Question about Miele Inspira Series Dishwasher w/ 6 Programs and 5 Temperatures - G2120 / G2120BL - Blac 24 in. Built-in Dishwasher
Miele Inspira g2182scsf - NOT DRYING DISHES
Hi.
I have new Miele Inspira g2182scsf. I haven't had overly full loads and there's lots of space between dishes. I use jetdry rinse aid. I use finish detergent tabs. Yet, even after long long normal wash/rinse/dry cycle, dishes are still wet. I sometimes leave them in for an hour after cycle over and they're still wet. Why?
Thank you.
rylee_smith
  • 8619 Answers
SOURCE: FOOD PARTICLES ON DISHES
Hi
If your dishwasher is cleaning poorly, check these:
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Please do rate this solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Posted on Mar 26, 2009
ginko
  • 19396 Answers
SOURCE: Drying cycle
To start ensure that heating element and fan are working.
The element can be tested reading ohms with a multimeter.
The fan can be tested evengizing it.
If the fan and element are Ok, then test and eventually replace dryness sensor and timer board.
Dryness sensor can be tested using a multimeter.
Posted on Jun 21, 2009
  • 677 Answers
SOURCE: Dishes not getting clean, white film on glasses
the problem is hard water. go to www.dishwasherfitler.com and get their fitration system. it is guaranteed to work and is amazing. you will love this product and the way your dishes look.
Posted on Jul 26, 2009
  • 423 Answers
SOURCE: LG LDF6810ST Dishes Wet
To save energy, the LG LDFx810 dishwasher product family does not turn on the heating element during the drying cycle (third blue light blinking) rather it brings the final rinse water up to a high temp (I think it is 160 degrees (f)) and then uses a condensing drying system (mounted in the door) to pull the wet, hot air from inside the dishwasher. When it works, the dishes come out pretty dry (except for some plastics)
Check this:
-When the DW does its final drain, confirm that the water drained into the garbage disposal is really hot and not just warm. Be careful to not burn yourself and use a meat thermometer if you have one.
- After the water drains for the final time and the dishwasher blinks the third light, put you hand under the left hand side of the DW door. There is a slot down there that should be exhausting warm air.
If either thing is not happening, it is time to get a professional to check things out and make repairs.
Please post back here with what you find or have further questions, OK?
Posted on Aug 12, 2009
  • 95 Answers
SOURCE: my dishwasher leaves a silt-like residue on
make sure you have really hot water also remove the lower rack and clean out around strainer and vacume it out using a wet dry vac
Posted on Oct 12, 2009
Hi, my Miel, Inspira series dishwasher makes a very loud grinding noise for a few seconds and shuts down...
It must be trying to drain out water but the pump mechanism might be rubbing due to faulty bearing. Need full model number before I can give you more details to look for. Is this happening right at the beginning of the wash cycle?
Feb 11, 2011 | Miele Dishwashers
My brand new Miele dishwasher door wont saty down when loading and unloading - tonight was the last straw as it shot up and has really hurt my forearm!!! Please tell me what I can do to sort this out =...
you can tension the door springs or release tension by a screw at the top ....you will have to look for it check the book for directions....you probably have a model made for a door panel to be fitted and dont have the panel fitted yet...
Feb 10, 2011 | Miele Inspira G2140 Dishwasher
Model Inspira G2140 SCU There is a residue on dishes and glasses Water come on is hot but does not clean
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 28, 2010 | Miele Inspira G2140 Dishwasher
My Miele Inspira has started squeaking when it runs.
Hi dear.It sounds like your machine have faulty bearing on main wash pump.That bearing can worn out it self or there is a leakage on impeller housing,that leakage can cause harsh chemical to get in to the front bearing of motor & damage it.Your machine should be under warranty,call Miele service in your country.I hope that helps.Thanks.
Jun 20, 2010 | Miele Inspira G2180SF Stainless Steel...
White film on dishes and still dirty.
Check rinse aid is actually dispensing - turn it up to max for a while to clear it, and check level is going down after a week.
If you suffer with hard water - your heating element may need replacing as it is probably furred up.
Jun 06, 2010 | Miele G892SC SS Dishwasher
I have a Miele Inspira line dishwasher and it is making a horrible sounds when I turn it on - like the water is not getting through easily
Hi If noise starts within one minute of start of program then you most likely have debris in drain pump. Under filter you will find non return valve remove valve this will expose drain pump impeller. with non return valve removed run program for 30 seconds refit valve and test. More in depth instructions available in user handbook.
Apr 11, 2010 | Miele Inspira Series Dishwasher w/ 6...
Miele G 880 SC -- dishes not drying
Make sure you are using rinse aid. even if you are using tablets which has rinse aid built into the tablets Miele still recommend using rinse aid liquid as well.
Make sure you have the rinse aid setting on 3ml
Plastic will not dry as well as plates as it doesn't hold the heat.
You could call out a Miele service tech if it is still under warranty and he would be able to increase the drying time through his computer.
Hope this helps.
Mar 20, 2010 | Miele G880 Dishwasher
Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Nov 12, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Miele Inspira Series Dishwasher w/ 6 Programs and 5 Temperatures - G2120 / G2120BL - Blac 24 in. Built-in Dishwasher Logo
248 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
