Question about Miele CVA615 Espresso Machine
The unit will not always come on. sometimes when it does turn on, it will turn off and then on again by itself. The coffee bean drawer is completely seated, (Not being held slightly out). With the door open, the unit will come on and stay on as long as the plunger switch is manually depressed. The unit and the door are both level. Miele tech support believes it is the ribbon cable, but are reluctant to send one for me to change myself. There is only one technician in this area and he knows less about the machine than I do. I paid him $85 to find that out!
josh1856
  • 105 Answers
SOURCE: Descaling a Miele Coffee maker
Put them in the water chamber then they dissolve and you run they cycle. I would cycle through a second time also with water only to flush the system out.
hope that helps.
Posted on Jan 27, 2008
Ya1da
  • 4 Answers
SOURCE: can you give me the process to descale the miele cva 615 coffee machine?
Here you go just click on this link I put the manual on my site: http://yalda.us/CVA615_us[1].pdf
Posted on Mar 12, 2008
SOURCE: miele brew unit jammed and brewunit block is being displayed
There is a third solution. The brewunit drive motor has three contact switches that indicate home, preset (loading grounds, I assume) and make espresso. The problem is the three contact switches are all on one circuit, so the microprocessor knows a limit switch has been reached, but it doesn't know which one. The programming obviously assumes the limit switches are reached in the correct sequence. In my case, the microprocessor thought the brew unit was in home position when it was in the make espresso position. Miele technical support recognized this immediately, so it is a common problem. The solution is to remove the top panel of the unit, unplug the unit, unplug JP34 on the microprocessor board (four wires, red/yellow/brown/black, in the middle back edge of the microprocessor board). Plug in the unit, put it in maintenance mode, and press and hold the medium coffee button for several seconds. This will move the drive motor past the current limit switch. Plug JP34 back in, plug in the machine, and put it in maintenance mode. Press and hold the large coffee button for a second or two, maximum. Open the machine, and look at the brew unit drive male gear in the main machine as compared to the brew unit female gear. It will take several tries to get the male/female gears to match so you can plug in the brew unit. Once this is done, and the brew unit snaps in place correctly, place the machine in maintenance mode one more time and press and hold the Medium Coffee button to reset the microprocessor with the limit switches. You should be back in business!
Posted on Jul 16, 2008
gary1121
  • 332 Answers
SOURCE: Need service manual, exploded view or part list
I just typed in your model of coffee machine in and there is a service manual in there on the web, it won't let me copy and paste but you can go there and print it out hope this will help you
Posted on May 30, 2009
  • 31 Answers
SOURCE: Door closed but machine says it's open
door switch
Posted on Oct 07, 2009
I ground a coffee cup's worth of beans. And then I changed my mind. So I quickly, pressed the power button and started over. I pressed espresso button and it ground beans again! now it is jammed. Is it...
When you turn it back on you should hear the brew unit go threw the motions. Check to see if the user ground coffee is in the dredge drawer and also see if can remove the brew group
Sep 08, 2013 | Saeco Magic Comfort Plus Espresso Machine
How do I clean my burr mill (Models BM1 and BM3)?
Always unplug your burr mill after use and before cleaning.
  1. Turn the whole bean chamber to the right until it can be lifted off the base. This will allow you to clean the grinding wheel. NOTE: Never use water or liquid for cleaning the lower grinding section of this appliance.
  2. Clean interior recesses with a soft brush (not provided).
  3. Wash the whole bean chamber and lid and the ground coffee chamber and lid in mild detergent and water. These items are only dishwasher safe on the top rack of your dishwasher. Wipe exterior with a damp cloth. Do not immerse mill in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  4. After completely drying, replace whole bean chamber. Important: when replacing whole bean chamber, screw on completely before setting grinding rate. Turn chamber clockwise (as viewed from top), until it will not turn. Fill with whole coffee beans for grinding and replace lid.
  5. Replace ground coffee chamber and lid, making sure it snaps securely into place.
Sep 02, 2011 | Bunn NHB Coffee Maker
The coffee grinder makes a sound and it grinds but the ground coffee is dumped directly in dreg container instead of going through water and turn into coffee
Hi
There is a small knob in the bean hopper. It is all the way to the plus(+). Turn it back towards the minus(-) 1 mark. Then try again. It could also be the grinder is separated and is putting to large of a grind into the brew unit. When you have dry grounds dumped into the dredge drawer, it is because the brew unit can't compress it. If it is done too many times it will break the brew drive.
Apr 19, 2011 | Saeco Incanto Classic Espresso Machine
Bean and water fault(red) light blinking when i turn on solis master 5000 coffee machine. how to fix it. Regards vh
HI First make sure everything is in and locked (brew unit, drip tray, and dredge drawer). Open the knob on the right and flow water through the wand. Now turn the knob in the bean hopper to 16 and push the brew button. If that didn't work you might have a clog in the grinder, and will need to clean it.
Jan 26, 2010 | Solis Master 5000 Espresso Machine
All of sudden my grinder plugs up. coffee settles in around the base of the burr and does not seem to fall into the grind bucket, so the machine still runs but grinding basically stops as no more more...
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Nov 03, 2009 | Solis Maestro Electric Burr Grinder
Add beans??
I had this same problem with my Saeco Magic Plus and found that cleaning the burr grinder fixed the problem. Here's a link showing how that is done:
http://www.cerinicoffee.com/Saeco_technical_documents.asp
Good Luck!
Mar 07, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco royal coffe machine
Clean the central unit whenever the coffee bean container is filled, or at least once a week. If the water hose seems dirty it is probably due to hard water and needs to be descaled.
Descaling is done with a special citric acid you can buy in any grocery store or dealer of such machines. follow the directions and run clean water through afterwards.
To clean the filter:
Switch off the machine and open service door
Remove grounds coffee container .
Remove central unit, by holding the handle and shortly pressing the PRESS key. Wash the central unit with hot water; do not use any solvent.
Make sure there are no coffee residues on the two steel filters: the upper filter can be removed by unloosening and turning the plastic pin anticlockwise using the tool supplied with your device. Dry thoroughly each central unit component, fit the filter again and tighten it properly with the screw .
Remove coffee rest drawer and clean it, using a non-abrasive solvent. Clean the service area thoroughly and fit the coffee rest drawer again. By holding the central unit by its handle, slide it back into its original position, making sure it is correctly engaged. Then close the door. Fit the coffee grounds container again.
good luck, stephen
Jul 04, 2008 | Saeco Royal Professional Espresso Machine
Saeco italia
ok turn the machine on and wait till warmed up. Open door while machine is on and remove the dreg drawer. This you always need to do when the machine is on otherwise it will not reset.
flashing means dreg drawer steady means coffee beans
Apr 05, 2008 | Saeco Incanto Classic Espresso Machine
Miele CVA615 Espresso Machine Logo
51 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
