Question about Hotpoint VVSR1070D Top Load Washer
Agitator wont agitate. Model VVSR1070B2WW - Hotpoint VVSR1070D Top Load Washer
I have a700 series top loader washer,and the agitator wont agitate,it will spin,but wont agitate why?
The agitator itself is stripped or loose is one possibility. Take agitator off to see if it is damaged.
Jun 03, 2014 | Washing Machines
How do I remove spindle from washing bowl Model AWM270JW3062?
To remove the agitator you're going to need an extension for a socket. The size is 7/16. Remove the lid right on the tip of the agitator. There may be a plastic lid you will have to pull out of the middle. Hold the lower agitator while loosening the bolt turning your driver to the left. Be careful that part has agitator dogs in it and you don't want to lose them or your agitator wont work correctly.
May 19, 2014 | Speed Queen AWS52NW Top Load Washer
Machine wont agitate
If the machine sounds like it is running OK. The agitator has lost its connection drive shaft because gear splines that connect it to the agitator have been damaged. You didn't really do anything wrong, this just happens occasionally. Hopefully yours has a sleeve that can be replaced rather than replacing the whole agitator.
It is tricky on some agitators, their may be a nut on the top of the agitator that holds or connects the agitator to a drive shaft. The top of the agitator probably has a plastic cap that covers this up and can usually be pried off to expose it. If there doesn't appear to be connection like this then the agitator may simply lift up. If you decide to try lifting the agitator up, let me know and I give you further guidance.
You might also call your local Appliance Supply store and with your make and model number, ask them if you unit has the sleeve or do you have to replace the agitator. I'll bet they will tell you.
Mar 02, 2011 | Hoover Washing Machines
Washer agitator wont turn!
what do you mean wont turn, do you mean when it spins that agitator is stationary ? in that case you need a new transmission. if you mean that in a dual action agitator that you can spin the agitator top left and right with no resistance / the bottom doesnt move either, then you will need new agitator dogs. remove the top of the agitator and i mean the cap, some have fabric softner dispensers on the top, which means pull the green tab up and the dispenser will come off, then you remove the cap to the agitator. under that is the agitator cam. you either need a 11mm socket to take it off, or you will need a 1/2 in ratchet and extension to take it off. after that it should be very easy to replace the agitator dogs
Feb 07, 2011 | Washing Machines
The Agitator is stripped and wont spin.
This is usually the agitator dogs have worn out or broke. These are very inexpensive and easy to replace. Here is a video this will walk you thru checking and replacing the agitator dogs . You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Dec 17, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
The top wont spin and the bottom will
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only
one way.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of
the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator
should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
May 29, 2010 | Kenmore Washing Machines
I have a kenmore top load washer, The top part of
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
The top section of a two part agitator is designed to turn only one way. If the "agitator dogs" in it are worn, it wont agitate either way.
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Also see the following on how to do it.
Oct 28, 2009 | Kenmore Washing Machines
Agitator not moving, nor spinning out water
HI, can you relay you complete model number and brand name please?
May 01, 2009 | KitchenAid Washing Machines
Top of agitator not conncted to bottom
not quite sure as to how your agitator is nol onger connected??? but i looked up by model number and you can order and replace the complete agitator for about $50... ifhte agitator no longer "agitated" and was reemoved to replace teh agitator dogs (which is the most common issue) the the 2 halves of the agitaotr click back together by lining up slots betweeen the two halves.hoping this was a little helpful
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Hotpoint VVSR1070D Top Load Washer Logo
100 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
