Question about Samsung Televison & Video
We are having SAMSUNG LA37R81B tv at home its showin blurred picture we asked repair man he said we need the tcon board number so that we can buy we now need your help
    President:
  • 1,099 Answers
it possible that the problem is the the TCON board, you can try websites Shopjimmy.com,Ebay.com to buy a refurbish board for the replacement.
Also note that
The T-CON (Timing Control or LCD controller) board (on the LCD panel assembly). It transfer the universal image signal of TTL and LVDS signal to specific TFT (Thin Film Transistor) LCD.
This is the interface board that talks to the Logic board and the LCD panel to produce pictures on the screen. White/gray glowing screen when it fails or not getting the voltage from the logic board (the 5 or 12vdc is supplied by switched transistor on the logic board). Notes: T-CON board is mounted under the metal cover shield.
Common failures:
Scrambled pictures, Lines, multiple pictures, color smears/blotches, rolling pictures after warm up.
Blown surface mounted fuse.
No pictures, very dark screen almost like there is no backlights.
Hope this helpout..
Posted on Jul 30, 2010
  • Tobias Mixer
    Tobias Mixer Nov 17, 2012
    What pins to test on the outgoing harness to the TCON for appropriate voltage?
Good day. Im getting dots that fill up the tv picture. If I click the menu for the tv the picture gets a lot clearer but the dots fill up again right after I exit the menu. Also on the right side of the tv...
Try replacing the tcon board, below is a link to what I think is the right board but take the back off and make sure that is the right number before ordering as any model set can have multiple boards
Samsung LJ94 03334J BN81 04159A TCon Board 03334J S120APM4C4LV0 4...
Feb 07, 2018 | Samsung Televison & Video
Samsung tv no image have sound and a blueish glowing screen. can see back lights thru back of the cover.
Don't waste your money, home TV repairs seldom repair the problem. Just replace it and been done with the problem.
May 25, 2016 | Samsung Televison & Video
Vizio tv repair picture blurs and darkens for five seconds and then goes normal for five seconds and continues this cycle. i changed the tcon board and no change.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Jul 29, 2015 | Vizio Razor M501D-A2R 50" LED Smart TV...
Colour is not normal, sometimes the picture is too dark, football pitches bright green, peoples faces very orange.
that would be a failing tcon board on the back of the screen.you would need to replace this part but they are available on ebay the part number is on the tcon board. match the numbers a version number to get the matching board for the screen. tcon board is the board were the main wire cluster goes to the screen board this is the tcon board.
Jul 03, 2017 | Samsung LE37R72B 37 in. HD-Ready LCD...
Poloroid repair tv
Tcon board or panel is bad, chances are its the board, cost about 25 to 35 to repair if its the board
Mar 06, 2018 | Televison & Video
I have a Samsung LN37550A LCD TV (full HD 1080) that is 2 years old. 2 days back the images got washed out. All I see is mostly very bright images and negative images. I am told that the TCON card needs to...
U can't buy the T-CON board in any stores in anywhere in the world because this T-CON board it is not buy able it new u only can buy it as a salvage tv PCB board only.This T-CON board u can buy it as refurbish board only.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Sep 22, 2011 | Samsung LN37A550P LCD TV
Hello, I have a Samsung LN-S4692D. The tv turns on, the back lights work, the audio works. The picture does not work. The screen is black and when I change channels or press menu it flashes however, the...
You cannot test the T-Con bd with a meter. However if you have the luxury of having another same model tv, you can install the bought T-Con bd and see if it is good or bad. Since you said the Menu and channel flashses, then I would replace the Main board.
Apr 16, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
Sony bravia LCD KDL52 TV: blurred picture with color bands
It is most likely the TCON board (located at the top right against the LCD panel). When these boards have problems, they can act up when cold or warmed up.
You will want to check with any extended warranty company you might have, or Sony's part website for the availability of the TCON board.
The problem here is, sometimes those TCONs are not made available separately and need to be replaced with the screen.
If you have to replace the panel, buy a new tv. You'll save yourself a costly repair.
Jul 14, 2009 | Sony Bravia KDL-32V4000 32 in. LCD TV
Open Questions:
Televison & Video Logo
445 people viewed this question
Jerry Greenberg
Jerry Greenberg
