Question about TechnoMarine RSQC05 Wrist Watch
Watch hard to describe. the ******** my watch got ripped off in a drunken brawl. the two bars that are attached to the strap have come off. i live in bradford and no one can fix it! ive even travelled to leeds and no joy! apperently these bars are rare! help me please.
  • 109 Answers
You need to go to a professional watch repairman, not just a jewelry store, or a store that claims they do the repairs, but in reality, sends them out. Any watch repairman that does the work on the premises will have these in stock, rare or not.
Posted on Apr 24, 2008
I have a KC 1411 watch with a leather band how do I get this band off?
there is SHOULDER SPRING BAR , look at bottom side of your watch , there is shoulder spring bar just as normal watch.
you need to squeeze to take off watch band.
hard to get strap for this watch, its is Discontinued.
Jul 01, 2014 | Kenneth Cole Watches
I want to change the watch strap, mine is brokem
Probably don't need special order band. Most people buy band that is same width. Bands have a collapsible post on each side where they attach to the watch, you just pick a band that fits the width. To change a watch band you have to use something like a razor blade (single edge common to cleaning) to wedge between the metal frame of the watch and the band, then try to get some friction on the post and push it away from the watch and toward the middle of band such that you collapse the post and get it out of one hole that the post is in (2 holes 1 on each side of post) so you can tilt the post out. A new band usually has 2 posts included since it is common to bend the old posts getting them out and hard to just buy those. Put the post in the band, put one end of post into a hole, then tilt and compress with the razor to push post into position, then slide the razor out which allows it to go in the second hole. Now band stays attached.
Jan 10, 2012 | Adidas Adistar ADP1786 WW Watch for Men
How do i change my watch band on a eco drive i have just run out of ideas!
If your watch strap is held on by standard spring bars, then you need to remove them with a spring bar tool or a micro screwdriver.
Here is a link to short video which describes the watch strap removal and replacement process in excellent detail:
http://www.youtube.com/watch?v=TtPde-M5Xz0
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
May 29, 2011 | Citizen Eco-Drive watch
Where can I get replace band for this watch.. I have had it replace twice and the strap keeps ripping out of the screws. Where can I get another original KC band?
mcdevito75 here, Best Bet, see a small watch repair shop in your area, for the new band, You could get an orginal Kenneth Cole band on ebay.
Jun 28, 2010 | Kenneth Cole 1315 Dial Strap Watch for...
Replacement watch band
You can buy any rubber watch strap and take the loop off for replacement. Just make sure - the strap you buy is exactly the same width as the original ******** your watch. Needless to say: colour should match as well. Rate me, plz.
Mar 30, 2010 | Oakley Watches
Looks like one part of the clasp should be able to slide along the strap to adjust the length but can't figure out how to move it
Usually on these types of clasps, there is a little metal tang with a notch on the inside of the part that the worded end of the clasp slips over a bar. Under that bar is where you lift up the notched tang. After you lift it up, using a miniscrewdriver or watch knife, you can then slide the attachment to the desired band length. Then push the tang back down to lock it.
Apr 15, 2009 | Watches
How to change the strap of leather to the gel strap technomarine
What is the reference of the watch? On the Cruise collection, the process is very simple: 1.      (To remove band) Squeeze the easy release spring bar to one side until it detaches from the watch case completely, do the same for both bands.
2.      (To attach new band) Take the straps that you want to put on and squeeze the easy release spring bar with your (nail or screwdriver) and insert into little groove, it should snap right into place
3.      Do the same for other band
If you need more information, please contact us customerserviceus@technomarine.com
Feb 13, 2009 | TechnoMarine Red SquareRSQG19
How do you replace the watch band on a casio g-shock
The following proccedure mentioned can be implied for replacing only resin(plastic) strap.
If you have a spare Band, you can replace it with the help of one small four mouth screw driver and one small 1, 2 or 3 no. screw driver which you can get from any electronics/ computer hardware shop.
Band = Strap
You just need to remove the strap with the help of 1, 2 or 3 no. screw driver which ever you find convinent by removing the Spring Bars. After removing the strap put out spring bars from both sides as these may be used for again fixing the band.
If you find difficulty in removing the Band, you just need to unscrew the screws on for side of the watch case and remove the ring and after fixing the strap you can fix the ring again.
The new band can be fixed in the same way as it has been removed. You need to put the spring bar in the hollow space of strap and keeping the buckle side part of starp above the watch i.e 12 position over the space where it has to be fixed, then put one end of the Spring bar on one hole in the watch case and press the spring bar to get inside from other side (hole in the watch case). In the same way you can replace ******** other side.
In case of any difficulty take your watch to nearest Casio Service Centre for assistance or solution of problem.
Jul 20, 2008 | Casio Watches
Adjusting the strap
Most clasps have a series of small holes drilled in them, and the end of the strap is held in by a small, spring-loaded bar whose ends are seated in one set of holes. Take the end of a small paperclip, or a large needle, and use it to depress the spring-loaded pin. You can then carefully slide it to another set of holes to make the band smaller. Don't let the ends of the pin slide all the way out of the clasp, or it might shoot off into space.
Jan 22, 2008 | Versace 27473-008-00 Wrist Watch
TechnoMarine RSQC05 Wrist Watch Logo
80 people viewed this question
Top TechnoMarine Watches Experts
Ansel Alberto
Ansel Alberto
Stan Ford
Are you a TechnoMarine Watch Expert? Answer questions, earn points and help others
