.
please let me know if i can be of more help.
thanks
Sep 28, 2008 | KitchenAid KAWS750L Top Load Washer
All white pic is shown on LCD when used in Manual Mode with delayed shutter timer
You are massively overexposing the picture. Manual mode means you have to set the exposure manually. You need to adjust the settings so that the light meter reads somewhere around the zero mark.
M mode is most useful for flash photography where you want a certain level of ambient illumination in the picture as well.
If you want some control over the camera but don't want to worry about exposure too much, use A and S modes. The manual will explain all of these modes.
Aug 31, 2008 | Nikon D40x Digital Camera
Canon PowerShot SD600 Digital Camera Logo
229 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
